[Nek5000-users] Compilation error
Wed May 25 07:21:58 CDT 2011
Thanks for the tip, it now works at least for serial calculation. Note
furthermore that, using the xlf compiler from ibm, I also had to change
-qrealsize=8 into -qautodbl=dbl4 in order to avoid a segmentation fault.
I am now trying to compile to it for parallel calculation, thus I specified
mpxlf_r and mpcc_r in F77 and C fields in makenek. However I get the
following message as soon as I start the compilation:
 ./makenek stenosis
makenek - automatic build tool for Nek5000
** test   === End of Compilation 1 ===
1501-510  Compilation successful for file test_f77.f.
llsubmit: Processed command file through Submit Filter:
"/usr/local/loadl/Fidris/llsubmit_exit".
** underscore_test   === End of Compilation 1 ===
1501-510  Compilation successful for file test_underscore.f.
ERROR: Unable to detect compiler!
        - don't know how to promote datatype REAL to 8 bytes
        - don't know how to invoke the C pre-processor (CPP) before
compilation
       Please edit the makefile and specify the requested compiler flags
using the P variable.
I presume it is a fairly simple error to solve, but I am not familiar at all
with such massively parallel calculators yet [?]
Best regards,
JC
On 24 May 2011 16:20, <nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Jean-Christophe,
> etime is a fairly std. timer function, but obviously not
> supported with your compiler.
> When using mpi, it uses instead the mpi timer, so there is no
> issue.
> The quick fix here would be to edit mpi_dummy.f and change
> the etime() reference therein to the ibm timer function.
> You might also try setting it zero - but I'm not 100% certain
> that there are no divisions involving time in the denominator...
> It's worth a try, however.
> Paul
> On Tue, 24 May 2011, nek5000-users at lists.mcs.anl.gov wrote:
>  Hi Nek's,
>> Up to now I have compiled and run the code on the various workstations
>> available in my lab. I am now trying to compile it (only in serial for the
>> moment) on an IBM Power 6 (
>> http://www.idris.fr/su/Scalaire/vargas/hw-vargas.html) but I encounter an
>> error (which is the reason why I do not compile it using mpi support
>> yet). Following is the outpost from the compilation:
>> xlf_r -qsuppress=cmpmsg -o nek5000  obj/stenosis.o obj/drive.o
>> obj/drive1.o
>> obj/drive2.o obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o
>> obj/connect1.o
>> obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
>> obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
>> obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
>> obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
>> obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
>> obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o
>> obj/hsmg.o
>> obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o obj/navier6.o
>> obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o obj/calcz.o
>> obj/byte.o
>> obj/chelpers.o obj/byte_mpi.o obj/postpro.o obj/cvode_driver.o
>> obj/nek_comm.o obj/init_plugin.o obj/setprop.o obj/qthermal.o
>> obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o obj/dsygv.o
>> obj/mxm_std.o obj/blas.o obj/comm_mpi.o obj/mpi_dummy.o obj/singlmesh.o
>> obj/jl2_gs.o obj/jl2_sort.o obj/jl2_sarray_transfer.o
>> obj/jl2_sarray_sort.o
>> obj/jl2_gs_local.o obj/jl2_crystal.o obj/jl2_comm.o obj/jl2_tensor.o
>> obj/jl2_fail.o obj/jl2_fcrystal.o obj/jl_tuple_list.o obj/jl_transfer.o
>> obj/jl_sort.o obj/jl_fcrystal.o obj/jl_errmem.o obj/jl_crystal.o
>> obj/jl2_findpts.o obj/jl2_findpts_local.o obj/jl2_obbox.o obj/jl2_poly.o
>> obj/jl2_lob_bnd.o obj/jl2_findpts_el_3.o obj/jl2_findpts_el_2.o
>> obj/jl2_sparse_cholesky.o obj/jl2_xxt.o obj/jl2_fcrs.o
>> ld: 0711-317 ERROR: Undefined symbol: .etime
>> ld: 0711-345 Use the -bloadmap or -bnoquiet option to obtain more
>> information.
>> gmake: *** [nek5000] Error 8
>> Attached is the whole compiler.out file also. Does anyone have an idea?
>> Regards,
>> Jean-Christophe
>>  _______________________________________________
> Nek5000-users mailing list
Jean-Christophe
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110525/e1414845/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110525/e1414845/attachment.gif>
