[Nek5000-users] Periodic BC on non-parallel boundaries
Tue Oct 11 15:09:56 CDT 2011
Hi David,
I was using a similar transformation for the annulus except for the order of r & theta, i.e. I mapped [r,theta,z] -> [x,y,z] preserving right-handed coordinate system...
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Tuesday, October 11, 2011 3:03:16 PM
Subject: Re: [Nek5000-users] Periodic BC on non-parallel boundaries
Hi Stefan,
What do you mean by "remapping a periodic-side domain in userdat2"?
I build a mesh using genbox with dimensions [0,1]^3. The BC are periodic in x. Then in userdat 2 I remap the (x,y) cross-section from a square to an annulus:
call rescale_x(xm1,zero,pi2)
call rescale_x(ym1,zero,one)
n = nx1*ny1*nz1*nelv ! Turn box into annulus
do i=1,n
th = xm1(i,1,1,1)
r = r0 + (r1-r0)*(1.-ym1(i,1,1,1))
xm1(i,1,1,1) = r*cos(th)
ym1(i,1,1,1) = r*sin(th)
enddo
This gives me an annulus centered on the z-axis with interior radius r0 and exterior radius r1. (I tried centering it on the y-axis instead with the periodic boundary lying in the xy-plane, but the result was the same.) My velocity BC in what are initially the y and z directions are all SYM, so I need to use the stress formulation.
This procedure worked in 2D for no-slip or stress-free BC, but in 3D it is not working for stress-free BC. I can visualize the 3D geometry, and the annular cylinder appears to be properly constructed, but the fluid solution blows up.
I understand now that my fractional-annulus cases blow up because non-cyclic periodic BC at the theta-ends are incompatible with stress-free walls, but this should not be an issue for the full 2π annulus, even in 3D. Can you think of a reason that non-cyclic periodic BC would work in 2D but not in 3D?
Sure, even with IFCYCLIC=F you'll get a result. But is probably not
the one you had in mind, simply because the BCs are different i.e.
periodic vs cyclic.
Ah yes, you`re right that the results are actually different.
Thanks a lot,
David
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
