[Nek5000-users] Solving for fluid flows on a sphere
Sun Aug 14 01:17:05 CDT 2011
Hi Paul,
I setup a simulation but I keep getting NaN's when I give nontrivial
initial data. I'm attaching the relevant files. Could you please try it out?
I checked that the initial data is divergence free and satisfies the
boundary conditions (u_r = 0, du_theta/dr = 0, du_phi/dr = 0).
Mani
On 08/11/2011 05:46 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Mani,
> Probably your best bet is to use a very thin layer of elements
> in a 3D spherical shell with SYM bcs on faces 5 & 6, plus the
> stress formulation.  I would imagine that a shell of thickness
> .001 with R=1.0 might be feasible.
> Instructions for constructing a 3D shell can be found in
> www.mcs.anl.gov/~fischer/primer.pdf
> (Some of this info may already have been transferred into
> current manual.)   We can help with this if you need any
> assistance.
> Regards,
> Paul
> On Thu, 11 Aug 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Nek devs,
>> Is it possible to use NEK to solve for Navier Stokes equations on the
>> surface of a sphere, where r is fixed and the velocity varies in
>> theta and
>> phi?
>> Thanks,
>> Mani Chandra
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110814/f244aff7/attachment.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110814/f244aff7/attachment-0001.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110814/f244aff7/attachment-0002.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110814/f244aff7/attachment-0003.ksh>
