[Nek5000-users] run-time hang up in gs_setup
Tue Jan 10 05:02:49 CST 2012
Dear NEKs;
I am trying to run a simulation of a turbulent flow in a straight pipe
in high Reynolds number (Re_tau = 1000). After generating the grid with
PRENEK and extrude it using n2to3, the mesh ended up with 4,495,920
elements. It compiled properly; however, trying to run it, hanged up in
the last stage:
verify mesh topology
   -1.000000000000000         1.000000000000000       Xrange
   -1.000000000000000         1.000000000000000       Yrange
    0.000000000000000         25.00000000000000       Zrange
 done :: verify mesh topology
  E-solver strategy:  1 itr
 mg_nx:            1            3
 mg_ny:            1            3
 mg_nz:            1            3
 call usrsetvert
 done :: usrsetvert
gs_setup: 866937 unique labels shared
   pairwise times (avg, min, max): 0.000241442 0.00019722 0.000265908
   crystal router                : 0.000458177 0.000445795 0.000471807
   used all_to_all method: pairwise
   setupds time 5.6048E-02 seconds   1  2     4565612     4495920
   setvert3d:   4    86046564   122013924    86046564    86046564
 call usrsetvert
 done :: usrsetvert
gs_setup: 8041169 unique labels shared
   pairwise times (avg, min, max): 0.00050716 0.000427103 0.00056479
   crystal router                : 0.0040165 0.00392921 0.00411811
   setupds time 1.0465E+00 seconds   2  4    86046564     4495920
 setup h1 coarse grid, nx_crs=            2
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 0.000233683 0.000197816 0.00024941
   crystal router                : 0.000466869 0.00045588 0.000478101
I was wondering if you could help me with that. I attached the run
logfile and also genmap.out.
Many thanks
Azad
Input (.rea) file name:
PIPE
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
0.1
 reading .rea file data ...
     4495920           3     4495920 F  nelt,ndim,nelv,ifre2
 start locglob_lexico:           8     4495920    35967360  0.10000000
 locglob:           1           1    35967360
 locglob:           2         340    35967360
 locglob:           3        8490    35967360
 locglob:           1     4457250    35967360
 locglob:           2     4574325    35967360
 locglob:           3     4574325    35967360
 locglob:           1     4574325    35967360
 done locglob_lexico:   4574325   4574325  35967360         8
 start periodic vtx:     4495920     4574325
      1000 5  5  3  0.00000000E+00     1000 shift
      2000 5  5  3  1.19209290E-07     2000 shift
      3000 5  5  3  1.19209290E-07     3000 shift
      4000 5  5  3  0.00000000E+00     4000 shift
      5000 5  5  3  0.00000000E+00     5000 shift
      6000 5  5  3  0.00000000E+00     6000 shift
      7000 5  5  3  0.00000000E+00     7000 shift
      8000 5  5  3  5.96046448E-08     8000 shift
   4487760 6  5  3  1.19209290E-07     9000 shift
   4488760 6  5  3  1.19209290E-07    10000 shift
   4489760 6  5  3  0.00000000E+00    11000 shift
   4490760 6  5  3  0.00000000E+00    12000 shift
   4491760 6  5  3  1.49011612E-08    13000 shift
   4492760 6  5  3  2.98023224E-08    14000 shift
   4493760 6  5  3  0.00000000E+00    15000 shift
   4494760 6  5  3  0.00000000E+00    16000 shift
   4495760 6  5  3  1.49011612E-08    17000 shift
 done periodic vtx
 start rec_bisect:     4495920
 done:    0.0%
 not connected           1           2           1           0
 done:    1.0%
 done:    2.0%
 done:    3.0%
 not connected           1           2           2           0
 done:    4.0%
 not connected           1           2           3           0
 done:    5.0%
 done:    6.0%
 done:    7.0%
 not connected           1           2           4           0
 not connected           1           2           5           0
