[Nek5000-users] Failure with TORDER = 3 (P027)
Thu Jan 19 09:39:35 CST 2012
Thank you George - so do I interpret this to mean that
all is ok?
Paul
On Thu, 19 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I am using the 758 version of the code with the new full-restart option, and
> my pipe flow simulation runs quite fine with TORDER = 3, and the projection
> parameters, i.e. P094 and P095 set to non-zero values.
> Regards
> George
> Quoting nek5000-users at lists.mcs.anl.gov:
>> George,
>> Can you do a run using single 4 byte .fXXXXX file using just one
>> IO-node. Also, turn off the characteristics scheme (IFCHAR). Then try
>> to do a restart again.
>> Cheers,
>> Stefan
>> On 12/9/11, nek5000-users at lists.mcs.anl.gov
>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Stefan,
>>> Here is a part of a file I obtained from a run that failed with TORDER =
>>> 3.
>>> Regards
>>> George
>>> 118   Parameters from file:/
>>>    1      1.00000     P001: DENSITY
>>>    2     -9500.     P002: VISCOS
>>>    7      1.00000     P007: RHOCP
>>>    8      1.00000     P008: CONDUCT
>>>   11      500.0     P011: NSTEPS
>>>   12     -5.000E-04   P012: DT
>>>   15      500.00     P015: IOSTEP
>>>   17      1.00000     P017:
>>>   18     0.500000E-01 P018: GRID < 0 --> # cells on screen
>>>   19     -1.00000     P019: INTYPE
>>>   20      10.0000     P020: NORDER
>>>   21     0.100000E-05 P021: DIVERGENCE
>>>   22     9.920000E-08 P022: HELMHOLTZ
>>>   24     0.100000E-01 P024: TOLREL
>>>   25     0.100000E-01 P025: TOLABS
>>>   26      1.00000     P026: COURANT/NTAU
>>>   27      3.00000     P027: TORDER
>>>   28      0.00000     P028: TORDER: mesh velocity (0: p28=p27)
>>>   54      -3.00000     P054: fixed flow rate dir: |p54|=1,2,3=x,y,z
>>>   55      1.00000     P055: vol.flow rate (p54>0) or Ubar (p54<0)
>>>   63      8.00000     P063: =8 --> force 8-byte output
>>>   65      6.00000     P065: #iofiles (eg, 0 or 64); <0 --> sep. dirs
>>>   66      6.00000     P066: output : <0=ascii, else binary
>>>   67      6.00000     P067: restart: <0=ascii, else binary
>>>   68      500.00     P068: iastep: freq for avg_all (0=iostep)
>>>   69      50000.0     P069: : :     frequency of srf dump
>>>   93      20.0000     P093: Number of previous pressure solns saved
>>>   99      3.00000     P099: dealiasing: <0--> off/3--> old/4--> new
>>>  102      1.00000     P102: Dump out divergence at each time step
>>>  103      0.05000     P103: weight of stabilizing filter (.01)
>>>  IFTRAN   =  T
>>>  IFFLOW   =  T
>>>  IFHEAT   =  F
>>>  IFSPLIT  =  F
>>>  IFLOMACH =  F
>>>  IFUSERVP =  F
>>>  IFUSERMV =  F
>>>  IFSTRS   =  F
>>>  IFCHAR   =  T
>>>  IFCYCLIC =  F
>>>  IFAXIS   =  F
>>>  IFMVBD   =  F
>>>  IFMELT   =  F
>>>  IFMODEL  =  F
>>>  IFKEPS   =  F
>>>  IFMOAB   =  F
>>>  IFNEKNEK =  F
>>>  IFSYNC   =  T
>>>  IFVCOR   =  T
>>>  IFINTQ   =  F
>>>  IFCWUZ   =  F
>>>  IFSWALL  =  F
>>>  IFGEOM   =  F
>>>  IFSURT   =  F
>>>  IFWCNO   =  F
>>>  IFTMSH for field            1    =   F
>>>  IFADVC for field            1    =   T
>>>  IFNONL for field            1    =   F
>>>  Dealiasing enabled, lxd=           12
>>>  Estimated eigenvalues
>>>  EIGAA =     1.650197855862139
>>>  EIGGA =     71694413.86227663
>>>  EIGAE =    1.5791367041742943E-002
