[Nek5000-users] Location based viscosity
Thu Mar 24 10:06:53 CDT 2011
Hi Josh,
make sure you accivating a call to uservp by either setting
       ifuservp = .true.
say in usrdat2 passed through 'TOTAL' or by p30>0 in .rea
Best,
Aleks
On Thu, 24 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Josh,
> How about setting "udiff" in uservp?
> Note that if you have more than one field (e.g., temperature and velocity)
> then you discriminate by ifield:
>      if (ifield.eq.1)  then  ! viscosity
>         udiff   = my viscosity
>         utrans  = my rho
>      elseif (ifield.eq.2)  then  ! conductivity
>         udiff   = my conductivity
>         utrans  = my rho C_p
>      endif
> Note that technically, you should use the full stress tensor
> when doing this, since the d/dxj mu du_j/dx_i
> term no longer vanishes.
> Are you using PnPn, or PnPn-2 ?
> Paul
>> Hello Neks,
>> This seems like it should be simple, but can somehow show me how I can
>> vary viscosity based on a given x, y, z?
>> I'm guessing I should be able to do this in uservp, looking at the
>> var_visc example, but I don't immediately see a variable that I can
>> edit in NEKUSE (like I could for ux, uy, etc....)
>> Thanks,
>> Josh Camp
>> "All that is necessary for the triumph of evil is that good men do
>> nothing" -- Edmund Burke
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
