[Nek5000-users] Restart with geometry changes
Mon Mar 14 06:24:37 CDT 2011
combining fld files for restart is a pretty slick feature!
Since I started out with f000*, I used your .usr -routine, which worked
perfectly.
Markus
nek5000-users at lists.mcs.anl.gov wrote:
> Markus,
> If you're using .fld files, you can simply modify your .rea file:
>             1 PRESOLVE/RESTART OPTIONS  *****
> my_old.fld01  U P T time=0
> which tells nek to take _only_ U P T and from the .fld
> file (assuming they are present), and to not take anything
> else.   Also, it tells it to reset time to 0 at the start
> of this calculation.   Note that if you have, say,
>             2 PRESOLVE/RESTART OPTIONS  *****
> my_old.fld02    P T
> it would take U from fld01 and P, T, and time from fld02.
> I don't believe we have this level of support in the .f0000
> format yet, but I can possibly put someone on it.
> In your case (assuming you're using .f0000 format), you can
> instead do the following in usrdat2 (by which point nek
> knows the geometry, but has not yet read initial conditions):
> c-----------------------------------------------------------------------
>       subroutine usrdat2
>       include 'SIZE'
>       include 'TOTAL'
>       parameter (ltt=lx1*ly1*lz1*lelt)
>       common /cmygeom/ xmo(llt),ymo(llt),zmo(llt)
>       call opcopy(xmo,ymo,zmo,xm1,ym1,zm1)  ! Preserve my geometry
>       return
>       end
>       subroutine usrchk
>       include 'SIZE'
>       include 'TOTAL'
>       call opcopy(xm1,ym1,zm1,xmo,ymo,zmo)  ! Restore my geometry
>       call geom_reset(1)                    ! Force regen. of Jacobians
> etc.
>       return
>       end
> Paul
> On Thu, 10 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Howdy Neks,
>> I ran a simulation on a certain geometry, saved solution files and
>> would now like to restart the same run from a given time step. The
>> difference is that I have implemented a geometry change via usrdat,
>> but when I reload the previous solution (which contains xyz), it
>> overwrites my changes and uses the geometry on which the solution was
>> originally computed.
>> To work around this, is it OK to just comment out line 367 in ic.f?
>> c         call geom_reset(1)  !  recompute geometric factors
>> Would this cause the old data to be mapped onto the new grid?
>> Thanks,
>> Markus
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