>>>  EIGAS =    7.9744816586921753E-004
>>>  EIGGE =     71694413.86227663
>>>  EIGGS =     2.000000000000000
>>>  verify mesh topology
>>>    -1.000000000000000         1.000000000000000       Xrange
>>>    -1.000000000000000         1.000000000000000       Yrange
>>>     0.000000000000000         25.00000000000002       Zrange
>>>  done :: verify mesh topology
>>>   E-solver strategy:  1 itr
>>>  mg_nx:            1            5            7
>>>  mg_ny:            1            5            7
>>>  mg_nz:            1            5            7
>>>  call usrsetvert
>>>  done :: usrsetvert
>>> gs_setup: 277536 unique labels shared
>>>    pairwise times (avg, min, max): 0.000236133 0.000198293 0.000261211
>>>    crystal router                : 0.000244021 0.000238085 0.00025022
>>>    used all_to_all method: crystal router
>>>    setupds time 2.1331E-02 seconds   1  2      875808      853632
>>>    setvert3d:   4    16416864    23245920    16416864    16416864
>>>  call usrsetvert
>>>  done :: usrsetvert
>>> gs_setup: 2635744 unique labels shared
>>>    pairwise times (avg, min, max): 0.0004331 0.000362206 0.000494504
>>>    crystal router                : 0.001126 0.0011049 0.00114682
>>>    used all_to_all method: pairwise
>>>    setupds time 1.9091E-01 seconds   2  4    16416864      853632
>>>    setvert3d:   6    52620192   107252640    52620192    52620192
>>>  call usrsetvert
>>>  done :: usrsetvert
>>> gs_setup: 7399328 unique labels shared
>>>    pairwise times (avg, min, max): 0.000524018 0.000427318 0.000591493
>>>    crystal router                : 0.00345075 0.0033884 0.0035347
>>>    setupds time 5.6218E-01 seconds   3  6    52620192      853632
>>>    setvert3d:   8   109485792   293870304   109485792   109485792
>>>  call usrsetvert
>>>  done :: usrsetvert
>>> gs_setup: 14568288 unique labels shared
>>>    pairwise times (avg, min, max): 0.00098448 0.000790119 0.00117922
>>>    crystal router                : 0.00694697 0.00683801 0.00708301
>>>    setupds time 1.4705E+00 seconds   4  8   109485792      853632
>>>  setup h1 coarse grid, nx_crs=            2
>>>  call usrsetvert
>>>  done :: usrsetvert
>>>    pairwise times (avg, min, max): 0.000271898 0.000193095 0.000345087
>>>    crystal router                : 0.000370127 0.000366497 0.000374007
>>>  done :: setup h1 coarse grid     562.8824191093445       sec
>>>  call usrdat3
>>>  done :: usrdat3
>>>  set initial conditions
>>>  Checking restart options: pipe?.f00001
>>>  Reading checkpoint data
>>>        0       0 OPEN: pipe0.f00001
>>>  byte swap:  F    6.543210      -2.9312772E+35
>>>      850       0 OPEN: pipe5.f00001
>>>      510       0 OPEN: pipe3.f00001
>>>      170       0 OPEN: pipe1.f00001
>>>     1020       0 OPEN: pipe6.f00001
>>>      680       0 OPEN: pipe4.f00001
>>>      340       0 OPEN: pipe2.f00001
>>>         0  1.6225E+02 done :: Read checkpoint data
>>>                               avg data-throughput =   -65.6MBps
>>>                               io-nodes =     6
>>>  xyz min    -1.0000      -1.0000       0.0000
>>>  uvwpt min -0.43349     -0.45564     -0.77820E-01  0.69058E+08   0.0000
>>>  xyz max     1.0000       1.0000       25.000
>>>  uvwpt max  0.44557      0.38210       1.4216      0.69058E+08   0.0000
>>>  Restart: recompute geom. factors.
