[Nek5000-users] NaN after velocity save
Thu Jan 6 13:49:30 CST 2011
Hi Mike,
Before we look at the case, can you try it with p94=p95=0?  Once a
solution is close to steady state there can be a problem with
projection...
Aleks
On Thu, 6 Jan 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hello All.
> I'm try to run about the simplest problem possible in order to test some in-house post-processing code.
> So, I'm trying to run a 2-D simulation of planar couette flow and I'm doing so in serial on my mac.  Once velocity solutions start being saved, param=94, I abruptly start getting NaN's.
> Any thoughts as to what's going wrong??
> Attached are the relevant files.
> Thanks.
> --Mike
