[Nek5000-users] Running Simulations in Parallel with nekbmpi
Tue Oct 18 12:13:14 CDT 2011
Please post your makenek.
-Stefan
On 10/18/11, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> Sorry for this very late response, it completely got out of my mind. Here
> are the different outputs I get for these commands:
> jean-christophe at dyf-corto:~/Calculs/Cavite2D/BaseFlow$ ulimit -a
> core file size          (blocks, -c) 0
> data seg size           (kbytes, -d) unlimited
> scheduling priority             (-e) 0
> file size               (blocks, -f) unlimited
> pending signals                 (-i) 31533
> max locked memory       (kbytes, -l) 64
> max memory size         (kbytes, -m) unlimited
> open files                      (-n) 1024
> pipe size            (512 bytes, -p) 8
> POSIX message queues     (bytes, -q) 819200
> real-time priority              (-r) 0
> stack size              (kbytes, -s) 8192
> cpu time               (seconds, -t) unlimited
> max user processes              (-u) 31533
> virtual memory          (kbytes, -v) unlimited
> file locks                      (-x) unlimited
> jean-christophe at dyf-corto:~/Calculs/Cavite2D/BaseFlow$ size nek5000
>    text       data        bss        dec        hex    filename
> 2232834       3484    185835044    188071362    b35bdc2    nek5000
> jean-christophe at dyf-corto:~/Calculs/Cavite2D/BaseFlow$ cat SIZE
> C     Dimension file to be included
> C
> C     HCUBE array dimensions
> C
>       parameter (ldim=2)
>       parameter (lx1=11,ly1=lx1,lz1=1,lelt=225,lelv=lelt)
>       parameter (lxd=17,lyd=lxd,lzd=1)
>       parameter (lelx=20,lely=60,lelz=1)
> c
>       parameter (lzl=3 + 2*(ldim-3))
> c
>       parameter (lx2=lx1-2)
>       parameter (ly2=ly1-2)
>       parameter (lz2=1)
>       parameter (lx3=lx2)
>       parameter (ly3=ly2)
>       parameter (lz3=lz2)
> c
> c     parameter (lpelv=lelv,lpelt=lelt,lpert=3)  ! perturbation
> c     parameter (lpx1=lx1,lpy1=ly1,lpz1=lz1)     ! array sizes
> c     parameter (lpx2=lx2,lpy2=ly2,lpz2=lz2)
> c
>       parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
>       parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
>       parameter (lpx2=1,lpy2=1,lpz2=1)
> c
> c
> c     parameter (lbelv=lelv,lbelt=lelt)          ! MHD
> c     parameter (lbx1=lx1,lby1=ly1,lbz1=lz1)     ! array sizes
> c     parameter (lbx2=lx2,lby2=ly2,lbz2=lz2)
> c
>       parameter (lbelv=1,lbelt=1)                ! MHD
>       parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
>       parameter (lbx2=1,lby2=1,lbz2=1)
> c
> C LX1M=LX1 when there are moving meshes; =1 otherwise
>       parameter (lx1m=lx1,ly1m=ly1,lz1m=lz1)
>       parameter (ldimt= 4)                       ! 3 passive scalars + T
>       parameter (ldimt1=ldimt+1)
>       parameter (ldimt3=ldimt+3)
>       parameter (lp = 8)
>       parameter (lelg = 300)
> c
> c     Note:  In the new code, LELGEC should be about sqrt(LELG)
> c
>       PARAMETER (LELGEC = 1)
>       PARAMETER (LXYZ2  = 1)
>       PARAMETER (LXZ21  = 1)
> c
>       PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
>       PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
>       PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
>       PARAMETER (LXZ=LX1*LZ1)
>       PARAMETER (LORDER=3)
>       PARAMETER (MAXOBJ=4,MAXMBR=LELT*6,lhis=100)
> C
> C     Common Block Dimensions
> C
>       PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
>       PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
> C
> C     The parameter LVEC controls whether an additional 42 field arrays
> C     are required for Steady State Solutions.  If you are not using
> C     Steady State, it is recommended that LVEC=1.
> C
>       PARAMETER (LVEC=1)
> C
> C     Uzawa projection array dimensions
> C
>       parameter (mxprev = 80)
>       parameter (lgmres = 40)
> C
> C     Split projection array dimensions
> C
>       parameter(lmvec = 1)
>       parameter(lsvec = 1)
>       parameter(lstore=lmvec*lsvec)
> c
> c     NONCONFORMING STUFF
> c
>       parameter (maxmor = lelt)
> C
> C     Array dimensions
> C
>       COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
>      $,NX3,NY3,NZ3,NDIM,NFIELD,NPERT,NID
>      $,NXD,NYD,NZD
> c automatically added by makenek
>       parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
>       parameter(lpart = 1  ) ! max number of particles
>       integer ax1,ay1,az1,ax2,ay2,az2
>       parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) ! running
> averages
>       parameter (lxs=1,lys=lxs,lzs=(lxs-1)*(ldim-2)+1) !New Pressure
> Preconditioner
>       parameter (lfdm=0)  ! == 1 for fast diagonalization method
> Concerning Nek, yes I do get an output on the screen when lauching the
> calculation. Attached is the logfile for one example (2D cavity, only with
> 100 elements though but the problem is the same as I increase the number of
> elements).
> Cheers,
> On 18 October 2011 18:03, Jean-Christophe Loiseau
> <loiseau.jc at gmail.com>wrote:
>> Hi,
>> C
>> C
>>       parameter (ldim=2)
>> c
>> c
>>       parameter (lz2=1)
>>       parameter (lx3=lx2)
>>       parameter (ly3=ly2)
>>       parameter (lz3=lz2)
>> c
>> c
>> c
>> c
>> c
>> c
>>       parameter (lp = 8)
>> c
>> c
>> c
>> C
>> C
>> C
>> C
>>       PARAMETER (LVEC=1)
>> C
>> C
>> C
>> C
>> c
>> c
>> C
>> C     Array dimensions
>> C
>>      $,NXD,NYD,NZD
>> running
>> averages
>> Preconditioner
>> of
>> elements).
>> Cheers,
>> On 27 September 2011 17:40, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi,
>>> Do you get any output printed to the screen when you launch Nek?
>>> Please provide the output of the following command:
>>> ulimit -a (in case you are using bash)
>>> size nek5000
>>> cat SIZE
>>> Can you post the command you are using to launch Nek in parallel?
>>> Cheers,
>>> Stefan
>>> On 9/27/11, nek5000-users at lists.mcs.anl.gov
>>> > Hi Neks,
>>> > I do get the same error when I try to run nek on my laptop. Did you
>>> > find
>>> any
>>> > way to solve the problem John?
>>> > Regards,
>>> > On 11 May 2011 21:25, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> >> Hi,
>>> >> I have lp=512 in SIZE, and I did compile with IFMPI=true.  I
>>> >> recompiled
>>> >> yesterday because I thought this may be the case, but I was still
>>> getting
>>> >> the same error.  When I first start a simulation and run top, it shows
>>> >> four
>>> >> processors running nek5000, but this changes to one processor after a
>>> few
>>> >> seconds.
>>> >> Thanks,
>>> >> John
>>> >> _______________________________________________
>>> >> Nek5000-users mailing list
>>> >> Nek5000-users at lists.mcs.anl.gov
>>> >> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> > Jean-Christophe
>> Jean-Christophe
> Jean-Christophe
