[Nek5000-users] Post-processing dump files to generate Lamda-2 criterion
Thu Nov 3 17:29:28 CDT 2011
 Thanks Katie,
 I will try it and I will let you know in case I need something else.
 Sofia
 On Thu, 3 Nov 2011 16:06:58 -0500, nek5000-users at lists.mcs.anl.gov
 wrote:
> Hi Sofia,
> Yes.  Once you add the code into userchk, you recompile, set nsteps =
> 0, and run nek.  It will then run the post-processing and exit.
> -Katie
> On Thu, Nov 3, 2011 at 12:24 PM,  wrote:
>> Hello Katie,
>> thank you for the reply.
>> What is not clear to me are the exact steps to run the code in
>> post-processing mode.
>> As I understand I have to add the userchk that you send me in the
>> link in the .usr file and compile Nek once again.
>> Then set the Nsteps=0 in the .rea file and run nek??
>> Thank you once again.
>> Regards
>> Sofia
>> On Wed, 2 Nov 2011 11:32:42 -0500, nek5000-users at lists.mcs.anl.gov
>> [10] wrote:
>>> Hi Sofia,
>>> Does this help clear anything up:
> https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2011-January/001224.html
>>> [4]
>>> [4]
>>> If not, could you further specify what needs clarification?
>>> Thanks,
>>> Katie
>>> On Sat, Oct 29, 2011 at 11:50 AM,  wrote:
>>>> Dears Neks
>>>> I have used the solver to run 3D simulations for the moving
>>>> cylinder problem.
>>>> I have cyl3d0.f000* and enscyl3d0.f000* dump files  that I
>>>> need to
>>>> post process in order to generate the Lambda-2 vortex
>>>> criterion.
>>>> Please advise how I will load my dump files and run the solver
>>>> in
>>>> post processing mode to apply the criterion (I see that there
>>>> is
>>>> subroutine lamda2(l2) in postpro.f ).
>>>> I have already read the example in
>>>> http://nek5000.mcs.anl.gov/index.php/Data_processing_example
>>>> [1] [1] but
>>>> it was not clear to me.
>>>> Regards
>>>> Sofia
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov [2] [2]
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users [3]
>>>> [3]
>>> Links:
>>> [1] http://nek5000.mcs.anl.gov/index.php/Data_processing_example
>>> [5]
>>> [2] mailto:Nek5000-users at lists.mcs.anl.gov [6]
>>> [3] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users [7]
>>> [4]
>>> [8]
>>> [5] mailto:nek5000-users at lists.mcs.anl.gov [9]
>> Nek5000-users at lists.mcs.anl.gov [11]
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users [12]
> Links:
> [4]
> [5] http://nek5000.mcs.anl.gov/index.php/Data_processing_example
> [6] mailto:Nek5000-users at lists.mcs.anl.gov
> [7] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> [8]
> [9] mailto:nek5000-users at lists.mcs.anl.gov
> [10] mailto:nek5000-users at lists.mcs.anl.gov
> [11] mailto:Nek5000-users at lists.mcs.anl.gov
> [12] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> [13] mailto:nek5000-users at lists.mcs.anl.gov