>>>  regenerate geomerty data            1
>>>  vol_t,vol_v:    78.53976641971477         78.53976641971477
>>>  done :: regenerate geomerty data            1
>>>  done :: set initial conditions
>>>  call userchk
>>>  done :: userchk
>>> gridpoints unique/tot:     293870304    437059584
>>>   dofs:                291725280                184384512
>>>  Initial time: 0.1622500E+03
>>>  Initialization successfully completed    616.10     sec
>>> Starting time loop ...
>>>      DT/DTCFL/DTFS/DTINIT   0.500E-03   0.494-323   0.299-316   0.500E-03
>>> Step      1, t= 1.6225050E+02, DT= 5.0000000E-04, C=  0.251 0.0000E+00
>>> 0.0000E+00
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             1            1
>>>   1     1 Helmholtz VELX    F:   1.0654E+00   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     2 Helmholtz VELX    F:   1.5163E-02   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     3 Helmholtz VELX    F:   1.6029E-03   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     4 Helmholtz VELX    F:   3.9700E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     5 Helmholtz VELX    F:   1.4559E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     6 Helmholtz VELX    F:   4.8307E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     7 Helmholtz VELX    F:   1.5822E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     8 Helmholtz VELX    F:   4.7557E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     9 Helmholtz VELX    F:   1.4659E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    10 Helmholtz VELX    F:   5.6372E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    11 Helmholtz VELX    F:   1.6238E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    12 Helmholtz VELX    F:   4.9454E-08   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>           1    Hmholtz VELX:     11   4.9454E-08   1.0654E+00   9.9200E-08
>>>   1     1 Helmholtz VELY    F:   1.0592E+00   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     2 Helmholtz VELY    F:   1.5106E-02   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     3 Helmholtz VELY    F:   1.6168E-03   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     4 Helmholtz VELY    F:   3.9446E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     5 Helmholtz VELY    F:   1.4562E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     6 Helmholtz VELY    F:   4.9132E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     7 Helmholtz VELY    F:   1.5898E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     8 Helmholtz VELY    F:   4.7011E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     9 Helmholtz VELY    F:   1.4592E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    10 Helmholtz VELY    F:   5.6658E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    11 Helmholtz VELY    F:   1.6209E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    12 Helmholtz VELY    F:   4.8705E-08   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>           1    Hmholtz VELY:     11   4.8705E-08   1.0592E+00   9.9200E-08
