[Nek5000-users] Error when running the vortex problem
Tue Oct 11 14:03:01 CDT 2011
Hi Dong,
For some reason, your run is traversing the .f00000 file format
branch, rather than the .fld input branch.
This traversal is generally controlled by setting
param(66)=4 (for .fld) in usrdat2 (or usrdat) in the .usr file.
I'm wondering if you are compiling with r1854.usr provided in
the examples/vortex directory?
Paul
On Tue, 11 Oct 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Dong,
> What kind of platform are you running on?
> Can you do an svn update in the example directory, just in case
> the file was contaminated on transfer?
> Paul
>> Hi, Stefan.
>> Sure. Attached is the log file.
>> -Dong
>> -----Original Message-----
>> From: nek5000-users-bounces at lists.mcs.anl.gov
>> [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of
>> Sent: Tuesday, October 11, 2011 2:15 PM
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Error when running the vortex problem
>> Please post a full log file. Note the file size is limited to 100KB.
>> -Stefan
>> On 10/11/11, S K <stgeke at googlemail.com> wrote:
>>> Hi Dong,
>>> It works for me. Did you change anything?
>>> -Stefan
>>> On 10/11/11, nek5000-users at lists.mcs.anl.gov
>>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>>> Hi,
>>>> I was trying to run nek5000 with vortex, following the default user
>>>> setting.
>>>> There is no problem for building, however when I start to run the
>>>> application, there is an error "NONSTD HDR, parse_hdr, abort". The
>>>> following
>>>> is the related error report.
>>>> Reading checkpoint data
>>>>        0       0 OPEN: r1492_n08.fld27
>>>> byte swap: T   0.000000       0.000000
>>>> 140   8   8   8 5.0101000E+0250101 U P                             4
>>>> NELT,NX,N
>>>> úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
>>>>                           NONSTD HDR, parse_hdr, abort.
>>>> I briefly read the code. It looks like the code is reading the checkpoint
>>>> file "r1492_n08.fld27" and there is something wrong with the file header.
>>>> The file header does not follow the standard format and the code cannot
>>>> understand the file.
>>>> How can I solve this problem?
>>>> Thank you.
>>>> -Dong
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Hi, Stefan.
> -Dong
> From: nek5000-users-bounces at lists.mcs.anl.gov [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of nek5000-users at lists.mcs.anl.gov
> -Stefan
>> Hi Dong,
>> -Stefan
>>> Hi,
>>> setting.
>>> following
>>> NELT,NX,N
>>> Thank you.
>>> -Dong
