[Nek5000-users] solver tolerances and norm of residual
Tue Nov 16 14:06:38 CST 2010
Hi Paul,
it worked!!
The crucial difference between my file and yours was:
<       parameter (lz2=lz1-2)
>       parameter (lz2=lz1  )
I am a little ashamed for not having seen it but the output was not giving
me any clue.
Thank you so much.
> Hi Alex,
> I just tried your case - it ran w/o any difficulty.
> I wonder if there is an issue w/ your SIZE file?  I've
> placed the one that I used in
> www.mcs.anl.gov/~fischer/SIZE
> which you can just grab.  Then makenek 3dtest followed by
> the usual run process.... Let me know if this resolves the
> issue for you.
> Cheers,
> Paul F.
> On Tue, 16 Nov 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> I think this is not the reason because in a previous attempt to face the
>> 3D problems I tried to solve the 3D lid-driven cavity (no periodic BC)
>> and
>> I obtained the same error: NaN in Helholtz residual.
>> Maybe I should start from the turbChannel example and simplify the
>> problem
>> to reach a laminar 3D poiseuille flow.
>> Anyway, thanks a lot for your answers.
>>> A quick look of the *rea file did not bring up anything.  I recall an
>>> issue with periodic BC's, following is an email from one of the
>>> developers:
>>> Hi Frank,
>>> Yes -- we currently don't support periodic bcs for
>>> anything smaller than a 3 x 3 x 3 array of elements.
>>> There's a technical reason for this --- it can be
>>> circumvented if really needed, but it would not
>>> fit within the std. context.
>>> Sorry about that.
>>> Paul
>>> On Tue, 2010-11-16 at 12:56 -0500, nek5000-users at lists.mcs.anl.gov
>>> wrote:
>>>> Hi Frank,
>>>> The rea file has been attached.
>>>> Meanwhile I'll check the BC...
>>>> Thanks
>>>>> Hello Alex,
>>>>> I looked through your files & didn't see anything amiss (by the way,
>>>> it
>>>>> would be best to post your *.rea file).  Since it blows up on the
>>>> first
>>>>> attempt to solve for pressure, perhaps the BC's don't satisfy
>>>>> conservation of mass?
>>>>> Cheers,
>>>>> Frank
>>>>> On Tue, 2010-11-16 at 11:40 -0500, nek5000-users at lists.mcs.anl.gov
>>>>> wrote:
>>>>>> Hi Nek users,
>>>>>> I am new in using Nek5. I have succesfully simualted the lid-driven
>>>>>> flow,
>>>>>> rayleigh-bénard in a square cavity and laminar poiseuille flow.
>>>> All of
>>>>>> them were 2d cases. I though it would be straightforward to move
>>>>>> from
>>>> 2D
>>>>>> to 3D simualtions but I have not been able to run a 3D poiseuille
>>>>>> channel.
>>>>>> I am obtaining an error on Helmoltz solver even in the first
>>>> iteration.
>>>>>> Please, find output, usr and box files attached.
>>>>>> Thanks in advance.
>>>>>>            Alex Fabregat
>>>>>>         Post-doctoral fellow
>>>>>>         University of Ottawa
>>>>>> Department of Mechanical Engineering
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>>>> Technische Universität Wien (Vienna University of Technology)
>>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute
>>>>> of
>>>> Fluid
>>>>> Mechanics and Heat Transfer)
>>>>> Resselgasse 3
>>>>> 1040 Wien
>>>>> Tel: +4315880132232
>>>>> Fax: +4315880132299
>>>>> Cell:+436765203470
>>>>> fmuldoo (skype)
>>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>>>            Alex Fabregat
>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>> Resselgasse 3
>>> 1040 Wien
>>> Tel: +4315880132232
>>> Fax: +4315880132299
>>> Cell:+436765203470
>>> fmuldoo (skype)
>>           Alex Fabregat
           Alex Fabregat
