[Nek5000-users] Failure with TORDER = 3 (P027)
Thu Jan 19 09:36:49 CST 2012
Dear Neks,
I am using the 758 version of the code with the new full-restart
option, and my pipe flow simulation runs quite fine with TORDER = 3,
and the projection parameters, i.e. P094 and P095 set to non-zero
values.
Regards
George
Quoting nek5000-users at lists.mcs.anl.gov:
> George,
> Can you do a run using single 4 byte .fXXXXX file using just one
> IO-node. Also, turn off the characteristics scheme (IFCHAR). Then try
> to do a restart again.
> Cheers,
> Stefan
> On 12/9/11, nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Stefan,
>> Here is a part of a file I obtained from a run that failed with TORDER = 3.
>> Regards
>> George
>> 118   Parameters from file:/
>>     1      1.00000     P001: DENSITY
>>     2     -9500.     P002: VISCOS
>>     7      1.00000     P007: RHOCP
>>     8      1.00000     P008: CONDUCT
>>    11      500.0     P011: NSTEPS
>>    12     -5.000E-04   P012: DT
>>    15      500.00     P015: IOSTEP
>>    17      1.00000     P017:
>>    18     0.500000E-01 P018: GRID < 0 --> # cells on screen
>>    19     -1.00000     P019: INTYPE
>>    20      10.0000     P020: NORDER
>>    21     0.100000E-05 P021: DIVERGENCE
>>    22     9.920000E-08 P022: HELMHOLTZ
>>    24     0.100000E-01 P024: TOLREL
>>    25     0.100000E-01 P025: TOLABS
>>    26      1.00000     P026: COURANT/NTAU
>>    27      3.00000     P027: TORDER
>>    28      0.00000     P028: TORDER: mesh velocity (0: p28=p27)
>>    54      -3.00000     P054: fixed flow rate dir: |p54|=1,2,3=x,y,z
>>    55      1.00000     P055: vol.flow rate (p54>0) or Ubar (p54<0)
>>    63      8.00000     P063: =8 --> force 8-byte output
>>    65      6.00000     P065: #iofiles (eg, 0 or 64); <0 --> sep. dirs
>>    66      6.00000     P066: output : <0=ascii, else binary
>>    67      6.00000     P067: restart: <0=ascii, else binary
>>    68      500.00     P068: iastep: freq for avg_all (0=iostep)
>>    69      50000.0     P069: : :     frequency of srf dump
>>    93      20.0000     P093: Number of previous pressure solns saved
>>    99      3.00000     P099: dealiasing: <0--> off/3--> old/4--> new
>>   102      1.00000     P102: Dump out divergence at each time step
>>   103      0.05000     P103: weight of stabilizing filter (.01)
>>   IFTRAN   =  T
>>   IFFLOW   =  T
>>   IFHEAT   =  F
>>   IFSPLIT  =  F
>>   IFLOMACH =  F
>>   IFUSERVP =  F
>>   IFUSERMV =  F
>>   IFSTRS   =  F
>>   IFCHAR   =  T
>>   IFCYCLIC =  F
>>   IFAXIS   =  F
>>   IFMVBD   =  F
>>   IFMELT   =  F
>>   IFMODEL  =  F
>>   IFKEPS   =  F
>>   IFMOAB   =  F
>>   IFNEKNEK =  F
>>   IFSYNC   =  T
>>   IFVCOR   =  T
>>   IFINTQ   =  F
>>   IFCWUZ   =  F
>>   IFSWALL  =  F
>>   IFGEOM   =  F
>>   IFSURT   =  F
>>   IFWCNO   =  F
>>   IFTMSH for field            1    =   F
>>   IFADVC for field            1    =   T
>>   IFNONL for field            1    =   F
>>   Dealiasing enabled, lxd=           12
>>   Estimated eigenvalues
>>   EIGAA =     1.650197855862139
>>   EIGGA =     71694413.86227663
>>   EIGAE =    1.5791367041742943E-002
>>   EIGAS =    7.9744816586921753E-004
>>   EIGGE =     71694413.86227663
>>   EIGGS =     2.000000000000000
>>   verify mesh topology
>>     -1.000000000000000         1.000000000000000       Xrange
>>     -1.000000000000000         1.000000000000000       Yrange
>>      0.000000000000000         25.00000000000002       Zrange
