[Nek5000-users] Primer for reacting flows
Fri Jul 29 12:08:45 CDT 2011
Mike, I don't know. Contact me off list to discuss the details.
-Stefan
On 7/29/11, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Stefan, Josh, Dave,  thanks for the responses.
> Dave -- pointing me to the shear4 example and sending the files was helpful.
>  Thanks!
> Stefan, I might be able to pull of what I need to do now with the
> current-version passive-scalar features.  That said, coupling nek with CVODE
> is quite appealing.   Are there any plans for your reactive-flow plug-in to
> be available publicly?
> --Mike
> On Jul 29, 2011, at 9:55 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> My thesis is probably a good point to start :)
>> http://e-collection.library.ethz.ch/view/eth:1899
>> -Stefan
>>> Hi Stefan,
>>> Reactive flows are something my group is also wanting to look at
>>> possibly in the near future.  I know you said the plug-in is not
>>> available, but was a paper produced from the work?  I thought it might
>>> be interesting  (and informative) to read the paper if it exists.
>>> Thanks,
>>> Josh
>>> On Fri, Jul 29, 2011 at 9:42 AM,  <nek5000-users at lists.mcs.anl.gov>
>>> wrote:
>>>> Hi Mike,
>>>> The base version of Nek is not ready to simulate chemically reacting
>>>> flows. What are the fits and gaps?
>>>> Fits:
>>>> - Low Mach number formulation to deal with density varying flows
>>>> - Accurate splitting formulation to segregate the hydrodynamic
>>>> sub-system (momentum+continuity eqn) and the thermochemical sub-system
>>>> (energy and species eqn)
>>>> - Interface to CVODE (a high order integrator to solve the stiff
>>>> thermochemical sub system efficiently)
>>>> Gaps:
>>>> - Routine to compute the RHS (needed input for CVODE)
>>>> - The routine to compute the thermal divergence does not include the
>>>> species eqns
>>>> - Routines to compute the thermophysical and kinetic properties
>>>> I developed a plug-in to do reactive DNS using Nek  when I was a PhD
>>>> student at ETH Zurich. It performed really well and we did some pretty
>>>> impressive simulations at the time
>>>> (http://nek5000.mcs.anl.gov/index.php/Visualization_Gallery). I am
>>>> afraid the plug-in is not available for the public :(
>>>> Cheers,
>>>> Stefan
>>>> On 7/28/11, nek5000-users at lists.mcs.anl.gov
>>>>> Hi Mike,
>>>>> Here are the .rea and .usr files of a case I did with 2 reacting
>>>>> scalars.
>>>>> The files are modified versions of the rayleigh case from repo that
>>>>> simulates the Boussinesq equations, but I turned off the buoyancy term
>>>>> and
>>>>> added a second scalar with reaction.
>>>>> In the userq routine in the .usr file, the qvol term specifies scalar
>>>>> production due to reaction.  The first scalar is called temp.  The next
>>>>> ones
>>>>> are ps(1), ps(2), etc.  The conditional statement (ifield.eq.2)
>>>>> specifies
>>>>> production of temp, the (ifield.eq.3) statement specifies production of
>>>>> ps(1).
>>>>> The README of the shear4 example from repo, which has 4 passive
>>>>> scalars,
>>>>> describes how you can change the parameters relating to the multiple
>>>>> scalars.
>>>>> hth,
>>>>> David
>>>>> On Thu, Jul 28, 2011 at 2:57 PM, <nek5000-users at lists.mcs.anl.gov>
>>>>> wrote:
>>>>>> All,
>>>>>> I'm interested in using Nek for simulation of reacting flows.  Can
>>>>>> anyone
>>>>>> send me, or point me towards, a simple example that could get me
>>>>>> going?
>>>>>>  I
>>>>>> guess I'm most interested to see the details of storage/operation with
>>>>>> passive scalars.
>>>>>> Thanks.
>>>>>> --Mike
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> Josh Camp
>>> "All that is necessary for the triumph of evil is that good men do
>>> nothing" -- Edmund Burke
