[Nek5000-users] Re : CYCLIC BC for bend pipe
Sun Jun 26 13:10:25 CDT 2011
Hi Azad,
Yes - you can do this in usrdat2.
Below is an example that would put a 90 degree semicircular
arc into the x-y plane, which is what you would need.  (Note,
I just coded this without testing it..., so you'll need to
verify and obviously modify to get your correct geometry.)
Cheers,
Paul
c-----------------------------------------------------------------------
      subroutine usrdat2
      include 'SIZE'
      include 'TOTAL'
      n = nx1*ny1*nz1*nelv
c    First, rotate x into axial position
      do i=1,n
         x_original = xm1(i,1,1,1)
         y_original = ym1(i,1,1,1)
         z_original = zm1(i,1,1,1)
         xm1(i,1,1,1) =  z_original
         ym1(i,1,1,1) =  y_original
         zm1(i,1,1,1) = -x_original
      enddo
c    Second, bend pipe into 90 degree bend (say)
      xmin = glmin(xm1,n)
      xmax = glmax(xm1,n)
      ymin = glmin(ym1,n)
      ymax = glmax(ym1,n)
      rad0 = .5*(ymax-ymin) ! Radius of initial pipe
      rad1 = 0.5            ! Radius of new pipe (say)
      radm = 1.5            ! Major radius of torus
      do i=1,n
         x     = xm1(i,1,1,1)
         y     = ym1(i,1,1,1)
         theta = 0.5*pi*(x-xmin)/(xmax-xmin)
         rad   = radm + rad1*(y-ymin)/(ymax-ymin)
         ym1(i,1,1,1) = rad*cos(theta)  ! This should be the
         xm1(i,1,1,1) = rad*sin(theta)  ! correct orientation.
      enddo
      return
      end
On Sun, 26 Jun 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul;
> Since I am using Prenek to generate the base mesh for the pipe in X-Y
> plane, and then extrude it in the Z direction using the n2to3 tool, is
> there any easy way to change the orientation of such a mesh based on
> your suggestion? Or maybe I need to start generating the grid from the
> very beginning in X-Z plane?
> Best regards
> Azad
> PS - be sure that the rotation preserves the right-handed
> coordinates of the original system.
>> Hi Azad,
>> It's important that the "cyclic" axis be the z-axis.
>> You may need to rotate your geometry into this orientation.
>> In that case, your inlet/out planes would, say, be x-z
>> and y-z planes.
>> Paul
>>> Dear Neks;
>>> I had a question regarding cyclic bc. It works properly for 2D and 3D
>>> curved channel, (arch-like curvature is generated in stream-wise
>>> direction using userdat2 with period bc at the both ends). However, when
>>> I try it for the curved pipe, seems not working at all. I appreciate it
>>> if you could help me by that.
>>> Many thanks;
>>> Azad
> Nek5000-users mailing list
