[Nek5000-users] stokes flow with time-dependent boundary
Wed Dec 21 15:12:40 CST 2011
thank you for your tip, Paul.
i think we are solving a series of Stokes problems linked by a
time-dependent boundary condition.
The time-derivative term is zero and we are not solving an unsteady
Stokes problem.  I think we are not clear how to solve a series of
Stokes problems.
lailai
On 12/21/2011 06:47 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Lailai,
> To switch to unsteady Stokes, you simply set the flag
> IFNAV to "F" in the .rea file, which turns off the convective
> term and simultaneously eliminates the CFL timestep constraint.
> [  Set:
>   T F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
> to
>   F F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
> It's still not clear to me if you are solving an unsteady
> Stokes problem, or a series of steady Stokes problems.
> (There is a difference...)
> Nek can handle either case with equal ease.
> I hope this helps.
> Paul
> On Wed, 21 Dec 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> On 12/19/2011 06:17 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Lailai,
>>> I have used the approach you proposed for solving multiple
>>> steady stokes problems... you use an artificially large
>>> timestep.  That works.
>> thank for your reply, if understand correctly, here you are talking
>> about the second approach i proposed. For each time step, we solve a
>> transient problem with very large internal timestep to quickly get to
>> the steady-state solution.
>> since i am very new to nek5000, thus  i am not sure how to implement
>> this method which seems not trivial.
>> On the other hand, i started from the first example of the Kovasznay
>> problem. I remove the time-derivative and convection term by setting
>> the density in .rea file to zero, the numerical results agree very
>> well with the analytical solution with zero Re number. I guess here
>> the solver is just inverting a matrix which seems feasible for a 2D
>> problem but might be too expensive or inefficient for a 3D problem.
>>> If you really have a time-dependent boundary condition, there
>>> is no reason you can't just use the unsteady Stokes solver
>>> with whatever timestep is required to accurately resolve your
>>> temporal bcs.   Note that, in this case, you would indeed have
>>> the inertial term rho du/dt present in the physics.
>>> Paul
>>> On Mon, 19 Dec 2011, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hello, guys,
>>>> i am a new guy to Nek5000, i saw the manual of nek5000 that it can
>>>> solve the steady stokes flow.
>>>> i guess when i solve such a flow, do i need to set it as a
>>>> transient simulation with time-derivative term included to get  a
>>>> steady-state solution? or, i can solve it by a direct solver method
>>>> to get the solution immediately?
>>>> since i want to add some time-dependent boundary condition for the
>>>> steady stokes flow, so it will be pretty nice if i can solve it
>>>> using the direct solver, for each time step, i solve one stokes
>>>> flow; if nek5000 cannot solve it in such a way, i guess i have to
>>>> use the first way; then for each time step i have to solve a
>>>> transient problem to approach the steady state with some artificial
>>>> time step used.
>>>> i am not sure if i have stated my problem clearly. hopefully you
>>>> guys have some experience on the feasibility of the two ways
>>>> mentioned above. Thank you in advance.
>>>> lailai
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
