[Nek5000-users] Grid 2 Grid Interpolation
Thu Sep 23 10:42:57 CDT 2010
Send over the case and I'll try to have a look at it.
-Stefan
----- Original Message -----
To: Nekton User List <nek5000-users at lists.mcs.anl.gov>
Sent: Wed, 22 Sep 2010 21:35:09 -0600 (GMT-06:00)
Subject: [Nek5000-users] Grid 2 Grid Interpolation
Hi Stefan,
I am having some difficulty using this routine and would like to check that I am setting things up correctly.  Do I set PPList = " MPIIO " in makenek ?
Also, I have set lpart to 100000.  The issue I am having is that when I run nek to generate the newgfld it is not outputting any data into 'newg0.f00001'. It
creates it, but nothing is written and then nek quits.
Also, can I use existing fld files from each case, old and new, or does the new case need to be a "blank slate"? Thanks for help with this, and if you would like
I can create a case file to send.
- Michael
