[Nek5000-users] Restart with geometry changes
Fri Mar 11 14:06:56 CST 2011
Hi David,
Nek does the following:
Sets geometry
Reads I.C.s
If you .fld file contains geometry, this supersedes
the geometry that has been set unless you say otherwise.
Paul
On Fri, 11 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> This post is making me wonder if I understand how restarting works.  If I
> have some geometry in my .rea file, and I restart from a .fld file with
> different geometry, which geometry takes precedence?  I had been assuming
> that nek interpolated the old data onto the mesh in the .rea file.  And is
> the answer affected by whether or not the .fld file contains geometry data?
> I think only my fld01 files contain that.
> Best,
> David
> On Fri, Mar 11, 2011 at 9:41 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Markus,
>> If you're using .fld files, you can simply modify your .rea file:
>>            1 PRESOLVE/RESTART OPTIONS  *****
>> my_old.fld01  U P T time=0
>> which tells nek to take _only_ U P T and from the .fld
>> file (assuming they are present), and to not take anything
>> else.   Also, it tells it to reset time to 0 at the start
>> of this calculation.   Note that if you have, say,
>>            2 PRESOLVE/RESTART OPTIONS  *****
>> my_old.fld02    P T
>> it would take U from fld01 and P, T, and time from fld02.
>> I don't believe we have this level of support in the .f0000
>> format yet, but I can possibly put someone on it.
>> In your case (assuming you're using .f0000 format), you can
>> instead do the following in usrdat2 (by which point nek
>> knows the geometry, but has not yet read initial conditions):
>> c-----------------------------------------------------------------------
>>      subroutine usrdat2
>>      include 'SIZE'
>>      include 'TOTAL'
>>      parameter (ltt=lx1*ly1*lz1*lelt)
>>      common /cmygeom/ xmo(llt),ymo(llt),zmo(llt)
>>      call opcopy(xmo,ymo,zmo,xm1,ym1,zm1)  ! Preserve my geometry
>>      return
>>      end
>>      subroutine usrchk
>>      include 'SIZE'
>>      include 'TOTAL'
>>      call opcopy(xm1,ym1,zm1,xmo,ymo,zmo)  ! Restore my geometry
>>      call geom_reset(1)                    ! Force regen. of Jacobians etc.
>>      return
>>      end
>> Paul
