[Nek5000-users] NaN after velocity save
Thu Jan 6 13:53:32 CST 2011
Aleks,
Thanks, that did it.    Incidentally, I was starting it *with* the steady-state solution, so it couldn't have been closer!
--Mike
On Jan 6, 2011, at 12:49 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mike,
> Before we look at the case, can you try it with p94=p95=0?  Once a
> solution is close to steady state there can be a problem with
> projection...
> Thanks,
> Aleks
> On Thu, 6 Jan 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello All.
>> I'm try to run about the simplest problem possible in order to test some in-house post-processing code.
>> So, I'm trying to run a 2-D simulation of planar couette flow and I'm doing so in serial on my mac.  Once velocity solutions start being saved, param=94, I abruptly start getting NaN's.
>> Any thoughts as to what's going wrong??
>> Attached are the relevant files.
>> Thanks.
>> --Mike
> Nek5000-users mailing list
