[Nek5000-users] A Restart Issue with NaNs
Tue Nov 30 20:43:53 CST 2010
Hi Michael,
One of my favorite tests at this point is to reduce dt to
a ridiculously low value, e.g., 1.e-6 or so...  At that
point, inertia should conquer all and the solution should
change very little...
>From your earlier email, I had the impression that you had
made several runs (for this case?) with restart w/o difficulty,
but now it looks like you're indicating you get the problem
for any of the restart files?
Has something changed in the .usr file or .rea file?
Paul
On Tue, 30 Nov 2010, nek5000-users at lists.mcs.anl.gov wrote:
> I don't believe it is corrupted. I min/max values given after the restart
> files load looks good, and I also
> just confirmed it using glmax/glmin.
> Also, I have several restart files that I have tried, all resulting in the
> same problem. I have also looked
> at them in visit and everything looks consistent from what I had before,
> could it still be corrupted even then?
> I have 5   *.f  files in increments of 4 seconds. I terminated the run
> to change something with 'echo -2 >ioinfo'.
> Fld files 3-5 give the problem, while number 2 worked.
> -Michael
> ----- Original Message ----- From: nek5000-users at lists.mcs.anl.gov To:
> "Nekton User List" <nek5000-users at lists.mcs.anl.gov> Sent: Tuesday, November
> 30, 2010 7:21:09 PM GMT -06:00 US/Canada Central Subject: Re: [Nek5000-users]
> Hi Micheal, How did this computation finish on the prior run? Is the data
> corrupted? (i.e., are there nans in the file?) You might try setting nsteps
> to zero and then checking via glmin/glmax or something to see if the restart
> file is corrupted. Paul On Tue, 30 Nov 2010, nek5000-users at lists.mcs.anl.gov
> wrote: > > > Hi, > > > > I am having an issue with a simulation in which I
> restart using the restart options in the Rea file. At the very first time
> step > > I get NaN's in the Helmholtz VelZ .  I have done several restarts
> of the same simulation at earlier points to arrive at where I am at > > now,
> however I get this upon trying to continue the simulation further.  > > > >
> Any ideas on why this could be, or how to troubleshoot it?  I'm not sure
> what I could do since this is showing up on the very > > first time step. > >
> > > Thanks a lot, > > Michael >
> > > _______________________________________________ Nek5000-users mailing
> > > list Nek5000-users at lists.mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
