[Nek5000-users] X11
Fri Nov 19 12:56:53 CST 2010
Hi Alex,
Are you sure you are providing the path to /usr/X11R6/lib in the
makefile and not /usr/X11R6/include/X11?
Harish.
On Fri, 19 Nov 2010 nek5000-users at lists.mcs.anl.gov wrote:
> pre and post have slightly different x11 interfaces...  given
> that post was used on a wider variety of platforms, it got
> more development.
> I'm upgrading pre right now and will see if I can remedy this
> issue.
> Paul
> On Fri, 19 Nov 2010, nek5000-users at lists.mcs.anl.gov wrote:
> > Hi Harish,
> > I did that but the problem persists. This is the output:
> > Make prenek...
> > gfortran -c   prenek.f
> > gfortran -c   curve.f
> > gfortran -c   edit.f
> > gfortran -c   build.f
> > gfortran -c   build1.f
> > gfortran -c   build2.f
> > gfortran -c   bound.f
> > gfortran -c   plot.f
> > gfortran -c   xinterface.f
> > gfortran -c   glomod.f
> > glomod.f:1534.9:
> >      ja(2) = w(2,1)
> >        1
> > Warning: Array reference at (1) is out of bounds
> > gfortran -c   legend.f
> > gfortran -c   vprops.f
> > gfortran -c   iolib.f
> > gfortran -c   subs.f
> > gfortran -c   zipper2.f
> > zipper2.f:1560.20:
> >      COMMON /CTMP2/ XP(NXM3),YP(NXM3),ZP(NXM3),RRL(3)
> >                   1
> > Warning: Named COMMON block 'ctmp2' at (1) shall be of the same size
> > zipper2.f:2816.20:
> >                   1
> > zipper2.f:4639.20:
> >      common /ctmp2/ xp(nxm3),yp(nxm3),zp(nxm3),wk(ldw)
> >                   1
> > zipper2.f:4640.20:
> >      common /ctmp0/ jx(nxm*3),jyt(nym*3),jzt(nzm*3)
> >                   1
> > Warning: Named COMMON block 'ctmp0' at (1) shall be of the same size
> > zipper2.f:4776.20:
> >      common /ctmp0/ xcb(2,2,2),ycb(2,2,2),zcb(2,2,2),w(ldw)
> >                   1
> > gfortran -c   postnek6.f
> > gfortran -c   screen.f
> > gcc -c -DUNDERSCORE -Dr8 revert.c
> > gfortran -c   crs.f
> > gfortran -c   mxm.f
> > gcc -c -DUNDERSCORE -Dr8 xdriver.c
> > xdriver.c:4:22: error: X11/Xlib.h: No such file or directory
> > xdriver.c:5:23: error: X11/Xutil.h: No such file or directory
> > xdriver.c:6:28: error: X11/cursorfont.h: No such file or directory
> > xdriver.c:7:27: error: X11/Intrinsic.h: No such file or directory
> > xdriver.c:8:28: error: X11/StringDefs.h: No such file or directory
> > In file included from xdriver.c:9:
> > /usr/lib/gcc/i686-apple-darwin8/4.0.1/include/X11/Xos.h:298:23: error:
> > X11/Xarch.h: No such file or directory
> > xdriver.c:10:23: error: X11/Xatom.h: No such file or directory
> > xdriver.c:11:27: error: X11/Xresource.h: No such file or directory
> >           Alex Fabregat
> >        Post-doctoral fellow
> >        University of Ottawa
> > Department of Mechanical Engineering
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
