[Nek5000-users] Nek5000-users Digest, Vol 35, Issue 21
Wed Feb 1 03:06:40 CST 2012
Dear Stefan and Paul,
Thank you for your replies.
The code compiles nicely and the same case runs when I compile with PGI
(for some reason that wasn't the case with the older Nek version I used
before; it compiled but gave segmentation faults before creating any
other output). Cray people told me however that I should use crayftn for
better performance, at least for large cases. Any thoughts?
Oliver
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> 	nek5000-users-request at lists.mcs.anl.gov
> You can reach the person managing the list at
> 	nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>     1. Re: Running NEK on CRAY;	compilation&  running issues
>        (nek5000-users at lists.mcs.anl.gov)
>     2. Re: Running NEK on CRAY; compilation&  running issues
> Message: 1
> Date: Mon, 30 Jan 2012 19:02:23 +0100
> From: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Running NEK on CRAY;	compilation&
> 	running issues
> To: nek5000-users at lists.mcs.anl.gov
> Message-ID:
> 	<CAGTrLsZ-p2_gud4exm5eTPBcKhM0tUM3OxBQO0Bed_xRCRhaLw at mail.gmail.com>
> Content-Type: text/plain; charset=windows-1252
> Hi Oliver,
> Can you try to use the PGI compiler instead of the Cray. Just want to
> check if this is a compiler specific issue.
> Cheers,
> Stefan
> On 1/30/12, nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov>  wrote:
>> Oliver,
>> Thanks for your comments.  We'll certainly take care of the
>> multd() and gsync() issues.
>> We have what I believe is an xe6 on site and several users
>> are using it regularly.   They may have some comments about
>> the flags, etc. and the issues that you are running into.
>> Hopefully, someone will get back to you early today.
>> Regards,
>> Paul
>> On Mon, 30 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>> Dear NEKs,
>>> I'm currently trying to compile NEK via crayftn to run on a XE6 and I
>>> run into some issues. Some compilation problems I solved (with kind help
>>> of CRAY personnel). I'll mention them here as they can be part of the
>>> problem, I assume.
>>> 1) changed
>>> *ftn*) P="-r8 -Mpreprocess
>>> to *ftn*) P="-s real64 -eZ -em"
>>> for double precision reals and to invoke preprocessor in makenek.inc
>>> (Cray uses ftn command as a wrapper)
>>> 2) changed subroutine name ?gsync? to ?gsync_nek? in all source files
>>> as
>>> crayftn has a build-in routine of the same name that conflicts with
>>> Nek's gsync
>>> 3) changed calls to subroutine ?multd? from
>>> CALL MULTD (TA1,TVX,RXM2,SXM2,TXM2,1)
>>> to CALL MULTD (TA1,TVX,RXM2,SXM2,TXM2,1,0)
>>> in ?navier1.f? as crayftn complains about missing seventh argument
>>> ?iflg? (calls come from subroutine ?tmultd? which seems not to be
>>> called
>>> in the code, though)
>>> In the SIZE file I'm setting lelt=300, lelv=lelt, lp = 64, lelg = 300.
