[Nek5000-users] Re : CYCLIC BC for bend pipe
Sun Jun 26 10:50:12 CDT 2011
Hi Paul;
Since I am using Prenek to generate the base mesh for the pipe in X-Y
plane, and then extrude it in the Z direction using the n2to3 tool, is
there any easy way to change the orientation of such a mesh based on
your suggestion? Or maybe I need to start generating the grid from the
very beginning in X-Z plane?
Best regards
Azad
PS - be sure that the rotation preserves the right-handed
coordinates of the original system.
On Sun, 26 Jun 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Azad,
> It's important that the "cyclic" axis be the z-axis.
> You may need to rotate your geometry into this orientation.
> In that case, your inlet/out planes would, say, be x-z
> and y-z planes.
> Paul
>> Dear Neks;
>> I had a question regarding cyclic bc. It works properly for 2D and 3D
>> curved channel, (arch-like curvature is generated in stream-wise
>> direction using userdat2 with period bc at the both ends). However, when
>> I try it for the curved pipe, seems not working at all. I appreciate it
>> if you could help me by that.
>> Many thanks;
>> Azad
