[Nek5000-users] Primer for reacting flows
Fri Jul 29 11:42:29 CDT 2011
Stefan, Josh, Dave,  thanks for the responses.
Dave -- pointing me to the shear4 example and sending the files was helpful.  Thanks!
Stefan, I might be able to pull of what I need to do now with the current-version passive-scalar features.  That said, coupling nek with CVODE is quite appealing.   Are there any plans for your reactive-flow plug-in to be available publicly?
--Mike
On Jul 29, 2011, at 9:55 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> My thesis is probably a good point to start :)
> http://e-collection.library.ethz.ch/view/eth:1899
> -Stefan
> On 7/29/11, nek5000-users at lists.mcs.anl.gov
>> Hi Stefan,
>> Reactive flows are something my group is also wanting to look at
>> possibly in the near future.  I know you said the plug-in is not
>> available, but was a paper produced from the work?  I thought it might
>> be interesting  (and informative) to read the paper if it exists.
>> Thanks,
>> Josh
>> On Fri, Jul 29, 2011 at 9:42 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Mike,
>>> The base version of Nek is not ready to simulate chemically reacting
>>> flows. What are the fits and gaps?
>>> Fits:
>>> - Low Mach number formulation to deal with density varying flows
>>> - Accurate splitting formulation to segregate the hydrodynamic
>>> sub-system (momentum+continuity eqn) and the thermochemical sub-system
>>> (energy and species eqn)
>>> - Interface to CVODE (a high order integrator to solve the stiff
>>> thermochemical sub system efficiently)
>>> Gaps:
>>> - Routine to compute the RHS (needed input for CVODE)
>>> - The routine to compute the thermal divergence does not include the
>>> species eqns
>>> - Routines to compute the thermophysical and kinetic properties
>>> I developed a plug-in to do reactive DNS using Nek  when I was a PhD
>>> student at ETH Zurich. It performed really well and we did some pretty
>>> impressive simulations at the time
>>> (http://nek5000.mcs.anl.gov/index.php/Visualization_Gallery). I am
>>> afraid the plug-in is not available for the public :(
>>> Cheers,
>>> Stefan
>>> On 7/28/11, nek5000-users at lists.mcs.anl.gov
>>>> Hi Mike,
>>>> Here are the .rea and .usr files of a case I did with 2 reacting scalars.
>>>> The files are modified versions of the rayleigh case from repo that
>>>> simulates the Boussinesq equations, but I turned off the buoyancy term
>>>> and
>>>> added a second scalar with reaction.
>>>> In the userq routine in the .usr file, the qvol term specifies scalar
>>>> production due to reaction.  The first scalar is called temp.  The next
>>>> ones
>>>> are ps(1), ps(2), etc.  The conditional statement (ifield.eq.2) specifies
>>>> production of temp, the (ifield.eq.3) statement specifies production of
>>>> ps(1).
>>>> The README of the shear4 example from repo, which has 4 passive scalars,
>>>> describes how you can change the parameters relating to the multiple
>>>> scalars.
>>>> hth,
>>>> David
>>>> On Thu, Jul 28, 2011 at 2:57 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>> All,
>>>>> I'm interested in using Nek for simulation of reacting flows.  Can
>>>>> anyone
>>>>> send me, or point me towards, a simple example that could get me going?
>>>>>  I
>>>>> guess I'm most interested to see the details of storage/operation with
>>>>> passive scalars.
>>>>> Thanks.
>>>>> --Mike
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Josh Camp
>> "All that is necessary for the triumph of evil is that good men do
>> nothing" -- Edmund Burke