>>>   1     1 Helmholtz VELZ    F:   9.0867E-01   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     2 Helmholtz VELZ    F:   1.5203E-02   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     3 Helmholtz VELZ    F:   2.3594E-03   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     4 Helmholtz VELZ    F:   5.4341E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     5 Helmholtz VELZ    F:   1.9420E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     6 Helmholtz VELZ    F:   6.9938E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     7 Helmholtz VELZ    F:   2.1336E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     8 Helmholtz VELZ    F:   6.4972E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     9 Helmholtz VELZ    F:   2.1068E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    10 Helmholtz VELZ    F:   7.2366E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    11 Helmholtz VELZ    F:   2.2873E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    12 Helmholtz VELZ    F:   6.6523E-08   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>           1    Hmholtz VELZ:     11   6.6523E-08   9.0867E-01   9.9200E-08
>>>     1 1.00000E-06 8.15804E-04 1.72021E-03 4.74246E-01       1 Divergence
>>>     2 1.00000E-06 4.25351E-04 1.72021E-03 2.47267E-01       1 Divergence
>>>     3 1.00000E-06 2.20250E-04 1.72021E-03 1.28037E-01       1 Divergence
>>>     4 1.00000E-06 1.10200E-04 1.72021E-03 6.40617E-02       1 Divergence
>>>     5 1.00000E-06 6.66356E-05 1.72021E-03 3.87369E-02       1 Divergence
>>>     6 1.00000E-06 4.55137E-05 1.72021E-03 2.64582E-02       1 Divergence
>>>     7 1.00000E-06 3.45979E-05 1.72021E-03 2.01126E-02       1 Divergence
>>>     8 1.00000E-06 2.74987E-05 1.72021E-03 1.59856E-02       1 Divergence
>>>     9 1.00000E-06 2.25703E-05 1.72021E-03 1.31207E-02       1 Divergence
>>>    10 1.00000E-06 1.84355E-05 1.72021E-03 1.07170E-02       1 Divergence
>>>    11 1.00000E-06 1.51102E-05 1.72021E-03 8.78394E-03       1 Divergence
>>>    12 1.00000E-06 1.23753E-05 1.72021E-03 7.19407E-03       1 Divergence
>>>    13 1.00000E-06 9.99015E-06 1.72021E-03 5.80751E-03       1 Divergence
>>>    14 1.00000E-06 7.91532E-06 1.72021E-03 4.60136E-03       1 Divergence
>>>    15 1.00000E-06 6.25368E-06 1.72021E-03 3.63541E-03       1 Divergence
>>>    16 1.00000E-06 4.91692E-06 1.72021E-03 2.85832E-03       1 Divergence
>>>    17 1.00000E-06 3.87115E-06 1.72021E-03 2.25039E-03       1 Divergence
>>>    18 1.00000E-06 3.04686E-06 1.72021E-03 1.77121E-03       1 Divergence
>>>    19 1.00000E-06 2.41971E-06 1.72021E-03 1.40663E-03       1 Divergence
>>>    20 1.00000E-06 1.93080E-06 1.72021E-03 1.12242E-03       1 Divergence
>>>    21 1.00000E-06 1.69768E-06 1.72021E-03 9.86902E-04       1 Divergence
>>>    22 1.00000E-06 1.48272E-06 1.72021E-03 8.61940E-04       1 Divergence
>>>    23 1.00000E-06 1.31245E-06 1.72021E-03 7.62959E-04       1 Divergence
>>>    24 1.00000E-06 1.15596E-06 1.72021E-03 6.71990E-04       1 Divergence
>>>    25 1.00000E-06 9.86100E-07 1.72021E-03 5.73243E-04       1 Divergence
>>>          1 U-PRES gmres:     25  9.8610E-07  1.0000E-06  1.7202E-03
>>> 9.0149E+00  1.6742E+01
>>>             1  DNORM, DIVEX   9.8609999662049055E-007
>>> 9.8609999670093433E-007
>>>   1     1 Helmholtz VELX    F:   0.0000E+00   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>           1    Hmholtz VELX:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>>   1     1 Helmholtz VELY    F:   0.0000E+00   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>           1    Hmholtz VELY:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>>   1     1 Helmholtz VELZ    F:   9.9993E-01   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     2 Helmholtz VELZ    F:   3.4255E-02   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     3 Helmholtz VELZ    F:   8.5689E-03   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     4 Helmholtz VELZ    F:   2.0449E-03   