>>   done :: verify mesh topology
>>    E-solver strategy:  1 itr
>>   mg_nx:            1            5            7
>>   mg_ny:            1            5            7
>>   mg_nz:            1            5            7
>>   call usrsetvert
>>   done :: usrsetvert
>> gs_setup: 277536 unique labels shared
>>     pairwise times (avg, min, max): 0.000236133 0.000198293 0.000261211
>>     crystal router                : 0.000244021 0.000238085 0.00025022
>>     used all_to_all method: crystal router
>>     setupds time 2.1331E-02 seconds   1  2      875808      853632
>>     setvert3d:   4    16416864    23245920    16416864    16416864
>>   call usrsetvert
>>   done :: usrsetvert
>> gs_setup: 2635744 unique labels shared
>>     pairwise times (avg, min, max): 0.0004331 0.000362206 0.000494504
>>     crystal router                : 0.001126 0.0011049 0.00114682
>>     used all_to_all method: pairwise
>>     setupds time 1.9091E-01 seconds   2  4    16416864      853632
>>     setvert3d:   6    52620192   107252640    52620192    52620192
>>   call usrsetvert
>>   done :: usrsetvert
>> gs_setup: 7399328 unique labels shared
>>     pairwise times (avg, min, max): 0.000524018 0.000427318 0.000591493
>>     crystal router                : 0.00345075 0.0033884 0.0035347
>>     setupds time 5.6218E-01 seconds   3  6    52620192      853632
>>     setvert3d:   8   109485792   293870304   109485792   109485792
>>   call usrsetvert
>>   done :: usrsetvert
>> gs_setup: 14568288 unique labels shared
>>     pairwise times (avg, min, max): 0.00098448 0.000790119 0.00117922
>>     crystal router                : 0.00694697 0.00683801 0.00708301
>>     setupds time 1.4705E+00 seconds   4  8   109485792      853632
>>   setup h1 coarse grid, nx_crs=            2
>>   call usrsetvert
>>   done :: usrsetvert
>>     pairwise times (avg, min, max): 0.000271898 0.000193095 0.000345087
>>     crystal router                : 0.000370127 0.000366497 0.000374007
>>   done :: setup h1 coarse grid     562.8824191093445       sec
>>   call usrdat3
>>   done :: usrdat3
>>   set initial conditions
>>   Checking restart options: pipe?.f00001
>>   Reading checkpoint data
>>         0       0 OPEN: pipe0.f00001
>>   byte swap:  F    6.543210      -2.9312772E+35
>>       850       0 OPEN: pipe5.f00001
>>       510       0 OPEN: pipe3.f00001
>>       170       0 OPEN: pipe1.f00001
>>      1020       0 OPEN: pipe6.f00001
>>       680       0 OPEN: pipe4.f00001
>>       340       0 OPEN: pipe2.f00001
>>          0  1.6225E+02 done :: Read checkpoint data
>>                                avg data-throughput =   -65.6MBps
>>                                io-nodes =     6
>>   xyz min    -1.0000      -1.0000       0.0000
>>   uvwpt min -0.43349     -0.45564     -0.77820E-01  0.69058E+08   0.0000
>>   xyz max     1.0000       1.0000       25.000
>>   uvwpt max  0.44557      0.38210       1.4216      0.69058E+08   0.0000
>>   Restart: recompute geom. factors.
>>   regenerate geomerty data            1
>>   vol_t,vol_v:    78.53976641971477         78.53976641971477
>>   done :: regenerate geomerty data            1
>>   done :: set initial conditions
>>   call userchk
>>   done :: userchk
>> gridpoints unique/tot:     293870304    437059584
>>    dofs:                291725280                184384512
>>   Initial time: 0.1622500E+03
>>   Initialization successfully completed    616.10     sec
>> Starting time loop ...