>>> With these changes I'm running the eddy_uv example via ?aprun -n 64 -N
>>> 32 ./nek5000? on 64 processors and I'm getting the following output:
>>> | _ __ ______ __ __ ______ ____ ____ ____ |
>>> | / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
>>> | / |/ // __/ / ,<  /___ \\ / / / // / / // / / / |
>>> | / /| // /___ / /| | ____/ / / /_/ // /_/ // /_/ / |
>>> | /_/ |_//_____//_/ |_|/_____/ \\____/ \\____/ \\____/ |
>>> | NEK5000: Open Source Spectral Element Solver |
>>> | COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC |
>>> | Version: 1.0rc1 / SVN r730 |
>>> | Web: http://nek5000.mcs.anl.gov |
>>> Number of processors: 64
>>> REAL wdsize : 8
>>> INTEGER wdsize : 4
>>> Beginning session:
>>> /zhome/academic/HLRS/iag/iagoschm/run_nek/eddy_example/eddy_uv.rea
>>> timer accuracy: 2.8610229E-07 sec
>>> read .rea file
>>> nelgt/nelgv/lelt: 256 256 300
>>> lx1 /lx2 /lx3 : 8 6 8
>>> mapping elements to processors
>>> 0, 2*4, 2*256 NELV
>>> 1, 2*4, 2*256 NELV
>>> 8, 2*4, 2*256 NELV
>>> 9, 2*4, 2*256 NELV
>>> 17, 2*4, 2*256 NELV
>>> 16, 2*4, 2*256 NELV
>>> 20, 2*4, 2*256 NELV
>>> 3*4, 2*256 NELV
>>> 29, 2*4, 2*256 NELV
>>> 21, 2*4, 2*256 NELV
>>> 28, 2*4, 2*256 NELV
>>> 7, 2*4, 2*256 NELV
>>> 31, 2*4, 2*256 NELV
>>> 25, 2*4, 2*256 NELV
>>> 11, 2*4, 2*256 NELV
>>> 12, 2*4, 2*256 NELV
>>> 6, 2*4, 2*256 NELV
>>> 30, 2*4, 2*256 NELV
>>> 18, 2*4, 2*256 NELV
>>> 19, 2*4, 2*256 NELV
>>> 2, 2*4, 2*256 NELV
>>> 5, 2*4, 2*256 NELV
>>> 23, 2*4, 2*256 NELV
>>> 27, 2*4, 2*256 NELV
>>> 10, 2*4, 2*256 NELV
>>> 22, 2*4, 2*256 NELV
>>> 13, 2*4, 2*256 NELV
>>> 14, 2*4, 2*256 NELV
>>> 15, 2*4, 2*256 NELV
>>> 3, 2*4, 2*256 NELV
>>> 26, 2*4, 2*256 NELV
>>> 24, 2*4, 2*256 NELV
>>> 33, 2*4, 2*256 NELV
>>> 41, 2*4, 2*256 NELV
>>> 32, 2*4, 2*256 NELV
>>> 40, 2*4, 2*256 NELV
>>> 45, 2*4, 2*256 NELV
>>> 44, 2*4, 2*256 NELV
>>> 49, 2*4, 2*256 NELV
>>> 34, 2*4, 2*256 NELV
>>> 35, 2*4, 2*256 NELV
>>> 48, 2*4, 2*256 NELV
>>> 39, 2*4, 2*256 NELV
>>> 38, 2*4, 2*256 NELV
>>> 50, 2*4, 2*256 NELV
>>> 51, 2*4, 2*256 NELV
>>> 37, 2*4, 2*256 NELV
>>> 36, 2*4, 2*256 NELV
>>> 55, 2*4, 2*256 NELV
