[Nek5000-users] Compilation problem due to large LHIS
Mon Jan 9 15:07:02 CST 2012
I guess one way to do this is to recycle my g2gi() code. It's fully parallel.
-Stefan
On 1/9/12, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Yes... looking at the code, I see this needs to be done.
> Fortunately, it is easy to parallelize.
> We'll look into it...
> Paul
> On Mon, 9 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> We are trying to compute the energy spectrum by transforming the fields
>> onto a particular basis set. The geometry is a box of size 5 x 5 x 1 with
>> 157464 elements. The code to transform onto the basis set takes in
>> hpts.out
>> as the input. The size of the transform is 640 x 640 x 128 which
>> gives 52428800. So you're saying that hpts() has to be parallelized?
>> Thanks,
>> Mani
>> On Jan 9, 2012 9:14 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Mani,
>>> Why do you need it so large?
>>> Is it possible you can partition this across your processor set?
>>> Best regards,
>>> Paul
>>> On Mon, 9 Jan 2012,
>>> nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>>  Dear Nek devs,
>>>> I need to put LHIS in the SIZE file to a large number (52428800), but
>>>> with this number I cannot seem to compile despite any amount of
>>>> increasing
>>>> the processors and decreasing LELT. The maximum LP that I tried is 2048
>>>> and
>>>> LELT=77.
>>>> I have attached the compile log and the SIZE file. Could I get around
>>>> this problem somehow?
>>>> Thanks,
>>>> Mani
>>>>  ______________________________**_________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
