[Nek5000-users] Compilation problem due to large LHIS
Mon Jan 9 11:41:24 CST 2012
Hi Paul,
We are trying to compute the energy spectrum by transforming the fields
onto a particular basis set. The geometry is a box of size 5 x 5 x 1 with
157464 elements. The code to transform onto the basis set takes in hpts.out
as the input. The size of the transform is 640 x 640 x 128 which
gives 52428800. So you're saying that hpts() has to be parallelized?
Mani
On Jan 9, 2012 9:14 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Mani,
> Why do you need it so large?
> Is it possible you can partition this across your processor set?
> Best regards,
> Paul
> On Mon, 9 Jan 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>  Dear Nek devs,
>> I need to put LHIS in the SIZE file to a large number (52428800), but
>> with this number I cannot seem to compile despite any amount of increasing
>> the processors and decreasing LELT. The maximum LP that I tried is 2048 and
>> LELT=77.
>> I have attached the compile log and the SIZE file. Could I get around
>> this problem somehow?
>> Thanks,
>> Mani
>>  ______________________________**_________________
> Nek5000-users mailing list
> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120109/13788a24/attachment.html>