>>> 54, 2*4, 2*256 NELV
>>> 57, 2*4, 2*256 NELV
>>> 58, 2*4, 2*256 NELV
>>> 43, 2*4, 2*256 NELV
>>> 42, 2*4, 2*256 NELV
>>> 47, 2*4, 2*256 NELV
>>> 53, 2*4, 2*256 NELV
>>> 59, 2*4, 2*256 NELV
>>> 46, 2*4, 2*256 NELV
>>> 60, 2*4, 2*256 NELV
>>> 61, 2*4, 2*256 NELV
>>> 63, 2*4, 2*256 NELV
>>> 62, 2*4, 2*256 NELV
>>> 52, 2*4, 2*256 NELV
>>> 56, 2*4, 2*256 NELV
>>> 25, 0, 2*4, 256 NELT FAIL
>>> 24, 0, 2*4, 256 NELT FAIL
>>> 21, 0, 2*4, 256 NELT FAIL
>>> Check that .map file and .rea file agree
>>> 20, 0, 2*4, 256 NELT FAIL
>>> 31, 0, 2*4, 256 NELT FAIL
>>> 8, 0, 2*4, 256 NELT FAIL
>>> 17, 0, 2*4, 256 NELT FAIL
>>> 14, 0, 2*4, 256 NELT FAIL
>>> 15, 0, 2*4, 256 NELT FAIL
>>> 16, 0, 2*4, 256 NELT FAIL
>>> 26, 0, 2*4, 256 NELT FAIL
>>> 10, 0, 2*4, 256 NELT FAIL
>>> 2, 0, 2*4, 256 NELT FAIL
>>> 30, 0, 2*4, 256 NELT FAIL
>>> 11, 0, 2*4, 256 NELT FAIL
>>> 2*0, 2*4, 256 NELT FAIL
>>> 13, 0, 2*4, 256 NELT FAIL
>>> 12, 0, 2*4, 256 NELT FAIL
>>> 28, 0, 2*4, 256 NELT FAIL
>>> 18, 0, 2*4, 256 NELT FAIL
>>> 29, 0, 2*4, 256 NELT FAIL
>>> 23, 0, 2*4, 256 NELT FAIL
>>> 27, 0, 2*4, 256 NELT FAIL
>>> 19, 0, 2*4, 256 NELT FAIL
>>> 22, 0, 2*4, 256 NELT FAIL
>>> 2*0, 2*4, 256 NELT FB
>>> 1, 0, 2*4, 256 NELT FB
>>> 2, 0, 2*4, 256 NELT FB
>>> 3, 0, 2*4, 256 NELT FB
>>> 4, 0, 2*4, 256 NELT FB
>>> 5, 0, 2*4, 256 NELT FB
>>> 6, 0, 2*4, 256 NELT FB
>>> 7, 0, 2*4, 256 NELT FB
>>> 8, 0, 2*4, 256 NELT FB
>>> 9, 3*4, 256 NELT FB
>>> 10, 0, 2*4, 256 NELT FB
>>> 11, 0, 2*4, 256 NELT FB
>>> 12, 0, 2*4, 256 NELT FB
>>> 13, 0, 2*4, 256 NELT FB
>>> 14, 0, 2*4, 256 NELT FB
>>> 15, 0, 2*4, 256 NELT FB
>>> 16, 0, 2*4, 256 NELT FB
>>> 17, 0, 2*4, 256 NELT FB
>>> 18, 0, 2*4, 256 NELT FB
>>> 19, 0, 2*4, 256 NELT FB
>>> 20, 0, 2*4, 256 NELT FB
>>> 21, 0, 2*4, 256 NELT FB
>>> 22, 0, 2*4, 256 NELT FB
>>> 23, 0, 2*4, 256 NELT FB
>>> 24, 0, 2*4, 256 NELT FB
>>> 25, 0, 2*4, 256 NELT FB
>>> 26, 0, 2*4, 256 NELT FB
>>> 27, 0, 2*4, 256 NELT FB
>>> 28, 0, 2*4, 256 NELT FB
>>> 29, 0, 2*4, 256 NELT FB
>>> 30, 0, 2*4, 256 NELT FB
>>> 31, 0, 2*4, 256 NELT FB
>>> call exitt: dying ...
>>> backtrace(): obtained 1 stack frames.
