[Nek5000-users] Nek5000-users Digest, Vol 35, Issue 21
Wed Feb 1 11:04:09 CST 2012
Oliver,
We currently do not support the Cray compiler but we will work on it
to make it happen. Need to check if I can get access to a Cray
machine. In the meantime please use the PGI compiler on your Cray
system. Variations in performance are typically low (around 10%)
considering different compilers. At least for Nek5000 :)
Cheers,
Stefan
On 2/1/12, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Stefan and Paul,
> Thank you for your replies.
> The code compiles nicely and the same case runs when I compile with PGI
> (for some reason that wasn't the case with the older Nek version I used
> before; it compiled but gave segmentation faults before creating any
> other output). Cray people told me however that I should use crayftn for
> better performance, at least for large cases. Any thoughts?
> Oliver
>> Send Nek5000-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>> 	https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> or, via email, send a message with subject or body 'help' to
>> 	nek5000-users-request at lists.mcs.anl.gov
>> You can reach the person managing the list at
>> 	nek5000-users-owner at lists.mcs.anl.gov
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Nek5000-users digest..."
>> Today's Topics:
>>     1. Re: Running NEK on CRAY;	compilation&  running issues
>>        (nek5000-users at lists.mcs.anl.gov)
>>     2. Re: Running NEK on CRAY; compilation&  running issues
>> Message: 1
>> Date: Mon, 30 Jan 2012 19:02:23 +0100
>> From: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Running NEK on CRAY;	compilation&
>> 	running issues
>> To: nek5000-users at lists.mcs.anl.gov
>> Message-ID:
>> 	<CAGTrLsZ-p2_gud4exm5eTPBcKhM0tUM3OxBQO0Bed_xRCRhaLw at mail.gmail.com>
>> Content-Type: text/plain; charset=windows-1252
>> Hi Oliver,
>> Can you try to use the PGI compiler instead of the Cray. Just want to
>> check if this is a compiler specific issue.
>> Cheers,
>> Stefan
>> On 1/30/12, nek5000-users at lists.mcs.anl.gov
>>> Oliver,
>>> Thanks for your comments.  We'll certainly take care of the
>>> multd() and gsync() issues.
>>> We have what I believe is an xe6 on site and several users
>>> are using it regularly.   They may have some comments about
>>> the flags, etc. and the issues that you are running into.
>>> Hopefully, someone will get back to you early today.
>>> Regards,
>>> Paul
>>> On Mon, 30 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Dear NEKs,
>>>> I'm currently trying to compile NEK via crayftn to run on a XE6 and I
>>>> run into some issues. Some compilation problems I solved (with kind help
>>>> of CRAY personnel). I'll mention them here as they can be part of the
>>>> problem, I assume.
>>>> 1) changed
>>>> *ftn*) P="-r8 -Mpreprocess
>>>> to *ftn*) P="-s real64 -eZ -em"
>>>> for double precision reals and to invoke preprocessor in makenek.inc
>>>> (Cray uses ftn command as a wrapper)
>>>> 2) changed subroutine name ?gsync? to ?gsync_nek? in all source files
>>>> as
>>>> crayftn has a build-in routine of the same name that conflicts with
>>>> Nek's gsync
>>>> 3) changed calls to subroutine ?multd? from
>>>> CALL MULTD (TA1,TVX,RXM2,SXM2,TXM2,1)
>>>> to CALL MULTD (TA1,TVX,RXM2,SXM2,TXM2,1,0)
>>>> in ?navier1.f? as crayftn complains about missing seventh argument
>>>> ?iflg? (calls come from subroutine ?tmultd? which seems not to be
>>>> called
>>>> in the code, though)
>>>> In the SIZE file I'm setting lelt=300, lelv=lelt, lp = 64, lelg = 300.