>>       DT/DTCFL/DTFS/DTINIT   0.500E-03   0.494-323   0.299-316   0.500E-03
>> Step      1, t= 1.6225050E+02, DT= 5.0000000E-04, C=  0.251 0.0000E+00
>> 0.0000E+00
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             1            1
>>    1     1 Helmholtz VELX    F:   1.0654E+00   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     2 Helmholtz VELX    F:   1.5163E-02   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     3 Helmholtz VELX    F:   1.6029E-03   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     4 Helmholtz VELX    F:   3.9700E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     5 Helmholtz VELX    F:   1.4559E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     6 Helmholtz VELX    F:   4.8307E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     7 Helmholtz VELX    F:   1.5822E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     8 Helmholtz VELX    F:   4.7557E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     9 Helmholtz VELX    F:   1.4659E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    10 Helmholtz VELX    F:   5.6372E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    11 Helmholtz VELX    F:   1.6238E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    12 Helmholtz VELX    F:   4.9454E-08   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>            1    Hmholtz VELX:     11   4.9454E-08   1.0654E+00   9.9200E-08
>>    1     1 Helmholtz VELY    F:   1.0592E+00   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     2 Helmholtz VELY    F:   1.5106E-02   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     3 Helmholtz VELY    F:   1.6168E-03   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     4 Helmholtz VELY    F:   3.9446E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     5 Helmholtz VELY    F:   1.4562E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     6 Helmholtz VELY    F:   4.9132E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     7 Helmholtz VELY    F:   1.5898E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     8 Helmholtz VELY    F:   4.7011E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     9 Helmholtz VELY    F:   1.4592E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    10 Helmholtz VELY    F:   5.6658E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    11 Helmholtz VELY    F:   1.6209E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    12 Helmholtz VELY    F:   4.8705E-08   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>            1    Hmholtz VELY:     11   4.8705E-08   1.0592E+00   9.9200E-08
>>    1     1 Helmholtz VELZ    F:   9.0867E-01   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     2 Helmholtz VELZ    F:   1.5203E-02   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     3 Helmholtz VELZ    F:   2.3594E-03   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     4 Helmholtz VELZ    F:   5.4341E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     5 Helmholtz VELZ    F:   1.9420E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     6 Helmholtz VELZ    F:   6.9938E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     7 Helmholtz VELZ    F:   2.1336E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     8 Helmholtz VELZ    F:   6.4972E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     9 Helmholtz VELZ    F:   2.1068E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    10 Helmholtz VELZ    F:   7.2366E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    11 Helmholtz VELZ    F:   2.2873E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    12 Helmholtz VELZ    F:   6.6523E-08   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>            1    Hmholtz VELZ:     11   6.6523E-08   9.0867E-01   9.9200E-08
>>      1 1.00000E-06 8.15804E-04 1.72021E-03 4.74246E-01       1 Divergence
>>      2 1.00000E-06 4.25351E-04 1.72021E-03 2.47267E-01       1 Divergence
>>      3 1.00000E-06 2.20250E-04 1.72021E-03 1.28037E-01       1 Divergence
>>      4 1.00000E-06 1.10200E-04 1.72021E-03 6.40617E-02       1 Divergence
>>      5 1.00000E-06 6.66356E-05 1.72021E-03 3.87369E-02       1 Divergence
>>      6 1.00000E-06 4.55137E-05 1.72021E-03 2.64582E-02       1 Divergence