>>> [0x662a40]
>>> total elapsed time : 7.82199E-02 sec
>>> total solver time incl. I/O : 0.00000E+00 sec
>>> time/timestep : 0.00000E+00 sec
>>> CPU seconds/timestep/gridpt : 0.00000E+00 sec
>>> 39, 0, 2*4, 256 NELT FAIL
>>> 38, 0, 2*4, 256 NELT FAIL
>>> 36, 0, 2*4, 256 NELT FAIL
>>> 41, 0, 2*4, 256 NELT FAIL
>>> 32, 0, 2*4, 256 NELT FAIL
>>> 48, 0, 2*4, 256 NELT FAIL
>>> 34, 0, 2*4, 256 NELT FAIL
>>> 54, 196, 2*4, 256 NELT FAIL
>>> 40, 0, 2*4, 256 NELT FAIL
>>> 46, 0, 2*4, 256 NELT FAIL
>>> 47, 0, 2*4, 256 NELT FAIL
>>> 33, 0, 2*4, 256 NELT FAIL
>>> 37, 0, 2*4, 256 NELT FAIL
>>> 35, 0, 2*4, 256 NELT FAIL
>>> 43, 0, 2*4, 256 NELT FAIL
>>> 45, 0, 2*4, 256 NELT FAIL
>>> 42, 0, 2*4, 256 NELT FAIL
>>> 44, 0, 2*4, 256 NELT FAIL
>>> 32, 0, 2*4, 256 NELT FB
>>> 33, 0, 2*4, 256 NELT FB
>>> 34, 0, 2*4, 256 NELT FB
>>> 35, 0, 2*4, 256 NELT FB
>>> 36, 0, 2*4, 256 NELT FB
>>> 37, 0, 2*4, 256 NELT FB
>>> 38, 0, 2*4, 256 NELT FB
>>> 39, 0, 2*4, 256 NELT FB
>>> 40, 0, 2*4, 256 NELT FB
>>> 41, 0, 2*4, 256 NELT FB
>>> 42, 0, 2*4, 256 NELT FB
>>> 43, 0, 2*4, 256 NELT FB
>>> 44, 0, 2*4, 256 NELT FB
>>> 45, 0, 2*4, 256 NELT FB
>>> 46, 0, 2*4, 256 NELT FB
>>> 47, 0, 2*4, 256 NELT FB
>>> 48, 0, 2*4, 256 NELT FB
>>> 49, 3*4, 256 NELT FB
>>> 50, 3*4, 256 NELT FB
>>> 51, 3*4, 256 NELT FB
>>> 52, 3*4, 256 NELT FB
>>> 53, 3*4, 256 NELT FB
>>> 54, 196, 2*4, 256 NELT FB
>>> 55, 3*4, 256 NELT FB
>>> 56, 3*4, 256 NELT FB
>>> 57, 3*4, 256 NELT FB
>>> 58, 3*4, 256 NELT FB
>>> 59, 3*4, 256 NELT FB
>>> 60, 3*4, 256 NELT FB
>>> 61, 3*4, 256 NELT FB
>>> 62, 3*4, 256 NELT FB
>>> 63, 3*4, 256 NELT FB
>>> Application 419539 resources: utime ~8s, stime ~13s
>>> Does the code map in parallel here? I'm not sure what's happening here,
>>> because the .map and .rea file do in fact agree. The error seems to
>>> occur when processor #25 is mapped for a second time. The same thing
>>> happens with my own cases that were running on a similar machine before
>>> but with Nek compiled with PGI.
>>> Any help would be greatly appreciated
>>> Oliver
>>> _______________________________________________
>>> Nek5000-users at lists.mcs.anl.gov
> Message: 2
> Date: Mon, 30 Jan 2012 13:43:50 -0600 (CST)
> 	running issues
> Message-ID:
> 	<304748520.192593.1327952630495.JavaMail.root at zimbra.anl.gov>
> Content-Type: text/plain; charset=utf-8
> Hi Oliver,
> I have been using Cray xe6/xt6 successfully with PGI compilers specified in makenek with
> # Fortran compiler
> F77="ftn"
> # C compiler
> CC="cc"
> and the submission script I use is below.
> Best.
> Aleks
> rm *batch*
> echo $1>   SESSION.NAME
> echo `pwd`'/'>>   SESSION.NAME
> touch $1.rea
> rm -f ioinfo
> mv -f $1.log.$2 $1.log1.$2
> mv -f $1.his $1.his1
> mv -f $1.sch $1.sch1
> rm -f logfile
> echo ''>  $1.log.$2
> echo   "#!/bin/bash">   $1.batch
> echo   "#PBS -l mppwidth="$2>>  $1.batch
> echo   "#PBS -l walltime="$3":"$4":00">>  $1.batch
> echo   "#PBS -j oe">>  $1.batch
> echo   cd `pwd`>>  $1.batch
> echo   aprun -n $2 ./nek5000 ">>" $1.log.$2>>  $1.batch
> echo   "exit 0;">>  $1.batch
> qsub -q batch $1.batch
> sleep 3
> ln $1.log.$2 logfile
> ## usage: neke case cores hours minutes
> Sent: Monday, January 30, 2012 12:02:23 PM
> Subject: Re: [Nek5000-users] Running NEK on CRAY;	compilation&  running issues
> Hi Oliver,
> Cheers,
> Stefan
>> Oliver,
>> Regards,
>> Paul
>>> Dear NEKs,
>>> problem, I assume.