>>>> With these changes I'm running the eddy_uv example via ?aprun -n 64 -N
>>>> 32 ./nek5000? on 64 processors and I'm getting the following output:
>>>> | _ __ ______ __ __ ______ ____ ____ ____ |
>>>> | / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
>>>> | / |/ // __/ / ,<  /___ \\ / / / // / / // / / / |
>>>> | / /| // /___ / /| | ____/ / / /_/ // /_/ // /_/ / |
>>>> | /_/ |_//_____//_/ |_|/_____/ \\____/ \\____/ \\____/ |
>>>> | NEK5000: Open Source Spectral Element Solver |
>>>> | COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC |
>>>> | Version: 1.0rc1 / SVN r730 |
>>>> | Web: http://nek5000.mcs.anl.gov |
>>>> Number of processors: 64
>>>> REAL wdsize : 8
>>>> INTEGER wdsize : 4
>>>> Beginning session:
>>>> /zhome/academic/HLRS/iag/iagoschm/run_nek/eddy_example/eddy_uv.rea
>>>> timer accuracy: 2.8610229E-07 sec
>>>> read .rea file
>>>> nelgt/nelgv/lelt: 256 256 300
>>>> lx1 /lx2 /lx3 : 8 6 8
>>>> mapping elements to processors
>>>> 0, 2*4, 2*256 NELV
>>>> 1, 2*4, 2*256 NELV
>>>> 8, 2*4, 2*256 NELV
>>>> 9, 2*4, 2*256 NELV
>>>> 17, 2*4, 2*256 NELV
>>>> 16, 2*4, 2*256 NELV
>>>> 20, 2*4, 2*256 NELV
>>>> 3*4, 2*256 NELV
>>>> 29, 2*4, 2*256 NELV
>>>> 21, 2*4, 2*256 NELV
>>>> 28, 2*4, 2*256 NELV
>>>> 7, 2*4, 2*256 NELV
>>>> 31, 2*4, 2*256 NELV
>>>> 25, 2*4, 2*256 NELV
>>>> 11, 2*4, 2*256 NELV
>>>> 12, 2*4, 2*256 NELV
>>>> 6, 2*4, 2*256 NELV
>>>> 30, 2*4, 2*256 NELV
>>>> 18, 2*4, 2*256 NELV
>>>> 19, 2*4, 2*256 NELV
>>>> 2, 2*4, 2*256 NELV
>>>> 5, 2*4, 2*256 NELV
>>>> 23, 2*4, 2*256 NELV
>>>> 27, 2*4, 2*256 NELV
>>>> 10, 2*4, 2*256 NELV
>>>> 22, 2*4, 2*256 NELV
>>>> 13, 2*4, 2*256 NELV
>>>> 14, 2*4, 2*256 NELV
>>>> 15, 2*4, 2*256 NELV
>>>> 3, 2*4, 2*256 NELV
>>>> 26, 2*4, 2*256 NELV
>>>> 24, 2*4, 2*256 NELV
>>>> 33, 2*4, 2*256 NELV
>>>> 41, 2*4, 2*256 NELV
>>>> 32, 2*4, 2*256 NELV
>>>> 40, 2*4, 2*256 NELV
>>>> 45, 2*4, 2*256 NELV
>>>> 44, 2*4, 2*256 NELV
>>>> 49, 2*4, 2*256 NELV
>>>> 34, 2*4, 2*256 NELV
>>>> 35, 2*4, 2*256 NELV
>>>> 48, 2*4, 2*256 NELV
>>>> 39, 2*4, 2*256 NELV
>>>> 38, 2*4, 2*256 NELV
>>>> 50, 2*4, 2*256 NELV
>>>> 51, 2*4, 2*256 NELV
>>>> 37, 2*4, 2*256 NELV
>>>> 36, 2*4, 2*256 NELV
>>>> 55, 2*4, 2*256 NELV