 done:    8.0%
 not connected           1           2           6           0
 done:    9.0%
 done:   10.0%
 done:   11.0%
 done:   12.0%
 done:   13.0%
 done:   14.0%
 not connected           1           2           7           0
 done:   15.0%
 done:   16.0%
 done:   17.0%
 not connected           1           2           8           0
 done:   18.0%
 done:   19.0%
 not connected           1           2           9           0
 done:   20.0%
 not connected           1           2          10           0
 done:   21.0%
 not connected           1           2          11           0
 done:   22.0%
 not connected           1           2          12           0
 not connected           1           2          13           0
 done:   23.0%
 not connected           1           2          14           0
 not connected           1           2          15           0
 done:   24.0%
 not connected           1           2          16           0
 not connected           1           2          17           0
 done:   25.0%
 not connected           1           2          18           0
 not connected           1           2          19           0
 not connected           1           2          20           0
 not connected           1           2          21           0
 done:   26.0%
 not connected           1           2          22           0
 not connected           1           2          23           0
 done:   27.0%
 done:   28.0%
 not connected           1           2          24           0
 done:   29.0%
 done:   30.0%
 not connected           1           2          25           0
 done:   31.0%
 done:   32.0%
 not connected           1           2          26           0
 done:   33.0%
 done:   34.0%
 not connected           1           2          27           0
 done:   35.0%
 done:   36.0%
 done:   37.0%
 not connected           1           2          28           0
 done:   38.0%
 done:   39.0%
 done:   40.0%
 done:   41.0%
 not connected           1           2          29           0
 done:   42.0%
 done:   43.0%
 not connected           1           2          30           0
 done:   44.0%
 not connected           1           2          31           0
 done:   45.0%
 done:   46.0%
 not connected           1           2          32           0
 not connected           1           2          33           0
 done:   47.0%
 not connected           1           2          34           0
 done:   48.0%
 done:   49.0%
 not connected           1           2          35           0
 not connected           1           2          36           0
 done:   50.0%
 not connected           1           2          37           0
 done:   51.0%
 not connected           1           2          38           0
 done:   52.0%
 not connected           1           2          39           0
 done:   53.0%
 done:   54.0%
 done:   55.0%
 done:   56.0%
 done:   57.0%
 done:   58.0%
 not connected           1           2          40           0
 done:   59.0%
 not connected           1           2          41           0
 done:   60.0%
 not connected           1           2          42           0
 not connected           1           2          43           0
 done:   61.0%
 not connected           1           2          44           0
 done:   62.0%
 not connected           1           2          45           0
 not connected           1           2          46           0
 done:   63.0%
 done:   64.0%
 done:   65.0%
 done:   66.0%
 not connected           1           2          47           0
 not connected           1           2          48           0
 done:   67.0%
 done:   68.0%
 done:   69.0%
 done:   70.0%
 not connected           1           2          49           0
