[Nek5000-users] Post-processing dump files to generate Lamda-2 criterion
Thu Nov 3 12:24:30 CDT 2011
 Hello Katie,
 thank you for the reply.
 What is not clear to me are the exact steps to run the code in
 post-processing mode.
 As I understand I have to add the userchk that you send me in the link
 in the .usr file and compile Nek once again.
 Then set the Nsteps=0 in the .rea file and run nek??
 Thank you once again.
 Regards
 Sofia
 On Wed, 2 Nov 2011 11:32:42 -0500, nek5000-users at lists.mcs.anl.gov
 wrote:
> Hi Sofia,
> Does this help clear anything up:
> https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2011-January/001224.html
> [4]
> If not, could you further specify what needs clarification?
> Thanks,
> Katie
> On Sat, Oct 29, 2011 at 11:50 AM,  wrote:
>> Dears Neks
>> I have used the solver to run 3D simulations for the moving
>> cylinder problem.
>> I have cyl3d0.f000* and enscyl3d0.f000* dump files  that I need to
>> post process in order to generate the Lambda-2 vortex criterion.
>> Please advise how I will load my dump files and run the solver in
>> post processing mode to apply the criterion (I see that there is
>> subroutine lamda2(l2) in postpro.f ).
>> I have already read the example in
>> http://nek5000.mcs.anl.gov/index.php/Data_processing_example [1] but
>> it was not clear to me.
>> Regards
>> Sofia
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov [2]
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users [3]
> Links:
> [1] http://nek5000.mcs.anl.gov/index.php/Data_processing_example
> [2] mailto:Nek5000-users at lists.mcs.anl.gov
> [3] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> [4]
> [5] mailto:nek5000-users at lists.mcs.anl.gov