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     5 Helmholtz VELZ    F:   8.2452E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     6 Helmholtz VELZ    F:   2.5912E-04   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     7 Helmholtz VELZ    F:   8.5857E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     8 Helmholtz VELZ    F:   2.4937E-05   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1     9 Helmholtz VELZ    F:   8.7854E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    10 Helmholtz VELZ    F:   3.0249E-06   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    11 Helmholtz VELZ    F:   9.2479E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    12 Helmholtz VELZ    F:   3.0301E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    13 Helmholtz VELZ    F:   1.0306E-07   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>   1    14 Helmholtz VELZ    F:   3.4387E-08   9.9200E-08   1.0526E-04
>>>   2.0000E+03
>>>           1    Hmholtz VELZ:     13   3.4387E-08   9.9993E-01   9.9200E-08
>>>     1 1.00000E-04 8.48221E-11 1.31021E-10 6.47394E-01       0 Divergence
>>>          0 U-PRES gmres:      1  8.4822E-11  1.0000E-04  1.3102E-10
>>> 3.6466E-01  6.1275E-01
>>>         1  1.57007E-03  2.50000E+01  1.00000E+00 basflow Z
>>>        1 0.1622505E+03  6.74973E-03  1.05976E-05  3.14158E+00
>>> 3.14159E+00 volflow Z
>>>           1   1.6225E+02  2.5581E+01 Fluid done
>>> filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0500
>>> filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 0.9500
>>>  schfile:
>>>  /cfs/klemming/nobackup/g/georgeek/Pipe_550/pipe.sch
>>> Step      2, t= 1.6225100E+02, DT= 5.0000000E-04, C=  0.252 2.9590E+01
>>> 2.9590E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             2            1
>>>           2    Hmholtz VELX:     10   2.6583E-08   1.5981E+00   9.9200E-08
>>>           2    Hmholtz VELY:     10   2.6270E-08   1.5887E+00   9.9200E-08
>>>           2    Hmholtz VELZ:     10   3.7961E-08   1.3628E+00   9.9200E-08
>>>          2 U-PRES gmres:     26  8.8941E-07  1.0000E-06  8.7570E-04
>>> 9.3625E+00  1.7342E+01
>>>             2  DNORM, DIVEX   8.8940552367860238E-007
>>> 8.8940552232510758E-007
>>>           2    Hmholtz VELX:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>>           2    Hmholtz VELY:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>>           2    Hmholtz VELZ:     11   2.9548E-08   9.9993E-01   9.9200E-08
>>>          0 U-PRES gmres:      1  5.0819E-11  1.0000E-04  7.6670E-11
>>> 3.6476E-01  6.1121E-01
>>>         2  1.04680E-03  2.50000E+01  1.00000E+00 basflow Z
>>>        2 0.1622510E+03  6.74912E-03  7.06497E-06  3.14158E+00
>>>           2   1.6225E+02  2.5493E+01 Fluid done
>>> Step      3, t= 1.6225150E+02, DT= 5.0000000E-04, C=  0.253 6.2005E+01
>>> 3.2415E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             3            1
>>>           3    Hmholtz VELX:      9   5.9973E-08   1.9551E+00   9.9200E-08
>>>           3    Hmholtz VELY:      9   5.9734E-08   1.9436E+00   9.9200E-08
>>>           3    Hmholtz VELZ:      9   6.7060E-08   1.6769E+00   9.9200E-08
>>>          3 U-PRES gmres:     43  9.7341E-07  1.0000E-06  5.8253E-03
>>> 1.5480E+01  2.9163E+01
>>>             3  DNORM, DIVEX   9.7340773053122238E-007
>>> 9.7340773046898007E-007
>>>           3    Hmholtz VELX:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>>           3    Hmholtz VELY:      0   0.0000E+00   0.0000E+00   9.9200E-08
