[Nek5000-users] Error when running the vortex problem
Tue Oct 11 12:54:06 CDT 2011
I was trying to run nek5000 with vortex, following the default user setting. There is no problem for building, however when I start to run the application, there is an error "NONSTD HDR, parse_hdr, abort". The following is the related error report.
Reading checkpoint data
       0       0 OPEN: r1492_n08.fld27
byte swap: T   0.000000       0.000000
140   8   8   8 5.0101000E+0250101 U P                             4 NELT,NX,N úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
        NONSTD HDR, parse_hdr, abort.
I briefly read the code. It looks like the code is reading the checkpoint file "r1492_n08.fld27" and there is something wrong with the file header. The file header does not follow the standard format and the code cannot understand the file.
How can I solve this problem?
Thank you.
-Dong
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20111011/d1927c59/attachment.html>