 done:   71.0%
 not connected           1           2          50           0
 done:   72.0%
 not connected           1           2          51           0
 done:   73.0%
 done:   74.0%
 not connected           1           2          52           0
 done:   75.0%
 not connected           1           2          53           0
 not connected           1           2          54           0
 done:   76.0%
 done:   77.0%
 done:   78.0%
 not connected           1           2          55           0
 done:   79.0%
 not connected           1           2          56           0
 not connected           1           2          57           0
 done:   80.0%
 not connected           1           2          58           0
 done:   81.0%
 done:   82.0%
 not connected           1           2          59           0
 done:   83.0%
 done:   84.0%
 not connected           1           2          60           0
 done:   85.0%
 not connected           1           2          61           0
 not connected           1           2          62           0
 done:   86.0%
 not connected           1           2          63           0
 done:   87.0%
 done:   88.0%
 done:   89.0%
 done:   90.0%
 done:   91.0%
 done:   92.0%
 not connected           1           2          64           0
 done:   93.0%
 not connected           1           2          65           0
 done:   94.0%
 done:   95.0%
 done:   96.0%
 done:   97.0%
 done:   98.0%
 done:   99.0%
 done:  100.0%
 done rec_bisect
writing PIPE.map
PE 0: MPICH/GNI environment settings:
PE 0:           MPICH_GNI_RECV_CQ_SIZE = 40960
PE 0:          MPICH_GNI_LOCAL_CQ_SIZE = 8192
PE 0:            MPICH_GNI_DEBUG_LEVEL = 0
PE 0:    MPICH_GNI_MAX_VSHORT_MSG_SIZE = 464
PE 0:     MPICH_GNI_MAX_EAGER_MSG_SIZE = 8192
PE 0:               MPICH_GNI_NUM_BUFS = 64
PE 0:             MPICH_GNI_NUM_MBOXES = -1
PE 0:         MPICH_GNI_RDMA_THRESHOLD = 1024
PE 0:          MPICH_GNI_RCVCQ_PROCNUM = 1
PE 0:    MPICH_GNI_NDREG_ENTRIES(req.) = 151
PE 0:          MPICH_GNI_NDREG_MAXSIZE = 524288
PE 0:          MPICH_GNI_NDREG_LAZYMEM = LAZY_ALL
PE 0:          MPICH_GNI_DMAPP_INTEROP = 1
PE 0:           MPICH_GNI_DYNAMIC_CONN = 1
PE 0:        MPICH_GNI_MAX_NUM_RETRIES = 16
PE 0:              MPICH_GNI_FORK_MODE = PARTCOPY
PE 0:         MPICH_GNI_MBOX_PLACEMENT = PROC
PE 0:        MPICH_GNI_VC_MSG_PROTOCOL = MBOX
PE 0:      MPICH_GNI_BTE_MULTI_CHANNEL = 1
PE 0:           MPICH_GNI_LMT_GET_PATH = 1
PE 0:               MPICH_GNI_LMT_PATH = 1
|      _   __ ______ __ __  ______  ____   ____   ____     |
|     / | / // ____// //_/ / ____/ / __ \ / __ \ / __ \    |
|    /  |/ // __/  / ,<   /___ \  / / / // / / // / / /    |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \____/ \____/ \____/      |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
| Version:  1.0rc1 / SVN r618                              |
| Web:      http://nek5000.mcs.anl.gov                     |
 Number of processors:         4096
 REAL    wdsize      :            8
 INTEGER wdsize      :            4
  Beginning session:
  /cfs/klemming/nobackup/a/anoorani/pipe/Retau1000/new/pipe.rea
 timer accuracy:   0.0000000E+00 sec
 read .rea file
 read .re2 file
 byte swap:  F    6.543210      -2.9312772E+35
 nelgt/nelgv/lelt:  4495920  4495920     1100
 lx1  /lx2  /lx3 :        4        2        2
 mapping elements to processors
 element load imbalance:             1         1097         1098
 done :: mapping elements to processors
   reading mesh
   reading curved sides
   reading bc for ifld            1
 done :: read .re2 file
            0  objects found
 done :: read .rea file    114.58     sec
 setup mesh topology
   Right-handed check complete for 4495920 elements. OK.