>>>           3    Hmholtz VELZ:     10   3.2545E-08   9.9993E-01   9.9200E-08
>>>          0 U-PRES gmres:      1  3.1707E-11  1.0000E-04  3.8884E-11
>>> 3.6436E-01  6.1134E-01
>>>         3  8.56501E-04  2.50000E+01  1.00000E+00 basflow Z
>>>        3 0.1622515E+03  6.74739E-03  5.77915E-06  3.14158E+00
>>>           3   1.6225E+02  3.6833E+01 Fluid done
>>> Step      4, t= 1.6225200E+02, DT= 5.0000000E-04, C=  0.253 1.0909E+02
>>> 4.7088E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             4            1
>>>           4    Hmholtz VELX:      9   5.1382E-08   1.9533E+00   9.9200E-08
>>>           4    Hmholtz VELY:      9   5.1245E-08   1.9419E+00   9.9200E-08
>>>           4    Hmholtz VELZ:      9   5.8121E-08   1.6656E+00   9.9200E-08
>>>          4 U-PRES gmres:     20  9.8736E-07  1.0000E-06  5.8401E-04
>>> 7.2002E+00  1.3507E+01
>>>             4  DNORM, DIVEX   9.8735913161531008E-007
>>> 9.8735912866392627E-007
>>>        4 0.1622520E+03  6.74462E-03  5.77677E-06  3.14158E+00
>>>           4   1.6225E+02  1.8072E+01 Fluid done
>>> Step      5, t= 1.6225250E+02, DT= 5.0000000E-04, C=  0.254 1.3731E+02
>>> 2.8220E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             5            1
>>>           5    Hmholtz VELX:      9   5.5907E-08   1.9533E+00   9.9200E-08
>>>           5    Hmholtz VELY:      9   5.5659E-08   1.9419E+00   9.9200E-08
>>>           5    Hmholtz VELZ:      9   5.9684E-08   1.6655E+00   9.9200E-08
>>>          5 U-PRES gmres:     16  9.2427E-07  1.0000E-06  1.5556E-04
>>> 5.7643E+00  1.0499E+01
>>>             5  DNORM, DIVEX   9.2426901539348950E-007
>>> 9.2426901307669303E-007
>>>        5 0.1622525E+03  6.74218E-03  5.77469E-06  3.14158E+00
>>>           5   1.6225E+02  1.5064E+01 Fluid done
>>> Step      6, t= 1.6225300E+02, DT= 5.0000000E-04, C=  0.255 1.6256E+02
>>> 2.5244E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             6            1
>>>           6    Hmholtz VELX:      9   6.0915E-08   1.9533E+00   9.9200E-08
>>>           6    Hmholtz VELY:      9   6.0642E-08   1.9418E+00   9.9200E-08
>>>           6    Hmholtz VELZ:      9   5.9861E-08   1.6655E+00   9.9200E-08
>>>          6 U-PRES gmres:     14  8.6298E-07  1.0000E-06  1.2403E-04
>>> 5.0438E+00  9.0451E+00
>>>             6  DNORM, DIVEX   8.6297683366363408E-007
>>> 8.6297681628504936E-007
>>>        6 0.1622530E+03  6.73975E-03  5.77261E-06  3.14158E+00
>>>           6   1.6225E+02  1.3610E+01 Fluid done
>>> Step      7, t= 1.6225350E+02, DT= 5.0000000E-04, C=  0.255 1.8632E+02
>>> 2.3767E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             7            1
>>>           7    Hmholtz VELX:      9   7.2389E-08   1.9533E+00   9.9200E-08
>>>           7    Hmholtz VELY:      9   7.1978E-08   1.9418E+00   9.9200E-08
>>>           7    Hmholtz VELZ:      9   6.0336E-08   1.6654E+00   9.9200E-08
>>>          7 U-PRES gmres:     14  7.8284E-07  1.0000E-06  1.2790E-04
>>> 5.0456E+00  9.0568E+00
>>>             7  DNORM, DIVEX   7.8284171959673956E-007
>>> 7.8284171260985997E-007
>>>        7 0.1622535E+03  6.73731E-03  5.77052E-06  3.14158E+00
>>>           7   1.6225E+02  1.3620E+01 Fluid done
>>> Step      8, t= 1.6225400E+02, DT= 5.0000000E-04, C=  0.256 2.1010E+02
>>> 2.3780E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             8            1
>>>           8    Hmholtz VELX:      9   8.0530E-08   1.9533E+00   9.9200E-08
>>>           8    Hmholtz VELY:      9   8.0474E-08   1.9418E+00   9.9200E-08
>>>           8    Hmholtz VELZ:      9   6.1838E-08   1.6654E+00   9.9200E-08