>>>> 54, 2*4, 2*256 NELV
>>>> 57, 2*4, 2*256 NELV
>>>> 58, 2*4, 2*256 NELV
>>>> 43, 2*4, 2*256 NELV
>>>> 42, 2*4, 2*256 NELV
>>>> 47, 2*4, 2*256 NELV
>>>> 53, 2*4, 2*256 NELV
>>>> 59, 2*4, 2*256 NELV
>>>> 46, 2*4, 2*256 NELV
>>>> 60, 2*4, 2*256 NELV
>>>> 61, 2*4, 2*256 NELV
>>>> 63, 2*4, 2*256 NELV
>>>> 62, 2*4, 2*256 NELV
>>>> 52, 2*4, 2*256 NELV
>>>> 56, 2*4, 2*256 NELV
>>>> 25, 0, 2*4, 256 NELT FAIL
>>>> 24, 0, 2*4, 256 NELT FAIL
>>>> 21, 0, 2*4, 256 NELT FAIL
>>>> Check that .map file and .rea file agree
>>>> 20, 0, 2*4, 256 NELT FAIL
>>>> 31, 0, 2*4, 256 NELT FAIL
>>>> 8, 0, 2*4, 256 NELT FAIL
>>>> 17, 0, 2*4, 256 NELT FAIL
>>>> 14, 0, 2*4, 256 NELT FAIL
>>>> 15, 0, 2*4, 256 NELT FAIL
>>>> 16, 0, 2*4, 256 NELT FAIL
>>>> 26, 0, 2*4, 256 NELT FAIL
>>>> 10, 0, 2*4, 256 NELT FAIL
>>>> 2, 0, 2*4, 256 NELT FAIL
>>>> 30, 0, 2*4, 256 NELT FAIL
>>>> 11, 0, 2*4, 256 NELT FAIL
>>>> 2*0, 2*4, 256 NELT FAIL
>>>> 13, 0, 2*4, 256 NELT FAIL
>>>> 12, 0, 2*4, 256 NELT FAIL
>>>> 28, 0, 2*4, 256 NELT FAIL
>>>> 18, 0, 2*4, 256 NELT FAIL
>>>> 29, 0, 2*4, 256 NELT FAIL
>>>> 23, 0, 2*4, 256 NELT FAIL
>>>> 27, 0, 2*4, 256 NELT FAIL
>>>> 19, 0, 2*4, 256 NELT FAIL
>>>> 22, 0, 2*4, 256 NELT FAIL
>>>> 2*0, 2*4, 256 NELT FB
>>>> 1, 0, 2*4, 256 NELT FB
>>>> 2, 0, 2*4, 256 NELT FB
>>>> 3, 0, 2*4, 256 NELT FB
>>>> 4, 0, 2*4, 256 NELT FB
>>>> 5, 0, 2*4, 256 NELT FB
>>>> 6, 0, 2*4, 256 NELT FB
>>>> 7, 0, 2*4, 256 NELT FB
>>>> 8, 0, 2*4, 256 NELT FB
>>>> 9, 3*4, 256 NELT FB
>>>> 10, 0, 2*4, 256 NELT FB
>>>> 11, 0, 2*4, 256 NELT FB
>>>> 12, 0, 2*4, 256 NELT FB
>>>> 13, 0, 2*4, 256 NELT FB
>>>> 14, 0, 2*4, 256 NELT FB
>>>> 15, 0, 2*4, 256 NELT FB
>>>> 16, 0, 2*4, 256 NELT FB
>>>> 17, 0, 2*4, 256 NELT FB
>>>> 18, 0, 2*4, 256 NELT FB
>>>> 19, 0, 2*4, 256 NELT FB
>>>> 20, 0, 2*4, 256 NELT FB
>>>> 21, 0, 2*4, 256 NELT FB
>>>> 22, 0, 2*4, 256 NELT FB
>>>> 23, 0, 2*4, 256 NELT FB
>>>> 24, 0, 2*4, 256 NELT FB
>>>> 25, 0, 2*4, 256 NELT FB
>>>> 26, 0, 2*4, 256 NELT FB
>>>> 27, 0, 2*4, 256 NELT FB
>>>> 28, 0, 2*4, 256 NELT FB
>>>> 29, 0, 2*4, 256 NELT FB
>>>> 30, 0, 2*4, 256 NELT FB
>>>> 31, 0, 2*4, 256 NELT FB
>>>> call exitt: dying ...
>>>> backtrace(): obtained 1 stack frames.