 call usrsetvert
 done :: usrsetvert
gs_setup: 13275258 unique labels shared
   pairwise times (avg, min, max): 0.000561914 0.000431108 0.000673413
   crystal router                : 0.00190646 0.00186119 0.00197728
   setupds time 3.6859E-01 seconds   0  4    86046564     4495920
            8  max multiplicity
 done :: setup mesh topology
 call usrdat
 done :: usrdat
 generate geomerty data
 vol_t,vol_v:    78.53235632719681         78.53235632719681
 done :: generate geomerty data
 call usrdat2
 done :: usrdat2
 regenerate geomerty data            1
 done :: regenerate geomerty data            1
 118   Parameters from file:/cfs/klemming/nobackup/a/anoorani/pipe/Retau1000/new/pipe.rea
   1      1.00000     P001: DENSITY
   2     -18850.     P002: VISCOS
   7      1.00000     P007: RHOCP
   8      1.00000     P008: CONDUCT
  11      100.0     P011: NSTEPS
  12    -1.0000E-05 P012: DT
  15      50.0000     P015: IOSTEP
  17      1.00000     P017:
  18     0.500000E-01 P018: GRID < 0 --> # cells on screen
  19     -1.00000     P019: INTYPE
  20      10.0000     P020: NORDER
  21     0.100000E-05 P021: DIVERGENCE
  22     0.100000E-06 P022: HELMHOLTZ
  24     0.100000E-01 P024: TOLREL
  25     0.100000E-01 P025: TOLABS
  26      1.00000     P026: COURANT/NTAU
  27      3.00000     P027: TORDER
  28      0.00000     P028: TORDER: mesh velocity (0: p28=p27)
  54      -3.00000     P054: fixed flow rate dir: |p54|=1,2,3=x,y,z
  55      1.00000     P055: vol.flow rate (p54>0) or Ubar (p54<0)
  65      1.00000     P065: #iofiles (eg, 0 or 64); <0 --> sep. dirs
  66      4.00000     P066: output : <0=ascii, else binary
  67      4.00000     P067: restart: <0=ascii, else binary
  69      50000.0     P069: : :     frequency of srf dump
  93      20.0000     P093: Number of previous pressure solns saved
  94      3.00000     P094: start projecting velocity after p94 step
  95      5.00000     P095: start projecting pressure after p95 step
  99      3.00000     P099: dealiasing: <0--> off/3--> old/4--> new
 102      1.00000     P102: Dump out divergence at each time step
 103     0.050000     P103: weight of stabilizing filter (.01)
 IFTRAN   =  T
 IFFLOW   =  T
 IFHEAT   =  F
 IFSPLIT  =  F
 IFLOMACH =  F
 IFUSERVP =  F
 IFUSERMV =  F
 IFSTRS   =  F
 IFCHAR   =  T
 IFCYCLIC =  F
 IFAXIS   =  F
 IFMVBD   =  F
 IFMELT   =  F
 IFMODEL  =  F
 IFKEPS   =  F
 IFMOAB   =  F
 IFSYNC   =  T
 IFVCOR   =  T
 IFINTQ   =  F
 IFCWUZ   =  F
 IFSWALL  =  F
 IFGEOM   =  F
 IFSURT   =  F
 IFWCNO   =  F
 IFTMSH for field            1    =   F
 IFADVC for field            1    =   T
 IFNONL for field            1    =   F
 Dealiasing enabled, lxd=            6
 Estimated eigenvalues
 EIGAA =     1.650197855862141
 EIGGA =     12385388.91135105
 EIGAE =    1.5791367041742974E-002
 EIGAS =    7.9744816586921851E-004
 EIGGE =     12385388.91135105
 EIGGS =     2.000000000000000
 mg_nx:            1            3
 mg_ny:            1            3
 mg_nz:            1            3
 call usrsetvert
 done :: usrsetvert
gs_setup: 1393086 unique labels shared
   pairwise times (avg, min, max): 0.000286875 0.000198293 0.000347185
   crystal router                : 0.000353284 0.000346708 0.000362897
   setupds time 3.3200E-02 seconds   1  2     4565612     4495920
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 0.000565474 0.000431323 0.000666308
   crystal router                : 0.00192211 0.00188022 0.00198519
   setupds time 3.6968E-01 seconds   2  4    86046564     4495920
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 0.00027245 0.000212216 0.000325584
   crystal router                : 0.000303 0.000294399 0.000315809
   used all_to_all method: crystal router
   pairwise times (avg, min, max): 0.000276989 0.000202703 0.000333595
   crystal router                : 0.000296147 0.000291204 0.000304508
Application 727540 exit codes: 143
Application 727540 resources: utime ~406010s, stime ~1268s