>>>          8 U-PRES gmres:     13  9.3871E-07  1.0000E-06  8.2637E-05
>>> 4.6862E+00  8.3450E+00
>>>             8  DNORM, DIVEX   9.3870751505892285E-007
>>> 9.3870750972531774E-007
>>>        8 0.1622540E+03  6.73487E-03  5.76843E-06  3.14158E+00
>>>           8   1.6225E+02  1.2911E+01 Fluid done
>>> Step      9, t= 1.6225450E+02, DT= 5.0000000E-04, C=  0.257 2.3318E+02
>>> 2.3081E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22             9            1
>>>           9    Hmholtz VELX:      9   8.5197E-08   1.9533E+00   9.9200E-08
>>>           9    Hmholtz VELY:      9   8.4881E-08   1.9418E+00   9.9200E-08
>>>           9    Hmholtz VELZ:      9   6.3849E-08   1.6654E+00   9.9200E-08
>>>          9 U-PRES gmres:     10  8.0419E-07  1.0000E-06  5.5243E-05
>>> 3.6054E+00  6.2748E+00
>>>             9  DNORM, DIVEX   8.0418938467388352E-007
>>> 8.0418939044644440E-007
>>>        9 0.1622545E+03  6.73242E-03  5.76633E-06  3.14158E+00
>>>           9   1.6225E+02  1.0838E+01 Fluid done
>>> Step     10, t= 1.6225500E+02, DT= 5.0000000E-04, C=  0.257 2.5418E+02
>>> 2.0995E+01
>>>              Solving for fluid
>>>    9.9200000000000002E-008  p22            10            1
>>>          10    Hmholtz VELX:      9   8.7316E-08   1.9533E+00   9.9200E-08
>>>          10    Hmholtz VELY:      9   8.7257E-08   1.9418E+00   9.9200E-08
>>>          10    Hmholtz VELZ:      9   6.5276E-08   1.6654E+00   9.9200E-08
>>>         10 U-PRES gmres:     14  7.9070E-07  1.0000E-06  5.7631E-05
>>> 5.0451E+00  9.0540E+00
>>>            10  DNORM, DIVEX   7.9069874056473697E-007
>>> 7.9069875187583686E-007
>>>       10 0.1622550E+03  6.72998E-03  5.76424E-06  3.14158E+00
>>>          10   1.6225E+02  1.3620E+01 Fluid done
>>> Step     11, t= 1.6225550E+02, DT= 5.0000000E-04, C=  0.258 2.7885E+02
>>> 2.4675E+01
>>>              Solving for fluid
>>>     11   100 **ERROR**: Failed in HMHOLTZ: VELX   7.9521E+07
>>>     11   100 **ERROR**: Failed in HMHOLTZ: VELY   2.8223E+03
>>>          11    Hmholtz VELZ:      9   6.6283E-08   1.6654E+00   9.9200E-08
>>>         11 U-PRES gmres:    100  1.6296E+02  1.0000E-06  2.6253E+12
>>> 3.6002E+01  6.8265E+01
>>>            11  DNORM, DIVEX    54998323.86255041         162.9642641112922
>>>       11 0.1622555E+03  4.32525E-03  3.70458E-06  3.14159E+00
>>>          11   1.6226E+02  9.4526E+01 Fluid done
>>>  CFL, Ctarg!    11083557069312.66         1.000000000000000
>>>  call outfld: ifpsco:  F
>>>        12  1.6226E+02 Write checkpoint:
>>>        0      12 OPEN: pipe0.f00001
>>>      850      12 OPEN: pipe5.f00001
>>>      510      12 OPEN: pipe3.f00001
>>>      170      12 OPEN: pipe1.f00001
>>>     1020      12 OPEN: pipe6.f00001
>>>      680      12 OPEN: pipe4.f00001
>>>      340      12 OPEN: pipe2.f00001
>>>        12  1.6226E+02 done :: Write checkpoint
>>>                               file size =     234.E+02MB
>>>           899  Emergency exit:           12    time =    162.2554999999999
>>>           512  Emergency exit:           12    time =    162.2554999999999
>>>           459  Emergency exit:           12    time =    162.2554999999999
>>>   Latest solution and data are dumped for post-processing.
>>>   *** STOP ***
>>>           461  Emergency exit:           12    time =    162.2554999999999
>>>   *** STOP ***
>>>> Geroge,
>>>> Can you provide more details. A logfile would be helpful.
>>>> Cheers,
>>>> Stefan
>>> This message was sent using IMP, the Internet Messaging Program.
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
