[Nek5000-users] NEKTON and Gambit
Fri May 21 14:09:16 CDT 2010
Hey Frank,
One of my colleagues, Michael, posted a method a while back that lists the steps to do something like this.  It involves exporting the mesh from Gambit to the neutral file format (NEU) and then using a matlab program to convert the mesh to a usable REA file.
I can't go into more detail than that as I wasn't the one to write the Matlab program, but I'm sure he wouldn't mind passing the Matlab file along again when he gets back to campus.  Hope this helps,
- Josh
-----Original Message-----
Date: Fri, 21 May 2010 18:39:51
To: <nek5000-users at lists.mcs.anl.gov>
Subject: [Nek5000-users] NEKTON and Gambit
Hello all,
I notice that Fluent's grid generator Gambit writes out meshes in NEKTON
format.  However, from looking at the (ASCI) file it write out, it
doesn't seem to be related to the structure the NEK5000 is expecting.
Does anyone know if it is at all possible to get a mesh from Gambit into
a format that NEK5000 can use?
Cheers,
Frank
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
