[Nek5000-users] Error when running the vortex problem
Tue Oct 11 13:14:48 CDT 2011
Please post a full log file. Note the file size is limited to 100KB.
-Stefan
On 10/11/11, S K <stgeke at googlemail.com> wrote:
> Hi Dong,
> It works for me. Did you change anything?
> -Stefan
> On 10/11/11, nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi,
>> I was trying to run nek5000 with vortex, following the default user
>> setting.
>> There is no problem for building, however when I start to run the
>> application, there is an error "NONSTD HDR, parse_hdr, abort". The
>> following
>> is the related error report.
>> Reading checkpoint data
>>        0       0 OPEN: r1492_n08.fld27
>> byte swap: T   0.000000       0.000000
>> 140   8   8   8 5.0101000E+0250101 U P                             4
>> NELT,NX,N
>> úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
>>                           NONSTD HDR, parse_hdr, abort.
>> I briefly read the code. It looks like the code is reading the checkpoint
>> file "r1492_n08.fld27" and there is something wrong with the file header.
>> The file header does not follow the standard format and the code cannot
>> understand the file.
>> How can I solve this problem?
>> Thank you.
>> -Dong
