[Nek5000-users] CYCLIC BC for bend pipe
Sun Jun 26 09:09:10 CDT 2011
PS - be sure that the rotation preserves the right-handed
coordinates of the original system.
On Sun, 26 Jun 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Azad,
> It's important that the "cyclic" axis be the z-axis.
> You may need to rotate your geometry into this orientation.
> In that case, your inlet/out planes would, say, be x-z
> and y-z planes.
> Paul
>> Dear Neks;
>> I had a question regarding cyclic bc. It works properly for 2D and 3D
>> curved channel, (arch-like curvature is generated in stream-wise
>> direction using userdat2 with period bc at the both ends). However, when
>> I try it for the curved pipe, seems not working at all. I appreciate it
>> if you could help me by that.
>> Many thanks;
>> Azad
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
