[Nek5000-users] Post-processing dump files to generate Lamda-2 criterion
Thu Nov 3 16:06:58 CDT 2011
Hi Sofia,
Yes.  Once you add the code into userchk, you recompile, set nsteps = 0,
and run nek.  It will then run the post-processing and exit.
-Katie
On Thu, Nov 3, 2011 at 12:24 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello Katie,
> thank you for the reply.
> What is not clear to me are the exact steps to run the code in
> post-processing mode.
> As I understand I have to add the userchk that you send me in the link in
> the .usr file and compile Nek once again.
> Then set the Nsteps=0 in the .rea file and run nek??
> Thank you once again.
> Regards
> Sofia
> On Wed, 2 Nov 2011 11:32:42 -0500, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>> Hi Sofia,
>> Does this help clear anything up:
>> https://lists.mcs.anl.gov/**mailman/htdig/nek5000-users/**
>> 2011-January/001224.html<https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2011-January/001224.html>
>> [4]
>> If not, could you further specify what needs clarification?
>> Thanks,
>> Katie
>> On Sat, Oct 29, 2011 at 11:50 AM,  wrote:
>>  Dears Neks
>>> I have used the solver to run 3D simulations for the moving
>>> cylinder problem.
>>> I have cyl3d0.f000* and enscyl3d0.f000* dump files  that I need to
>>> post process in order to generate the Lambda-2 vortex criterion.
>>> Please advise how I will load my dump files and run the solver in
>>> post processing mode to apply the criterion (I see that there is
>>> subroutine lamda2(l2) in postpro.f ).
>>> I have already read the example in
>>> http://nek5000.mcs.anl.gov/**index.php/Data_processing_**example<http://nek5000.mcs.anl.gov/index.php/Data_processing_example>[1] but
>>> it was not clear to me.
>>> Regards
>>> Sofia
>>> ______________________________**_________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov> [2]
>>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>[3]
>> Links:
>> [1] http://nek5000.mcs.anl.gov/**index.php/Data_processing_**example<http://nek5000.mcs.anl.gov/index.php/Data_processing_example>
>> [2] mailto:Nek5000-users at lists.**mcs.anl.gov<Nek5000-users at lists.mcs.anl.gov>
>> [3] https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>> [4]
>> [5] mailto:nek5000-users at lists.**mcs.anl.gov<nek5000-users at lists.mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20111103/1cef852b/attachment.html>