>>>> [0x662a40]
>>>> total elapsed time : 7.82199E-02 sec
>>>> total solver time incl. I/O : 0.00000E+00 sec
>>>> time/timestep : 0.00000E+00 sec
>>>> CPU seconds/timestep/gridpt : 0.00000E+00 sec
>>>> 39, 0, 2*4, 256 NELT FAIL
>>>> 38, 0, 2*4, 256 NELT FAIL
>>>> 36, 0, 2*4, 256 NELT FAIL
>>>> 41, 0, 2*4, 256 NELT FAIL
>>>> 32, 0, 2*4, 256 NELT FAIL
>>>> 48, 0, 2*4, 256 NELT FAIL
>>>> 34, 0, 2*4, 256 NELT FAIL
>>>> 54, 196, 2*4, 256 NELT FAIL
>>>> 40, 0, 2*4, 256 NELT FAIL
>>>> 46, 0, 2*4, 256 NELT FAIL
>>>> 47, 0, 2*4, 256 NELT FAIL
>>>> 33, 0, 2*4, 256 NELT FAIL
>>>> 37, 0, 2*4, 256 NELT FAIL
>>>> 35, 0, 2*4, 256 NELT FAIL
>>>> 43, 0, 2*4, 256 NELT FAIL
>>>> 45, 0, 2*4, 256 NELT FAIL
>>>> 42, 0, 2*4, 256 NELT FAIL
>>>> 44, 0, 2*4, 256 NELT FAIL
>>>> 32, 0, 2*4, 256 NELT FB
>>>> 33, 0, 2*4, 256 NELT FB
>>>> 34, 0, 2*4, 256 NELT FB
>>>> 35, 0, 2*4, 256 NELT FB
>>>> 36, 0, 2*4, 256 NELT FB
>>>> 37, 0, 2*4, 256 NELT FB
>>>> 38, 0, 2*4, 256 NELT FB
>>>> 39, 0, 2*4, 256 NELT FB
>>>> 40, 0, 2*4, 256 NELT FB
>>>> 41, 0, 2*4, 256 NELT FB
>>>> 42, 0, 2*4, 256 NELT FB
>>>> 43, 0, 2*4, 256 NELT FB
>>>> 44, 0, 2*4, 256 NELT FB
>>>> 45, 0, 2*4, 256 NELT FB
>>>> 46, 0, 2*4, 256 NELT FB
>>>> 47, 0, 2*4, 256 NELT FB
>>>> 48, 0, 2*4, 256 NELT FB
>>>> 49, 3*4, 256 NELT FB
>>>> 50, 3*4, 256 NELT FB
>>>> 51, 3*4, 256 NELT FB
>>>> 52, 3*4, 256 NELT FB
>>>> 53, 3*4, 256 NELT FB
>>>> 54, 196, 2*4, 256 NELT FB
>>>> 55, 3*4, 256 NELT FB
>>>> 56, 3*4, 256 NELT FB
>>>> 57, 3*4, 256 NELT FB
>>>> 58, 3*4, 256 NELT FB
>>>> 59, 3*4, 256 NELT FB
>>>> 60, 3*4, 256 NELT FB
>>>> 61, 3*4, 256 NELT FB
>>>> 62, 3*4, 256 NELT FB
>>>> 63, 3*4, 256 NELT FB
>>>> Application 419539 resources: utime ~8s, stime ~13s
>>>> Does the code map in parallel here? I'm not sure what's happening here,
>>>> because the .map and .rea file do in fact agree. The error seems to
>>>> occur when processor #25 is mapped for a second time. The same thing
>>>> happens with my own cases that were running on a similar machine before
>>>> but with Nek compiled with PGI.
>>>> Any help would be greatly appreciated
>>>> Oliver
>>>> _______________________________________________
>>>> Nek5000-users at lists.mcs.anl.gov
>> Message: 2
>> Date: Mon, 30 Jan 2012 13:43:50 -0600 (CST)
>> 	running issues
>> Message-ID:
>> 	<304748520.192593.1327952630495.JavaMail.root at zimbra.anl.gov>
>> Content-Type: text/plain; charset=utf-8
>> Hi Oliver,
>> I have been using Cray xe6/xt6 successfully with PGI compilers specified
>> in makenek with
>> # Fortran compiler
>> F77="ftn"
>> # C compiler
>> CC="cc"
>> and the submission script I use is below.
>> Best.
>> Aleks
>> rm *batch*
>> echo $1>   SESSION.NAME
>> echo `pwd`'/'>>   SESSION.NAME
>> touch $1.rea
>> rm -f ioinfo
>> mv -f $1.log.$2 $1.log1.$2
>> mv -f $1.his $1.his1
>> mv -f $1.sch $1.sch1
>> rm -f logfile
>> echo ''>  $1.log.$2
>> echo   "#!/bin/bash">   $1.batch
>> echo   "#PBS -l mppwidth="$2>>  $1.batch
>> echo   "#PBS -l walltime="$3":"$4":00">>  $1.batch
>> echo   "#PBS -j oe">>  $1.batch
>> echo   cd `pwd`>>  $1.batch
>> echo   aprun -n $2 ./nek5000 ">>" $1.log.$2>>  $1.batch
>> echo   "exit 0;">>  $1.batch
>> qsub -q batch $1.batch
>> sleep 3
>> ln $1.log.$2 logfile
>> ## usage: neke case cores hours minutes
>> ----- Original Message -----
>> Sent: Monday, January 30, 2012 12:02:23 PM
>> Subject: Re: [Nek5000-users] Running NEK on CRAY;	compilation&  running
>> issues
>> Hi Oliver,
>> Cheers,
>> Stefan
>>> Oliver,
>>> Regards,
>>> Paul
>>>> Dear NEKs,
>>>> problem, I assume.
