[Nek5000-users] Compilation problem due to large LHIS
Mon Jan 9 11:50:48 CST 2012
Yes... looking at the code, I see this needs to be done.
Fortunately, it is easy to parallelize.
We'll look into it...
Paul
On Mon, 9 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> We are trying to compute the energy spectrum by transforming the fields
> onto a particular basis set. The geometry is a box of size 5 x 5 x 1 with
> 157464 elements. The code to transform onto the basis set takes in hpts.out
> as the input. The size of the transform is 640 x 640 x 128 which
> gives 52428800. So you're saying that hpts() has to be parallelized?
> Thanks,
> Mani
> On Jan 9, 2012 9:14 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Mani,
>> Why do you need it so large?
>> Is it possible you can partition this across your processor set?
>> Best regards,
>> Paul
>> On Mon, 9 Jan 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>  Dear Nek devs,
>>> I need to put LHIS in the SIZE file to a large number (52428800), but
>>> with this number I cannot seem to compile despite any amount of increasing
>>> the processors and decreasing LELT. The maximum LP that I tried is 2048 and
>>> LELT=77.
>>> I have attached the compile log and the SIZE file. Could I get around
>>> this problem somehow?
>>> Thanks,
>>> Mani
>>>  ______________________________**_________________
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
