[Nek5000-users] First Visit file
Thu Jan 6 14:20:34 CST 2011
Just to clarify -
binary/ascii .fld files are the same w.r.t. VisIt  (I believe).
However, for ".f0000" files (the other binary format), you
need a slightly different specification in the .nek3d file.
(Correct guys?)
Paul
On Thu, 6 Jan 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Nek5000 header and extension will work for both including .f files.
> Aleks
>> Hi,
>> finally: should i assume that to have the same script for binary files
>> the only thing to be done is to change the line
>>  echo 'filetemplate: '$base'.fld%02d'   >> $base.nek3d
>> in the previous script?.
>> Thanks.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