>>>> 1) changed
>>>> as
>>>> Nek's gsync
>>>> called
>>>> REAL wdsize : 8
>>>> INTEGER wdsize : 4
>>>> Beginning session:
>>>> read .rea file
>>>> 0, 2*4, 2*256 NELV
>>>> 1, 2*4, 2*256 NELV
>>>> 8, 2*4, 2*256 NELV
>>>> 9, 2*4, 2*256 NELV
>>>> 17, 2*4, 2*256 NELV
>>>> 16, 2*4, 2*256 NELV
>>>> 20, 2*4, 2*256 NELV
>>>> 3*4, 2*256 NELV
>>>> 29, 2*4, 2*256 NELV
>>>> 21, 2*4, 2*256 NELV
>>>> 28, 2*4, 2*256 NELV
>>>> 7, 2*4, 2*256 NELV
>>>> 31, 2*4, 2*256 NELV
>>>> 25, 2*4, 2*256 NELV
>>>> 11, 2*4, 2*256 NELV
>>>> 12, 2*4, 2*256 NELV
>>>> 6, 2*4, 2*256 NELV
>>>> 30, 2*4, 2*256 NELV
>>>> 18, 2*4, 2*256 NELV
>>>> 19, 2*4, 2*256 NELV
>>>> 2, 2*4, 2*256 NELV
>>>> 5, 2*4, 2*256 NELV
>>>> 23, 2*4, 2*256 NELV
>>>> 27, 2*4, 2*256 NELV
>>>> 10, 2*4, 2*256 NELV
>>>> 22, 2*4, 2*256 NELV
>>>> 13, 2*4, 2*256 NELV
>>>> 14, 2*4, 2*256 NELV
>>>> 15, 2*4, 2*256 NELV
>>>> 3, 2*4, 2*256 NELV
>>>> 26, 2*4, 2*256 NELV
>>>> 24, 2*4, 2*256 NELV
>>>> 33, 2*4, 2*256 NELV
>>>> 41, 2*4, 2*256 NELV
>>>> 32, 2*4, 2*256 NELV
>>>> 40, 2*4, 2*256 NELV
>>>> 45, 2*4, 2*256 NELV
>>>> 44, 2*4, 2*256 NELV
>>>> 49, 2*4, 2*256 NELV
>>>> 34, 2*4, 2*256 NELV
>>>> 35, 2*4, 2*256 NELV
>>>> 48, 2*4, 2*256 NELV
>>>> 39, 2*4, 2*256 NELV
>>>> 38, 2*4, 2*256 NELV
>>>> 50, 2*4, 2*256 NELV
>>>> 51, 2*4, 2*256 NELV
>>>> 37, 2*4, 2*256 NELV
>>>> 36, 2*4, 2*256 NELV
>>>> 55, 2*4, 2*256 NELV
>>>> 54, 2*4, 2*256 NELV
>>>> 57, 2*4, 2*256 NELV
>>>> 58, 2*4, 2*256 NELV
>>>> 43, 2*4, 2*256 NELV
>>>> 42, 2*4, 2*256 NELV
>>>> 47, 2*4, 2*256 NELV
>>>> 53, 2*4, 2*256 NELV
>>>> 59, 2*4, 2*256 NELV
>>>> 46, 2*4, 2*256 NELV
>>>> 60, 2*4, 2*256 NELV
>>>> 61, 2*4, 2*256 NELV
>>>> 63, 2*4, 2*256 NELV
>>>> 62, 2*4, 2*256 NELV
>>>> 52, 2*4, 2*256 NELV
>>>> 56, 2*4, 2*256 NELV
>>>> 9, 3*4, 256 NELT FB
>>>> [0x662a40]
>>>> Oliver
>> End of Nek5000-users Digest, Vol 35, Issue 21
