[Nek5000-users] Error when running the vortex problem
Tue Oct 11 13:08:43 CDT 2011
Hi Dong,
It works for me. Did you change anything?
-Stefan
On 10/11/11, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> I was trying to run nek5000 with vortex, following the default user setting.
> There is no problem for building, however when I start to run the
> application, there is an error "NONSTD HDR, parse_hdr, abort". The following
> is the related error report.
> Reading checkpoint data
>        0       0 OPEN: r1492_n08.fld27
> byte swap: T   0.000000       0.000000
> 140   8   8   8 5.0101000E+0250101 U P                             4
> NELT,NX,N
> úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
>                           NONSTD HDR, parse_hdr, abort.
> I briefly read the code. It looks like the code is reading the checkpoint
> file "r1492_n08.fld27" and there is something wrong with the file header.
> The file header does not follow the standard format and the code cannot
> understand the file.
> How can I solve this problem?
> Thank you.
> -Dong
