[Nek5000-users] NaN after velocity save
Thu Jan 6 12:57:55 CST 2011
Hello All.
I'm try to run about the simplest problem possible in order to test some in-house post-processing code.
So, I'm trying to run a 2-D simulation of planar couette flow and I'm doing so in serial on my mac.  Once velocity solutions start being saved, param=94, I abruptly start getting NaN's.
Any thoughts as to what's going wrong??
Attached are the relevant files.
Thanks.
--Mike
Desc: z2.map
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110106/9141161d/attachment.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110106/9141161d/attachment.txt>
Desc: z2.rea
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110106/9141161d/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110106/9141161d/attachment-0001.txt>
Desc: z2.usr
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110106/9141161d/attachment-0002.obj>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110106/9141161d/attachment-0002.txt>
Desc: SIZE
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110106/9141161d/attachment-0003.obj>