>>> 1) changed
>>> as
>>> Nek's gsync
>>> called
>>> REAL wdsize : 8
>>> INTEGER wdsize : 4
>>> Beginning session:
>>> read .rea file
>>> 0, 2*4, 2*256 NELV
>>> 1, 2*4, 2*256 NELV
>>> 8, 2*4, 2*256 NELV
>>> 9, 2*4, 2*256 NELV
>>> 17, 2*4, 2*256 NELV
>>> 16, 2*4, 2*256 NELV
>>> 20, 2*4, 2*256 NELV
>>> 3*4, 2*256 NELV
>>> 29, 2*4, 2*256 NELV
>>> 21, 2*4, 2*256 NELV
>>> 28, 2*4, 2*256 NELV
>>> 7, 2*4, 2*256 NELV
>>> 31, 2*4, 2*256 NELV
>>> 25, 2*4, 2*256 NELV
>>> 11, 2*4, 2*256 NELV
>>> 12, 2*4, 2*256 NELV
>>> 6, 2*4, 2*256 NELV
>>> 30, 2*4, 2*256 NELV
>>> 18, 2*4, 2*256 NELV
>>> 19, 2*4, 2*256 NELV
>>> 2, 2*4, 2*256 NELV
>>> 5, 2*4, 2*256 NELV
>>> 23, 2*4, 2*256 NELV
>>> 27, 2*4, 2*256 NELV
>>> 10, 2*4, 2*256 NELV
>>> 22, 2*4, 2*256 NELV
>>> 13, 2*4, 2*256 NELV
>>> 14, 2*4, 2*256 NELV
>>> 15, 2*4, 2*256 NELV
>>> 3, 2*4, 2*256 NELV
>>> 26, 2*4, 2*256 NELV
>>> 24, 2*4, 2*256 NELV
>>> 33, 2*4, 2*256 NELV
>>> 41, 2*4, 2*256 NELV
>>> 32, 2*4, 2*256 NELV
>>> 40, 2*4, 2*256 NELV
>>> 45, 2*4, 2*256 NELV
>>> 44, 2*4, 2*256 NELV
>>> 49, 2*4, 2*256 NELV
>>> 34, 2*4, 2*256 NELV
>>> 35, 2*4, 2*256 NELV
>>> 48, 2*4, 2*256 NELV
>>> 39, 2*4, 2*256 NELV
>>> 38, 2*4, 2*256 NELV
>>> 50, 2*4, 2*256 NELV
>>> 51, 2*4, 2*256 NELV
>>> 37, 2*4, 2*256 NELV
>>> 36, 2*4, 2*256 NELV
>>> 55, 2*4, 2*256 NELV
>>> 54, 2*4, 2*256 NELV
>>> 57, 2*4, 2*256 NELV
>>> 58, 2*4, 2*256 NELV
>>> 43, 2*4, 2*256 NELV
>>> 42, 2*4, 2*256 NELV
>>> 47, 2*4, 2*256 NELV
>>> 53, 2*4, 2*256 NELV
>>> 59, 2*4, 2*256 NELV
>>> 46, 2*4, 2*256 NELV
>>> 60, 2*4, 2*256 NELV
>>> 61, 2*4, 2*256 NELV
>>> 63, 2*4, 2*256 NELV
>>> 62, 2*4, 2*256 NELV
>>> 52, 2*4, 2*256 NELV
>>> 56, 2*4, 2*256 NELV
>>> 9, 3*4, 256 NELT FB
>>> [0x662a40]
>>> Oliver
> End of Nek5000-users Digest, Vol 35, Issue 21
