[Nek5000-users] Solving for fluid flows on a sphere
Thu Aug 11 08:12:39 CDT 2011
Hi Paul,
Thanks for the response. I'll give it a shot and will post to the mailing
list again for help.
Mani
> Hi Mani,
> Probably your best bet is to use a very thin layer of elements
> in a 3D spherical shell with SYM bcs on faces 5 & 6, plus the
> stress formulation.  I would imagine that a shell of thickness
> .001 with R=1.0 might be feasible.
> Instructions for constructing a 3D shell can be found in
> www.mcs.anl.gov/~fischer/primer.pdf
> (Some of this info may already have been transferred into
> current manual.)   We can help with this if you need any
> assistance.
> Regards,
> Paul
> On Thu, 11 Aug 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Nek devs,
>> Is it possible to use NEK to solve for Navier Stokes equations on the
>> surface of a sphere, where r is fixed and the velocity varies in theta
>> and
>> phi?
>> Thanks,
>> Mani Chandra
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
