[Nek5000-users] solver tolerances and norm of residual
Tue Nov 16 14:14:03 CST 2010
Sorry - that's a check that we should add... It's now on my
todo list.
Paul
On Tue, 16 Nov 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> it worked!!
> The crucial difference between my file and yours was:
> <       parameter (lz2=lz1-2)
>>       parameter (lz2=lz1  )
> I am a little ashamed for not having seen it but the output was not giving
> me any clue.
> Thank you so much.
>> Hi Alex,
>> I just tried your case - it ran w/o any difficulty.
>> I wonder if there is an issue w/ your SIZE file?  I've
>> placed the one that I used in
>> www.mcs.anl.gov/~fischer/SIZE
>> which you can just grab.  Then makenek 3dtest followed by
>> the usual run process.... Let me know if this resolves the
>> issue for you.
>> Cheers,
>> Paul F.
>>> Hi,
>>> I think this is not the reason because in a previous attempt to face the
>>> 3D problems I tried to solve the 3D lid-driven cavity (no periodic BC)
>>> and
>>> I obtained the same error: NaN in Helholtz residual.
>>> Maybe I should start from the turbChannel example and simplify the
>>> problem
>>> to reach a laminar 3D poiseuille flow.
>>> Anyway, thanks a lot for your answers.
>>>> A quick look of the *rea file did not bring up anything.  I recall an
>>>> issue with periodic BC's, following is an email from one of the
>>>> developers:
>>>> Hi Frank,
>>>> Yes -- we currently don't support periodic bcs for
>>>> anything smaller than a 3 x 3 x 3 array of elements.
>>>> There's a technical reason for this --- it can be
>>>> circumvented if really needed, but it would not
>>>> fit within the std. context.
>>>> Sorry about that.
>>>> Paul
>>>> On Tue, 2010-11-16 at 12:56 -0500, nek5000-users at lists.mcs.anl.gov
>>>> wrote:
>>>>> Hi Frank,
>>>>> The rea file has been attached.
>>>>> Meanwhile I'll check the BC...
>>>>> Thanks
>>>>>> Hello Alex,
>>>>>> I looked through your files & didn't see anything amiss (by the way,
>>>>> it
>>>>>> would be best to post your *.rea file).  Since it blows up on the
>>>>> first
>>>>>> attempt to solve for pressure, perhaps the BC's don't satisfy
>>>>>> conservation of mass?
>>>>>> Cheers,
>>>>>> Frank
>>>>>> On Tue, 2010-11-16 at 11:40 -0500, nek5000-users at lists.mcs.anl.gov
>>>>>> wrote:
>>>>>>> Hi Nek users,
>>>>>>> I am new in using Nek5. I have succesfully simualted the lid-driven
>>>>>>> flow,
>>>>>>> rayleigh-bénard in a square cavity and laminar poiseuille flow.
>>>>> All of
>>>>>>> them were 2d cases. I though it would be straightforward to move
>>>>>>> from
>>>>> 2D
>>>>>>> to 3D simualtions but I have not been able to run a 3D poiseuille
>>>>>>> channel.
>>>>>>> I am obtaining an error on Helmoltz solver even in the first
>>>>> iteration.
>>>>>>> Please, find output, usr and box files attached.
>>>>>>> Thanks in advance.
>>>>>>>            Alex Fabregat
>>>>>>>         Post-doctoral fellow
>>>>>>>         University of Ottawa
>>>>>>> Department of Mechanical Engineering
>>>>>>> _______________________________________________
>>>>>>> Nek5000-users mailing list
>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>>>>> Technische Universität Wien (Vienna University of Technology)
>>>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute
>>>>>> of
>>>>> Fluid
>>>>>> Mechanics and Heat Transfer)
>>>>>> Resselgasse 3
>>>>>> 1040 Wien
>>>>>> Tel: +4315880132232
>>>>>> Fax: +4315880132299
>>>>>> Cell:+436765203470
>>>>>> fmuldoo (skype)
>>>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>>>>            Alex Fabregat
>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>>> Resselgasse 3
>>>> 1040 Wien
>>>> Tel: +4315880132232
>>>> Fax: +4315880132299
>>>> Cell:+436765203470
>>>> fmuldoo (skype)
>>>           Alex Fabregat
>           Alex Fabregat
