[Nek5000-users] stokes flow with time-dependent boundary
Wed Dec 21 11:47:26 CST 2011
Hi Lailai,
To switch to unsteady Stokes, you simply set the flag
IFNAV to "F" in the .rea file, which turns off the convective
term and simultaneously eliminates the CFL timestep constraint.
[  Set:
   T F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
to
   F F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
It's still not clear to me if you are solving an unsteady
Stokes problem, or a series of steady Stokes problems.
(There is a difference...)
Nek can handle either case with equal ease.
I hope this helps.
Paul
On Wed, 21 Dec 2011, nek5000-users at lists.mcs.anl.gov wrote:
> On 12/19/2011 06:17 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Lailai,
>> I have used the approach you proposed for solving multiple
>> steady stokes problems... you use an artificially large
>> timestep.  That works.
> thank for your reply, if understand correctly, here you are talking about the
> second approach i proposed. For each time step, we solve a transient problem
> with very large internal timestep to quickly get to the steady-state
> solution.
> since i am very new to nek5000, thus  i am not sure how to implement this
> method which seems not trivial.
> On the other hand, i started from the first example of the Kovasznay problem.
> I remove the time-derivative and convection term by setting the density in
> .rea file to zero, the numerical results agree very well with the analytical
> solution with zero Re number. I guess here the solver is just inverting a
> matrix which seems feasible for a 2D problem but might be too expensive or
> inefficient for a 3D problem.
>> If you really have a time-dependent boundary condition, there
>> is no reason you can't just use the unsteady Stokes solver
>> with whatever timestep is required to accurately resolve your
>> temporal bcs.   Note that, in this case, you would indeed have
>> the inertial term rho du/dt present in the physics.
>> Paul
>> On Mon, 19 Dec 2011, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hello, guys,
>>> i am a new guy to Nek5000, i saw the manual of nek5000 that it can solve
>>> the steady stokes flow.
>>> i guess when i solve such a flow, do i need to set it as a transient
>>> simulation with time-derivative term included to get  a steady-state
>>> solution? or, i can solve it by a direct solver method to get the solution
>>> immediately?
>>> since i want to add some time-dependent boundary condition for the steady
>>> stokes flow, so it will be pretty nice if i can solve it using the direct
>>> solver, for each time step, i solve one stokes flow; if nek5000 cannot
>>> solve it in such a way, i guess i have to use the first way; then for each
>>> time step i have to solve a transient problem to approach the steady state
>>> with some artificial time step used.
>>> i am not sure if i have stated my problem clearly. hopefully you guys have
>>> some experience on the feasibility of the two ways mentioned above. Thank
>>> you in advance.
>>> lailai
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
