[Nek5000-users] Running Simulations in Parallel with nekbmpi
Tue Oct 18 11:05:33 CDT 2011
Sorry for this very late response, it completely got out of my mind. Here
are the different outputs I get for these commands:
jean-christophe at dyf-corto:~/Calculs/Cavite2D/BaseFlow$ ulimit -a
core file size          (blocks, -c) 0
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 31533
max locked memory       (kbytes, -l) 64
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 0
stack size              (kbytes, -s) 8192
cpu time               (seconds, -t) unlimited
max user processes              (-u) 31533
virtual memory          (kbytes, -v) unlimited
file locks                      (-x) unlimited
jean-christophe at dyf-corto:~/Calculs/Cavite2D/BaseFlow$ size nek5000
   text       data        bss        dec        hex    filename
2232834       3484    185835044    188071362    b35bdc2    nek5000
jean-christophe at dyf-corto:~/Calculs/Cavite2D/BaseFlow$ cat SIZE
C     Dimension file to be included
C
C     HCUBE array dimensions
C
      parameter (ldim=2)
      parameter (lx1=11,ly1=lx1,lz1=1,lelt=225,lelv=lelt)
      parameter (lxd=17,lyd=lxd,lzd=1)
      parameter (lelx=20,lely=60,lelz=1)
c
      parameter (lzl=3 + 2*(ldim-3))
c
      parameter (lx2=lx1-2)
      parameter (ly2=ly1-2)
      parameter (lz2=1)
      parameter (lx3=lx2)
      parameter (ly3=ly2)
      parameter (lz3=lz2)
c
c     parameter (lpelv=lelv,lpelt=lelt,lpert=3)  ! perturbation
c     parameter (lpx1=lx1,lpy1=ly1,lpz1=lz1)     ! array sizes
c     parameter (lpx2=lx2,lpy2=ly2,lpz2=lz2)
c
      parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
      parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
      parameter (lpx2=1,lpy2=1,lpz2=1)
c
c
c     parameter (lbelv=lelv,lbelt=lelt)          ! MHD
c     parameter (lbx1=lx1,lby1=ly1,lbz1=lz1)     ! array sizes
c     parameter (lbx2=lx2,lby2=ly2,lbz2=lz2)
c
      parameter (lbelv=1,lbelt=1)                ! MHD
      parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
      parameter (lbx2=1,lby2=1,lbz2=1)
c
C LX1M=LX1 when there are moving meshes; =1 otherwise
      parameter (lx1m=lx1,ly1m=ly1,lz1m=lz1)
      parameter (ldimt= 4)                       ! 3 passive scalars + T
      parameter (ldimt1=ldimt+1)
      parameter (ldimt3=ldimt+3)
      parameter (lp = 8)
      parameter (lelg = 300)
c
c     Note:  In the new code, LELGEC should be about sqrt(LELG)
c
      PARAMETER (LELGEC = 1)
      PARAMETER (LXYZ2  = 1)
      PARAMETER (LXZ21  = 1)
c
      PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
      PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
      PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
      PARAMETER (LXZ=LX1*LZ1)
      PARAMETER (LORDER=3)
      PARAMETER (MAXOBJ=4,MAXMBR=LELT*6,lhis=100)
C
C     Common Block Dimensions
C
      PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
      PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
C
C     The parameter LVEC controls whether an additional 42 field arrays
C     are required for Steady State Solutions.  If you are not using
C     Steady State, it is recommended that LVEC=1.
C
      PARAMETER (LVEC=1)
C
C     Uzawa projection array dimensions
C
      parameter (mxprev = 80)
      parameter (lgmres = 40)
C
C     Split projection array dimensions
C
      parameter(lmvec = 1)
      parameter(lsvec = 1)
      parameter(lstore=lmvec*lsvec)
c
c     NONCONFORMING STUFF
c
      parameter (maxmor = lelt)
C
C     Array dimensions
C
      COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
     $,NX3,NY3,NZ3,NDIM,NFIELD,NPERT,NID
     $,NXD,NYD,NZD
c automatically added by makenek
      parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
      parameter(lpart = 1  ) ! max number of particles
      integer ax1,ay1,az1,ax2,ay2,az2
      parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) ! running
averages
      parameter (lxs=1,lys=lxs,lzs=(lxs-1)*(ldim-2)+1) !New Pressure
Preconditioner
      parameter (lfdm=0)  ! == 1 for fast diagonalization method
Concerning Nek, yes I do get an output on the screen when lauching the
calculation. Attached is the logfile for one example (2D cavity, only with
100 elements though but the problem is the same as I increase the number of
elements).
Cheers,
On 18 October 2011 18:03, Jean-Christophe Loiseau <loiseau.jc at gmail.com>wrote:
> Hi,
> C
> C
>       parameter (ldim=2)
> c
> c
>       parameter (lz2=1)
>       parameter (lx3=lx2)
>       parameter (ly3=ly2)
>       parameter (lz3=lz2)
> c
> c
> c
> c
> c
> c
>       parameter (lp = 8)
> c
> c
> c
> C
> C
> C
> C
>       PARAMETER (LVEC=1)
> C
> C
> C
> C
> c
> c
> C
> C     Array dimensions
> C
>      $,NXD,NYD,NZD
> averages
> Preconditioner
> elements).
> Cheers,
> On 27 September 2011 17:40, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi,
>> Do you get any output printed to the screen when you launch Nek?
>> Please provide the output of the following command:
>> ulimit -a (in case you are using bash)
>> size nek5000
>> cat SIZE
>> Can you post the command you are using to launch Nek in parallel?
>> Cheers,
>> Stefan
>> On 9/27/11, nek5000-users at lists.mcs.anl.gov
>> > Hi Neks,
>> > I do get the same error when I try to run nek on my laptop. Did you find
>> any
>> > way to solve the problem John?
>> > Regards,
>> > On 11 May 2011 21:25, <nek5000-users at lists.mcs.anl.gov> wrote:
>> >> Hi,
>> >> I have lp=512 in SIZE, and I did compile with IFMPI=true.  I recompiled
>> >> yesterday because I thought this may be the case, but I was still
>> getting
>> >> the same error.  When I first start a simulation and run top, it shows
>> >> four
>> >> processors running nek5000, but this changes to one processor after a
>> few
>> >> seconds.
>> >> Thanks,
>> >> John
>> >> _______________________________________________
>> >> Nek5000-users mailing list
>> >> Nek5000-users at lists.mcs.anl.gov
>> >> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> > Jean-Christophe
> Jean-Christophe
Jean-Christophe
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20111018/48472c63/attachment.html>
