[Nek5000-users] Error when running the vortex problem
Tue Oct 11 13:42:16 CDT 2011
Hi Dong,
What kind of platform are you running on?
Can you do an svn update in the example directory, just in case
the file was contaminated on transfer?
Paul
On Tue, 11 Oct 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi, Stefan.
> Sure. Attached is the log file.
> -Dong
> -----Original Message-----
> From: nek5000-users-bounces at lists.mcs.anl.gov [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of nek5000-users at lists.mcs.anl.gov
> Sent: Tuesday, October 11, 2011 2:15 PM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Error when running the vortex problem
> Please post a full log file. Note the file size is limited to 100KB.
> -Stefan
> On 10/11/11, S K <stgeke at googlemail.com> wrote:
>> Hi Dong,
>> It works for me. Did you change anything?
>> -Stefan
>> On 10/11/11, nek5000-users at lists.mcs.anl.gov
>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi,
>>> I was trying to run nek5000 with vortex, following the default user
>>> setting.
>>> There is no problem for building, however when I start to run the
>>> application, there is an error "NONSTD HDR, parse_hdr, abort". The
>>> following
>>> is the related error report.
>>> Reading checkpoint data
>>>        0       0 OPEN: r1492_n08.fld27
>>> byte swap: T   0.000000       0.000000
>>> 140   8   8   8 5.0101000E+0250101 U P                             4
>>> NELT,NX,N
>>> úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
>>>                           NONSTD HDR, parse_hdr, abort.
>>> I briefly read the code. It looks like the code is reading the checkpoint
>>> file "r1492_n08.fld27" and there is something wrong with the file header.
>>> The file header does not follow the standard format and the code cannot
>>> understand the file.
>>> How can I solve this problem?
>>> Thank you.
>>> -Dong
> Nek5000-users mailing list
