[Nek5000-users] Periodic BC on non-parallel boundaries
Tue Oct 11 20:43:18 CDT 2011
Hi Aleks,
Thanks for the tip.  Unfortunately, fixing the handedness did not make the
free-slip case work for me.  When you were simulating an annular cylinder,
did you ever have the SYM BC's on both the sides and the ends?
I think I've determined that neither the Pn/Pn-2 method nor the stress
formulation is the problem with my 3D annular cylinder.  I conclude this
because the simulation runs properly with IFSTRS=T when the sides are SYM
and ends are W, or when the sides are W and the ends are SYM.  It is only
when both sides and ends are SYM that the simulation doesn't work.  Any
thoughts?
Best,
David
On Tue, Oct 11, 2011 at 3:09 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi David,
> I was using a similar transformation for the annulus except for the order
> of r & theta, i.e. I mapped [r,theta,z] -> [x,y,z] preserving right-handed
> coordinate system...
> Aleks
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20111011/aa0e928e/attachment.html>