>>      7 1.00000E-06 3.45979E-05 1.72021E-03 2.01126E-02       1 Divergence
>>      8 1.00000E-06 2.74987E-05 1.72021E-03 1.59856E-02       1 Divergence
>>      9 1.00000E-06 2.25703E-05 1.72021E-03 1.31207E-02       1 Divergence
>>     10 1.00000E-06 1.84355E-05 1.72021E-03 1.07170E-02       1 Divergence
>>     11 1.00000E-06 1.51102E-05 1.72021E-03 8.78394E-03       1 Divergence
>>     12 1.00000E-06 1.23753E-05 1.72021E-03 7.19407E-03       1 Divergence
>>     13 1.00000E-06 9.99015E-06 1.72021E-03 5.80751E-03       1 Divergence
>>     14 1.00000E-06 7.91532E-06 1.72021E-03 4.60136E-03       1 Divergence
>>     15 1.00000E-06 6.25368E-06 1.72021E-03 3.63541E-03       1 Divergence
>>     16 1.00000E-06 4.91692E-06 1.72021E-03 2.85832E-03       1 Divergence
>>     17 1.00000E-06 3.87115E-06 1.72021E-03 2.25039E-03       1 Divergence
>>     18 1.00000E-06 3.04686E-06 1.72021E-03 1.77121E-03       1 Divergence
>>     19 1.00000E-06 2.41971E-06 1.72021E-03 1.40663E-03       1 Divergence
>>     20 1.00000E-06 1.93080E-06 1.72021E-03 1.12242E-03       1 Divergence
>>     21 1.00000E-06 1.69768E-06 1.72021E-03 9.86902E-04       1 Divergence
>>     22 1.00000E-06 1.48272E-06 1.72021E-03 8.61940E-04       1 Divergence
>>     23 1.00000E-06 1.31245E-06 1.72021E-03 7.62959E-04       1 Divergence
>>     24 1.00000E-06 1.15596E-06 1.72021E-03 6.71990E-04       1 Divergence
>>     25 1.00000E-06 9.86100E-07 1.72021E-03 5.73243E-04       1 Divergence
>>           1 U-PRES gmres:     25  9.8610E-07  1.0000E-06  1.7202E-03
>> 9.0149E+00  1.6742E+01
>>              1  DNORM, DIVEX   9.8609999662049055E-007
>> 9.8609999670093433E-007
>>    1     1 Helmholtz VELX    F:   0.0000E+00   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>            1    Hmholtz VELX:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>    1     1 Helmholtz VELY    F:   0.0000E+00   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>            1    Hmholtz VELY:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>    1     1 Helmholtz VELZ    F:   9.9993E-01   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     2 Helmholtz VELZ    F:   3.4255E-02   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     3 Helmholtz VELZ    F:   8.5689E-03   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     4 Helmholtz VELZ    F:   2.0449E-03   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     5 Helmholtz VELZ    F:   8.2452E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     6 Helmholtz VELZ    F:   2.5912E-04   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     7 Helmholtz VELZ    F:   8.5857E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     8 Helmholtz VELZ    F:   2.4937E-05   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1     9 Helmholtz VELZ    F:   8.7854E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    10 Helmholtz VELZ    F:   3.0249E-06   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    11 Helmholtz VELZ    F:   9.2479E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    12 Helmholtz VELZ    F:   3.0301E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    13 Helmholtz VELZ    F:   1.0306E-07   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>    1    14 Helmholtz VELZ    F:   3.4387E-08   9.9200E-08   1.0526E-04
>>    2.0000E+03
>>            1    Hmholtz VELZ:     13   3.4387E-08   9.9993E-01   9.9200E-08
>>      1 1.00000E-04 8.48221E-11 1.31021E-10 6.47394E-01       0 Divergence
>>           0 U-PRES gmres:      1  8.4822E-11  1.0000E-04  1.3102E-10
>> 3.6466E-01  6.1275E-01
>>          1  1.57007E-03  2.50000E+01  1.00000E+00 basflow Z
>>         1 0.1622505E+03  6.74973E-03  1.05976E-05  3.14158E+00
>> 3.14159E+00 volflow Z
>>            1   1.6225E+02  2.5581E+01 Fluid done
>> filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0500
>> filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 0.9500
>>   schfile:
>>   /cfs/klemming/nobackup/g/georgeek/Pipe_550/pipe.sch
>> Step      2, t= 1.6225100E+02, DT= 5.0000000E-04, C=  0.252 2.9590E+01
>> 2.9590E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             2            1
>>            2    Hmholtz VELX:     10   2.6583E-08   1.5981E+00   9.9200E-08
>>            2    Hmholtz VELY:     10   2.6270E-08   1.5887E+00   9.9200E-08
