[Nek5000-users] A good way to approximate second derivatives?
Tue May 25 06:39:51 CDT 2010
Hi Outi,
Nek5000 supports free-surface motion and does not require
2nd derivatives, using the same approach that is used for
the 2nd-order Laplace operator, namely, by transfering one
of the derivatives to the test functions.
The description of the implementation can be found in Lee W. Ho's
MIT thesis
http://dspace.mit.edu/handle/1721.1/14293
Note that one of our example problems, fs_hydro, implements
a linear stability test with results described in
  www.mcs.anl.gov/~fischer/users.pdf
I'm not certain if this is what you're needing?
Paul
On Tue, 25 May 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello!
> This is the first time I write to this list.
> I am a PhD student at KTH Mechanics, and use Nek5000 mostly to get steady
> solutions for my linear stability calculations (where the steadiness is
> imposed geometrically, by boundary conditions) on 2D wakes and jets. The
> stability calculation is performed on a different grid, in another code.
> I wrote a script where I interpolate the solution form Nek5000 exactly to my
> stability grid using the Legendre basis functions, and for the flow variables
> (U,V,P) and their first derivatives this works fine. However, now I am using
> the same steady solution to calculate stability with surface tension (since
> for slowly developing flows the steady state without surface tension can
> still be used). In this new setting, the second derivatives (Uxx,Uyy,Vxx,Vyy)
> are also needed.
> Therefore I wonder if there is any standard way to approximate the second
> derivatives of the flow variables in Nek5000?
> The basis functions are only C1-continuous across the element boundaries, and
> even if they would have been continuous, the second derivatives are always
> noisy, e.g. if taken from experimental data.
> Currently I use finite differences combined with a smooth function in Matlab
> with a 5-point moving average.
> Thank you for input or better ideas,
> Outi Tammisola
> Nek5000-users mailing list
