[Nek5000-users] X11
Fri Nov 19 12:53:23 CST 2010
pre and post have slightly different x11 interfaces...  given
that post was used on a wider variety of platforms, it got
more development.
I'm upgrading pre right now and will see if I can remedy this
issue.
Paul
On Fri, 19 Nov 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Harish,
> I did that but the problem persists. This is the output:
> Make prenek...
> gfortran -c   prenek.f
> gfortran -c   curve.f
> gfortran -c   edit.f
> gfortran -c   build.f
> gfortran -c   build1.f
> gfortran -c   build2.f
> gfortran -c   bound.f
> gfortran -c   plot.f
> gfortran -c   xinterface.f
> gfortran -c   glomod.f
> glomod.f:1534.9:
>      ja(2) = w(2,1)
>        1
> Warning: Array reference at (1) is out of bounds
> gfortran -c   legend.f
> gfortran -c   vprops.f
> gfortran -c   iolib.f
> gfortran -c   subs.f
> gfortran -c   zipper2.f
> zipper2.f:1560.20:
>      COMMON /CTMP2/ XP(NXM3),YP(NXM3),ZP(NXM3),RRL(3)
>                   1
> Warning: Named COMMON block 'ctmp2' at (1) shall be of the same size
> zipper2.f:2816.20:
>                   1
> zipper2.f:4639.20:
>      common /ctmp2/ xp(nxm3),yp(nxm3),zp(nxm3),wk(ldw)
>                   1
> zipper2.f:4640.20:
>      common /ctmp0/ jx(nxm*3),jyt(nym*3),jzt(nzm*3)
>                   1
> Warning: Named COMMON block 'ctmp0' at (1) shall be of the same size
> zipper2.f:4776.20:
>      common /ctmp0/ xcb(2,2,2),ycb(2,2,2),zcb(2,2,2),w(ldw)
>                   1
> gfortran -c   postnek6.f
> gfortran -c   screen.f
> gcc -c -DUNDERSCORE -Dr8 revert.c
> gfortran -c   crs.f
> gfortran -c   mxm.f
> gcc -c -DUNDERSCORE -Dr8 xdriver.c
> xdriver.c:4:22: error: X11/Xlib.h: No such file or directory
> xdriver.c:5:23: error: X11/Xutil.h: No such file or directory
> xdriver.c:6:28: error: X11/cursorfont.h: No such file or directory
> xdriver.c:7:27: error: X11/Intrinsic.h: No such file or directory
> xdriver.c:8:28: error: X11/StringDefs.h: No such file or directory
> In file included from xdriver.c:9:
> /usr/lib/gcc/i686-apple-darwin8/4.0.1/include/X11/Xos.h:298:23: error:
> X11/Xarch.h: No such file or directory
> xdriver.c:10:23: error: X11/Xatom.h: No such file or directory
> xdriver.c:11:27: error: X11/Xresource.h: No such file or directory
>           Alex Fabregat
>        Post-doctoral fellow
>        University of Ottawa
> Department of Mechanical Engineering
> Nek5000-users mailing list