>>            2    Hmholtz VELZ:     10   3.7961E-08   1.3628E+00   9.9200E-08
>>           2 U-PRES gmres:     26  8.8941E-07  1.0000E-06  8.7570E-04
>> 9.3625E+00  1.7342E+01
>>              2  DNORM, DIVEX   8.8940552367860238E-007
>> 8.8940552232510758E-007
>>            2    Hmholtz VELX:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>            2    Hmholtz VELY:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>            2    Hmholtz VELZ:     11   2.9548E-08   9.9993E-01   9.9200E-08
>>           0 U-PRES gmres:      1  5.0819E-11  1.0000E-04  7.6670E-11
>> 3.6476E-01  6.1121E-01
>>          2  1.04680E-03  2.50000E+01  1.00000E+00 basflow Z
>>         2 0.1622510E+03  6.74912E-03  7.06497E-06  3.14158E+00
>>            2   1.6225E+02  2.5493E+01 Fluid done
>> Step      3, t= 1.6225150E+02, DT= 5.0000000E-04, C=  0.253 6.2005E+01
>> 3.2415E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             3            1
>>            3    Hmholtz VELX:      9   5.9973E-08   1.9551E+00   9.9200E-08
>>            3    Hmholtz VELY:      9   5.9734E-08   1.9436E+00   9.9200E-08
>>            3    Hmholtz VELZ:      9   6.7060E-08   1.6769E+00   9.9200E-08
>>           3 U-PRES gmres:     43  9.7341E-07  1.0000E-06  5.8253E-03
>> 1.5480E+01  2.9163E+01
>>              3  DNORM, DIVEX   9.7340773053122238E-007
>> 9.7340773046898007E-007
>>            3    Hmholtz VELX:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>            3    Hmholtz VELY:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>            3    Hmholtz VELZ:     10   3.2545E-08   9.9993E-01   9.9200E-08
>>           0 U-PRES gmres:      1  3.1707E-11  1.0000E-04  3.8884E-11
>> 3.6436E-01  6.1134E-01
>>          3  8.56501E-04  2.50000E+01  1.00000E+00 basflow Z
>>         3 0.1622515E+03  6.74739E-03  5.77915E-06  3.14158E+00
>>            3   1.6225E+02  3.6833E+01 Fluid done
>> Step      4, t= 1.6225200E+02, DT= 5.0000000E-04, C=  0.253 1.0909E+02
>> 4.7088E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             4            1
>>            4    Hmholtz VELX:      9   5.1382E-08   1.9533E+00   9.9200E-08
>>            4    Hmholtz VELY:      9   5.1245E-08   1.9419E+00   9.9200E-08
>>            4    Hmholtz VELZ:      9   5.8121E-08   1.6656E+00   9.9200E-08
>>           4 U-PRES gmres:     20  9.8736E-07  1.0000E-06  5.8401E-04
>> 7.2002E+00  1.3507E+01
>>              4  DNORM, DIVEX   9.8735913161531008E-007
>> 9.8735912866392627E-007
>>         4 0.1622520E+03  6.74462E-03  5.77677E-06  3.14158E+00
>>            4   1.6225E+02  1.8072E+01 Fluid done
>> Step      5, t= 1.6225250E+02, DT= 5.0000000E-04, C=  0.254 1.3731E+02
>> 2.8220E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             5            1
>>            5    Hmholtz VELX:      9   5.5907E-08   1.9533E+00   9.9200E-08
>>            5    Hmholtz VELY:      9   5.5659E-08   1.9419E+00   9.9200E-08
>>            5    Hmholtz VELZ:      9   5.9684E-08   1.6655E+00   9.9200E-08
>>           5 U-PRES gmres:     16  9.2427E-07  1.0000E-06  1.5556E-04
>> 5.7643E+00  1.0499E+01
>>              5  DNORM, DIVEX   9.2426901539348950E-007
>> 9.2426901307669303E-007
>>         5 0.1622525E+03  6.74218E-03  5.77469E-06  3.14158E+00
>>            5   1.6225E+02  1.5064E+01 Fluid done
>> Step      6, t= 1.6225300E+02, DT= 5.0000000E-04, C=  0.255 1.6256E+02
>> 2.5244E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             6            1
>>            6    Hmholtz VELX:      9   6.0915E-08   1.9533E+00   9.9200E-08
>>            6    Hmholtz VELY:      9   6.0642E-08   1.9418E+00   9.9200E-08
>>            6    Hmholtz VELZ:      9   5.9861E-08   1.6655E+00   9.9200E-08
>>           6 U-PRES gmres:     14  8.6298E-07  1.0000E-06  1.2403E-04
>> 5.0438E+00  9.0451E+00
>>              6  DNORM, DIVEX   8.6297683366363408E-007
>> 8.6297681628504936E-007
>>         6 0.1622530E+03  6.73975E-03  5.77261E-06  3.14158E+00
>>            6   1.6225E+02  1.3610E+01 Fluid done
>> Step      7, t= 1.6225350E+02, DT= 5.0000000E-04, C=  0.255 1.8632E+02
>> 2.3767E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             7            1
>>            7    Hmholtz VELX:      9   7.2389E-08   1.9533E+00   9.9200E-08
>>            7    Hmholtz VELY:      9   7.1978E-08   1.9418E+00   9.9200E-08
