[Nek5000-users] stokes flow with time-dependent boundary
Wed Dec 21 08:30:40 CST 2011
On 12/19/2011 06:17 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Lailai,
> I have used the approach you proposed for solving multiple
> steady stokes problems... you use an artificially large
> timestep.  That works.
thank for your reply, if understand correctly, here you are talking
about the second approach i proposed. For each time step, we solve a
transient problem with very large internal timestep to quickly get to
the steady-state solution.
since i am very new to nek5000, thus  i am not sure how to implement
this method which seems not trivial.
On the other hand, i started from the first example of the Kovasznay
problem. I remove the time-derivative and convection term by setting the
density in .rea file to zero, the numerical results agree very well with
the analytical solution with zero Re number. I guess here the solver is
just inverting a matrix which seems feasible for a 2D problem but might
be too expensive or inefficient for a 3D problem.
> If you really have a time-dependent boundary condition, there
> is no reason you can't just use the unsteady Stokes solver
> with whatever timestep is required to accurately resolve your
> temporal bcs.   Note that, in this case, you would indeed have
> the inertial term rho du/dt present in the physics.
> Paul
> On Mon, 19 Dec 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello, guys,
>> i am a new guy to Nek5000, i saw the manual of nek5000 that it can
>> solve the steady stokes flow.
>> i guess when i solve such a flow, do i need to set it as a transient
>> simulation with time-derivative term included to get  a steady-state
>> solution? or, i can solve it by a direct solver method to get the
>> solution immediately?
>> since i want to add some time-dependent boundary condition for the
>> steady stokes flow, so it will be pretty nice if i can solve it using
>> the direct solver, for each time step, i solve one stokes flow; if
>> nek5000 cannot solve it in such a way, i guess i have to use the
>> first way; then for each time step i have to solve a transient
>> problem to approach the steady state with some artificial time step
>> used.
>> i am not sure if i have stated my problem clearly. hopefully you guys
>> have some experience on the feasibility of the two ways mentioned
>> above. Thank you in advance.
>> lailai
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
