[Nek5000-users] First Visit file
Thu Jan 6 14:32:01 CST 2011
Right, Paul, but the difference is the line with the filename
template while the rest of the visit metafile is the same -- skipping the
header in .nek5000 works fine too.
Here is the new script that should work for all cases:
http://www.mcs.anl.gov/~obabko/visnek
Best,
Aleks
On Thu, 6 Jan 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Just to clarify -
> binary/ascii .fld files are the same w.r.t. VisIt  (I believe).
> However, for ".f0000" files (the other binary format), you
> need a slightly different specification in the .nek3d file.
> (Correct guys?)
> Paul
>> Nek5000 header and extension will work for both including .f files.
>> Aleks
>>> Hi,
>>> finally: should i assume that to have the same script for binary files
>>> the only thing to be done is to change the line
>>>  echo 'filetemplate: '$base'.fld%02d'   >> $base.nek3d
>>> in the previous script?.
>>> Thanks.
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