>>            7    Hmholtz VELZ:      9   6.0336E-08   1.6654E+00   9.9200E-08
>>           7 U-PRES gmres:     14  7.8284E-07  1.0000E-06  1.2790E-04
>> 5.0456E+00  9.0568E+00
>>              7  DNORM, DIVEX   7.8284171959673956E-007
>> 7.8284171260985997E-007
>>         7 0.1622535E+03  6.73731E-03  5.77052E-06  3.14158E+00
>>            7   1.6225E+02  1.3620E+01 Fluid done
>> Step      8, t= 1.6225400E+02, DT= 5.0000000E-04, C=  0.256 2.1010E+02
>> 2.3780E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             8            1
>>            8    Hmholtz VELX:      9   8.0530E-08   1.9533E+00   9.9200E-08
>>            8    Hmholtz VELY:      9   8.0474E-08   1.9418E+00   9.9200E-08
>>            8    Hmholtz VELZ:      9   6.1838E-08   1.6654E+00   9.9200E-08
>>           8 U-PRES gmres:     13  9.3871E-07  1.0000E-06  8.2637E-05
>> 4.6862E+00  8.3450E+00
>>              8  DNORM, DIVEX   9.3870751505892285E-007
>> 9.3870750972531774E-007
>>         8 0.1622540E+03  6.73487E-03  5.76843E-06  3.14158E+00
>>            8   1.6225E+02  1.2911E+01 Fluid done
>> Step      9, t= 1.6225450E+02, DT= 5.0000000E-04, C=  0.257 2.3318E+02
>> 2.3081E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22             9            1
>>            9    Hmholtz VELX:      9   8.5197E-08   1.9533E+00   9.9200E-08
>>            9    Hmholtz VELY:      9   8.4881E-08   1.9418E+00   9.9200E-08
>>            9    Hmholtz VELZ:      9   6.3849E-08   1.6654E+00   9.9200E-08
>>           9 U-PRES gmres:     10  8.0419E-07  1.0000E-06  5.5243E-05
>> 3.6054E+00  6.2748E+00
>>              9  DNORM, DIVEX   8.0418938467388352E-007
>> 8.0418939044644440E-007
>>         9 0.1622545E+03  6.73242E-03  5.76633E-06  3.14158E+00
>>            9   1.6225E+02  1.0838E+01 Fluid done
>> Step     10, t= 1.6225500E+02, DT= 5.0000000E-04, C=  0.257 2.5418E+02
>> 2.0995E+01
>>               Solving for fluid
>>     9.9200000000000002E-008  p22            10            1
>>           10    Hmholtz VELX:      9   8.7316E-08   1.9533E+00   9.9200E-08
>>           10    Hmholtz VELY:      9   8.7257E-08   1.9418E+00   9.9200E-08
>>           10    Hmholtz VELZ:      9   6.5276E-08   1.6654E+00   9.9200E-08
>>          10 U-PRES gmres:     14  7.9070E-07  1.0000E-06  5.7631E-05
>> 5.0451E+00  9.0540E+00
>>             10  DNORM, DIVEX   7.9069874056473697E-007
>> 7.9069875187583686E-007
>>        10 0.1622550E+03  6.72998E-03  5.76424E-06  3.14158E+00
>>           10   1.6225E+02  1.3620E+01 Fluid done
>> Step     11, t= 1.6225550E+02, DT= 5.0000000E-04, C=  0.258 2.7885E+02
>> 2.4675E+01
>>               Solving for fluid
>>      11   100 **ERROR**: Failed in HMHOLTZ: VELX   7.9521E+07
>>      11   100 **ERROR**: Failed in HMHOLTZ: VELY   2.8223E+03
>>           11    Hmholtz VELZ:      9   6.6283E-08   1.6654E+00   9.9200E-08
>>          11 U-PRES gmres:    100  1.6296E+02  1.0000E-06  2.6253E+12
>> 3.6002E+01  6.8265E+01
>>             11  DNORM, DIVEX    54998323.86255041         162.9642641112922
>>        11 0.1622555E+03  4.32525E-03  3.70458E-06  3.14159E+00
>>           11   1.6226E+02  9.4526E+01 Fluid done
>>   CFL, Ctarg!    11083557069312.66         1.000000000000000
>>   call outfld: ifpsco:  F
>>         12  1.6226E+02 Write checkpoint:
>>         0      12 OPEN: pipe0.f00001
>>       850      12 OPEN: pipe5.f00001
>>       510      12 OPEN: pipe3.f00001
>>       170      12 OPEN: pipe1.f00001
>>      1020      12 OPEN: pipe6.f00001
>>       680      12 OPEN: pipe4.f00001
>>       340      12 OPEN: pipe2.f00001
>>         12  1.6226E+02 done :: Write checkpoint
>>                                file size =     234.E+02MB
>>            899  Emergency exit:           12    time =    162.2554999999999
>>            512  Emergency exit:           12    time =    162.2554999999999
>>            459  Emergency exit:           12    time =    162.2554999999999
>>    Latest solution and data are dumped for post-processing.
>>    *** STOP ***
>>            461  Emergency exit:           12    time =    162.2554999999999
>>    *** STOP ***
>>> Geroge,
>>> Can you provide more details. A logfile would be helpful.
>>> Cheers,
>>> Stefan
>> This message was sent using IMP, the Internet Messaging Program.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
