[Nek5000-users] Compilation error
Wed May 25 07:41:04 CDT 2011
Hi Jean-Christophe,
Could you try to modify makefile after makenek has generated it? That is what I do for g95 compiler on my Mac.
The downside is that .f file should be a copy of .usr file every time you modify it.
Best,
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Wednesday, May 25, 2011 7:21:58 AM
Subject: Re: [Nek5000-users] Compilation error
Thanks for the tip, it now works at least for serial calculation. Note furthermore that, using the xlf compiler from ibm, I also had to change -qrealsize=8 into -qautodbl=dbl4 in order to avoid a segmentation fault.
I am now trying to compile to it for parallel calculation, thus I specified mpxlf_r and mpcc_r in F77 and C fields in makenek. However I get the following message as soon as I start the compilation:
./makenek stenosis
makenek - automatic build tool for Nek5000
** test === End of Compilation 1 ===
1501-510 Compilation successful for file test_f77.f.
llsubmit: Processed command file through Submit Filter: "/usr/local/loadl/Fidris/llsubmit_exit".
** underscore_test === End of Compilation 1 ===
1501-510 Compilation successful for file test_underscore.f.
ERROR: Unable to detect compiler!
- don't know how to promote datatype REAL to 8 bytes
- don't know how to invoke the C pre-processor (CPP) before compilation
Please edit the makefile and specify the requested compiler flags using the P variable.
I presume it is a fairly simple error to solve, but I am not familiar at all with such massively parallel calculators yet
Best regards,
JC
On 24 May 2011 16:20, < nek5000-users at lists.mcs.anl.gov > wrote:
Dear Jean-Christophe,
etime is a fairly std. timer function, but obviously not
supported with your compiler.
When using mpi, it uses instead the mpi timer, so there is no
issue.
The quick fix here would be to edit mpi_dummy.f and change
the etime() reference therein to the ibm timer function.
You might also try setting it zero - but I'm not 100% certain
that there are no divisions involving time in the denominator...
It's worth a try, however.
Paul
On Tue, 24 May 2011, nek5000-users at lists.mcs.anl.gov wrote:
Hi Nek's,
Up to now I have compiled and run the code on the various workstations
available in my lab. I am now trying to compile it (only in serial for the
moment) on an IBM Power 6 (
http://www.idris.fr/su/Scalaire/vargas/hw-vargas.html ) but I encounter an
error (which is the reason why I do not compile it using mpi support
yet). Following is the outpost from the compilation:
xlf_r -qsuppress=cmpmsg -o nek5000 obj/stenosis.o obj/drive.o obj/drive1.o
obj/drive2.o obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o obj/hsmg.o
obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o obj/navier6.o
obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o obj/calcz.o obj/byte.o
obj/chelpers.o obj/byte_mpi.o obj/postpro.o obj/cvode_driver.o
obj/nek_comm.o obj/init_plugin.o obj/setprop.o obj/qthermal.o
obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o obj/dsygv.o
obj/mxm_std.o obj/blas.o obj/comm_mpi.o obj/mpi_dummy.o obj/singlmesh.o
obj/jl2_gs.o obj/jl2_sort.o obj/jl2_sarray_transfer.o obj/jl2_sarray_sort.o
obj/jl2_gs_local.o obj/jl2_crystal.o obj/jl2_comm.o obj/jl2_tensor.o
obj/jl2_fail.o obj/jl2_fcrystal.o obj/jl_tuple_list.o obj/jl_transfer.o
obj/jl_sort.o obj/jl_fcrystal.o obj/jl_errmem.o obj/jl_crystal.o
obj/jl2_findpts.o obj/jl2_findpts_local.o obj/jl2_obbox.o obj/jl2_poly.o
obj/jl2_lob_bnd.o obj/jl2_findpts_el_3.o obj/jl2_findpts_el_2.o
obj/jl2_sparse_cholesky.o obj/jl2_xxt.o obj/jl2_fcrs.o
ld: 0711-317 ERROR: Undefined symbol: .etime
ld: 0711-345 Use the -bloadmap or -bnoquiet option to obtain more
information.
gmake: *** [nek5000] Error 8
Attached is the whole compiler.out file also. Does anyone have an idea?
Jean-Christophe
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Jean-Christophe
