[Nek5000-users] X11
Fri Nov 19 12:50:43 CST 2010
Hi Harish,
I did that but the problem persists. This is the output:
Make prenek...
gfortran -c   prenek.f
gfortran -c   curve.f
gfortran -c   edit.f
gfortran -c   build.f
gfortran -c   build1.f
gfortran -c   build2.f
gfortran -c   bound.f
gfortran -c   plot.f
gfortran -c   xinterface.f
gfortran -c   glomod.f
glomod.f:1534.9:
      ja(2) = w(2,1)
        1
Warning: Array reference at (1) is out of bounds
gfortran -c   legend.f
gfortran -c   vprops.f
gfortran -c   iolib.f
gfortran -c   subs.f
gfortran -c   zipper2.f
zipper2.f:1560.20:
      COMMON /CTMP2/ XP(NXM3),YP(NXM3),ZP(NXM3),RRL(3)
                   1
Warning: Named COMMON block 'ctmp2' at (1) shall be of the same size
zipper2.f:2816.20:
                   1
zipper2.f:4639.20:
      common /ctmp2/ xp(nxm3),yp(nxm3),zp(nxm3),wk(ldw)
                   1
zipper2.f:4640.20:
      common /ctmp0/ jx(nxm*3),jyt(nym*3),jzt(nzm*3)
                   1
Warning: Named COMMON block 'ctmp0' at (1) shall be of the same size
zipper2.f:4776.20:
      common /ctmp0/ xcb(2,2,2),ycb(2,2,2),zcb(2,2,2),w(ldw)
                   1
gfortran -c   postnek6.f
gfortran -c   screen.f
gcc -c -DUNDERSCORE -Dr8 revert.c
gfortran -c   crs.f
gfortran -c   mxm.f
gcc -c -DUNDERSCORE -Dr8 xdriver.c
xdriver.c:4:22: error: X11/Xlib.h: No such file or directory
xdriver.c:5:23: error: X11/Xutil.h: No such file or directory
xdriver.c:6:28: error: X11/cursorfont.h: No such file or directory
xdriver.c:7:27: error: X11/Intrinsic.h: No such file or directory
xdriver.c:8:28: error: X11/StringDefs.h: No such file or directory
In file included from xdriver.c:9:
/usr/lib/gcc/i686-apple-darwin8/4.0.1/include/X11/Xos.h:298:23: error:
X11/Xarch.h: No such file or directory
xdriver.c:10:23: error: X11/Xatom.h: No such file or directory
xdriver.c:11:27: error: X11/Xresource.h: No such file or directory
           Alex Fabregat
        Post-doctoral fellow
        University of Ottawa
Department of Mechanical Engineering
