[Nek5000-users] NEKTON and Gambit
Fri May 21 14:21:20 CDT 2010
Hi Josh,
Yes, I recall that.  For sure, I'd be grateful if you could let him know
that he has an eager customer for his program.
Cheers,
Frank
On Fri, 2010-05-21 at 19:09 +0000, nek5000-users at lists.mcs.anl.gov
wrote:
> Hey Frank,
> One of my colleagues, Michael, posted a method a while back that lists the steps to do something like this.  It involves exporting the mesh from Gambit to the neutral file format (NEU) and then using a matlab program to convert the mesh to a usable REA file.
> I can't go into more detail than that as I wasn't the one to write the Matlab program, but I'm sure he wouldn't mind passing the Matlab file along again when he gets back to campus.  Hope this helps,
> - Josh
> -----Original Message-----
> From: nek5000-users at lists.mcs.anl.gov
> Date: Fri, 21 May 2010 18:39:51
> To: <nek5000-users at lists.mcs.anl.gov>
> Subject: [Nek5000-users] NEKTON and Gambit
> Hello all,
> I notice that Fluent's grid generator Gambit writes out meshes in NEKTON
> format.  However, from looking at the (ASCI) file it write out, it
> doesn't seem to be related to the structure the NEK5000 is expecting.
> Does anyone know if it is at all possible to get a mesh from Gambit into
> a format that NEK5000 can use?
> Cheers,
> Frank
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
